Zero-JavaScript Charting using UIBUILDER for Node-RED & the Datatype font
This is a very simple to use charting method. It requires no JavaScript to be loaded at all (apart from the UIBUILDER client library of course) - none written by you anyway. 🙂
The example flow loads the font from Google and sends data updates for the 3 different chart types every 10 seconds.
image image
Simply load the [Datatype font}(https://franktisellano.github.io/datatype/) - either from Google fonts or download the font file and put in your instance source folder (or use the uibuilder common folder, typically ~/.node-red/uibuilder/common if you want to make it available to all uibuilder instances and pages).
Loading via Google fonts requires the following 3 statements in the <head> section of your index.html file:
    <!-- If NOT using a local install, load the font from Google Fonts -->
    <link rel="preconnect" href="https://fonts.googleapis.com">
    <link rel="preconnect" href="https://fonts.gstatic.com" crossorigin>
    <link href="https://fonts.googleapis.com/css2?family=Datatype:[email protected]&display=swap" rel="stylesheet">
If loading from a local copy, you only need some code in your index.css:
/* If NOT using Google Fonts, load the font locally */
@font-face {
  font-family: 'Datatype';
  src: url('Datatype.woff2') format('woff2');
  font-display: swap;
Either way, you will also want a CSS class definition to use the font, again in your index.css:
/* Use it on chart expressions */
.chart {
  font-family: 'Datatype', monospace;
  /* Optional: adjust axes */
  font-variation-settings: 'wdth' 15;
  font-weight: 400;
  font-size: 24pt;
[{"id":"47ac12f779aeb262","type":"tab","label":"nojs-charts","disabled":false,"info":"","env":[]},{"id":"32525a5fbe8c87fb","type":"group","z":"47ac12f779aeb262","name":"RUN ONCE: Initialise Front-end Code - Run after the uibuilder node has been deployed. \\n REMEMBER to change the uib node name before use \\n Sets up FE code, reloads connected clients. \\n ","style":{"label":true,"stroke":"#a4a4a4","fill-opacity":"0.33","color":"#000000","fill":"#ffffff"},"nodes":["5a67c8966c9c9b52","7ca1a91a76ea8738","e984cefed0e0f1a1","4a0b2d4c62668516","74267a32548ba4cc","d4b9d4d1f12ad72a"],"x":34,"y":191,"w":572,"h":170},{"id":"d922faf8e29ff646","type":"group","z":"47ac12f779aeb262","name":"New data for the 3 different charts. Auto updates every 10 seconds","style":{"label":true,"color":"#000000"},"nodes":["77e6e9067941d454","97fad63dc64436e9","61ceb395faef2732","852d331a3bf85184"],"x":34,"y":379,"w":542,"h":162},{"id":"2a9f925e5c45d5c2","type":"uibuilder","z":"47ac12f779aeb262","name":"","topic":"","url":"nojs-charts","instancePath":"","okToGo":true,"fwdInMessages":false,"allowScripts":false,"allowStyles":false,"copyIndex":true,"templateFolder":"blank","extTemplate":"","showfolder":false,"reload":true,"sourceFolder":"src","deployedVersion":"7.6.2","showMsgUib":false,"title":"","descr":"","editurl":"vscode://file/D:/src\\uibRoot/nojs-charts/?windowId=_blank","x":280,"y":140,"wires":[[],[]]},{"id":"1cd8784886d01a20","type":"link in","z":"47ac12f779aeb262","name":"link in 20","links":["cf78803c235c0db6","97fad63dc64436e9"],"x":95,"y":140,"wires":[["2a9f925e5c45d5c2"]]},{"id":"5a67c8966c9c9b52","type":"inject","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"setup all FE files","x":95,"y":280,"wires":[["74267a32548ba4cc","d4b9d4d1f12ad72a"]],"l":false},{"id":"7ca1a91a76ea8738","type":"template","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","name":"index.html","field":"payload","fieldType":"msg","format":"html","syntax":"plain","template":"<!doctype html>\n<html lang=\"en\"><head>\n\n    <meta charset=\"utf-8\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    <link rel=\"icon\" href=\"../uibuilder/images/uib-world.svg\" type=\"image/svg+xml\">\n\n    <title>Zero JavaScript Charts - Node-RED UIBUILDER</title>\n    <meta name=\"description\" content=\"Node-RED UIBUILDER - Zero JavaScript Charts - A simple example of how to create charts without writing any JavaScript.\">\n\n    <!-- Your own CSS (defaults to loading uibuilders css)-->\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"./index.css\" media=\"all\">\n\n    <!-- If NOT using a local install, load the font from Google Fonts -->\n    <link rel=\"preconnect\" href=\"https://fonts.googleapis.com\">\n    <link rel=\"preconnect\" href=\"https://fonts.gstatic.com\" crossorigin>\n    <link href=\"https://fonts.googleapis.com/css2?family=Datatype:[email protected]&display=swap\" rel=\"stylesheet\">\n\n    <!-- #region Supporting Scripts. These MUST be in the right order. Note no leading / -->\n    <script defer src=\"../uibuilder/uibuilder.iife.min.js\">/* THE UIBUILDER LIBRARY MUST BE IN THE HTML! DO NOT REMOVE */</script>\n    <!-- <script defer src=\"./index.js\">/* OPTIONAL: Put your custom code in that */</script> -->\n    <!-- #endregion -->\n\n</head><body>\n    \n    <h1 class=\"with-subtitle\">Zero JavaScript Charts</h1>\n    <div role=\"doc-subtitle\">Using UIBUILDER for Node-RED & the <a href=\"https://franktisellano.github.io/datatype/\" target=\"_blank\">Datatype font</a></div>\n\n    <p>\n        Check out the <code>index.css</code> file to see how to load and configure the Datatype font.\n        Check out this <code>index.html</code> file to see how to load from Google Fonts (if not loading locally).\n    </p>\n    <p>\n        The charts auto-update with data from Node-RED every 10 seconds in the example flow.\n    </p>\n    <article>\n        Send a message with a payload like this to display a chart:\n        <pre><code>{\n    \"topic\": \"my-chart-1\",\n    \"payload\": \"{b:30,70,20,90}\" // NB: Text content, not JSON\n}</code></pre>\n        <div>This is an inline bar chart: <uib-var topic=\"my-chart-1\" class=\"chart\"><i>{Waiting for data}</i></uib-var>.</div>\n    </article>\n\n    <article>\n        For a sparkline chart:\n        <pre><code>{\n    \"topic\": \"my-chart-2\",\n    \"payload\": \"{l:30,70,20,90}\" // NB: Text content, not JSON\n}</code></pre>\n        <div>This is an inline sparkline chart: <uib-var topic=\"my-chart-2\" class=\"chart\"><i>{Waiting for data}</i></uib-var>.</div>\n    </article>\n\n    <article>\n        For a pie chart:\n        <pre><code>{\n    \"topic\": \"my-chart-3\",\n    \"payload\": \"{p:70}\" // NB: Text content, not JSON\n}</code></pre>\n        <p>This is a pie chart:</p>\n        <div>\n            <uib-var topic=\"my-chart-3\" class=\"chart\"><i>{Waiting for data}</i></uib-var>\n        </div>\n    </article>\n\n    <!-- '#more' is used as a parent for dynamic HTML content in examples\n         Also, send {topic:\"more\", payload:\"Hello from <b>Node-RED</b>\"} to auto-display the payload -->\n    <div id=\"more\" uib-topic=\"more\"></div>\n\n</body></html>\n","output":"str","x":300,"y":280,"wires":[["e984cefed0e0f1a1"]]},{"id":"e984cefed0e0f1a1","type":"uib-save","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","url":"nojs-charts","uibId":"2a9f925e5c45d5c2","folder":"src","fname":"","createFolder":false,"reload":true,"usePageName":false,"encoding":"utf8","mode":438,"name":"","topic":"","x":510,"y":280,"wires":[]},{"id":"4a0b2d4c62668516","type":"template","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","name":"index.css","field":"payload","fieldType":"msg","format":"css","syntax":"plain","template":"/* Load defaults from `<userDir>/node_modules/node-red-contrib-uibuilder/front-end/uib-brand.min.css`\n * This is optional but reasonably complete and allows for light/dark mode switching.\n */\n@import url(\"../uibuilder/uib-brand.min.css\");\n\n/* If NOT using Google Fonts, load the font locally */\n/* @font-face {\n  font-family: 'Datatype';\n  src: url('Datatype.woff2') format('woff2');\n  font-display: swap;\n} */\n\n/* Use it on chart expressions */\n.chart {\n    font-family: 'Datatype', monospace;\n    /* Optional: adjust axes */\n    font-variation-settings: 'wdth' 15;\n    font-weight: 400;\n    font-size: 24pt;\n}\n\nuib-var[topic=\"my-chart-3\"] {\n    font-size: 48pt;\n}\n\n/* Making the JSON view smaller for this page */\npre>code {\n    font-size: 12pt;\n    line-height: 1;\n}\n","output":"str","x":310,"y":320,"wires":[["e984cefed0e0f1a1"]]},{"id":"74267a32548ba4cc","type":"change","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","name":"index.html","rules":[{"t":"set","p":"fname","pt":"msg","to":"index.html","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":185,"y":280,"wires":[["7ca1a91a76ea8738"]],"l":false},{"id":"d4b9d4d1f12ad72a","type":"change","z":"47ac12f779aeb262","g":"32525a5fbe8c87fb","name":"index.js","rules":[{"t":"set","p":"fname","pt":"msg","to":"index.css","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":185,"y":320,"wires":[["4a0b2d4c62668516"]],"l":false},{"id":"77e6e9067941d454","type":"inject","z":"47ac12f779aeb262","g":"d922faf8e29ff646","name":"Bar Chart","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"10","crontab":"","once":true,"onceDelay":0.1,"topic":"my-chart-1","payload":"\"{b:\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") \t& \"}\"","payloadType":"jsonata","x":150,"y":420,"wires":[["97fad63dc64436e9"]]},{"id":"97fad63dc64436e9","type":"link out","z":"47ac12f779aeb262","g":"d922faf8e29ff646","name":"link out 63","mode":"link","links":["1cd8784886d01a20"],"x":535,"y":420,"wires":[]},{"id":"61ceb395faef2732","type":"inject","z":"47ac12f779aeb262","g":"d922faf8e29ff646","name":"Sparkline Chart","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"10","crontab":"","once":true,"onceDelay":0.1,"topic":"my-chart-2","payload":"\"{l:\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") & \",\" \t& $formatInteger($random()*100, \"0\") \t& \"}\"","payloadType":"jsonata","x":170,"y":460,"wires":[["97fad63dc64436e9"]]},{"id":"852d331a3bf85184","type":"inject","z":"47ac12f779aeb262","g":"d922faf8e29ff646","name":"Pie Chart","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"10","crontab":"","once":true,"onceDelay":0.1,"topic":"my-chart-3","payload":"\"{p:\" \t& $formatInteger($random()*100, \"0\") \t& \"}\"","payloadType":"jsonata","x":150,"y":500,"wires":[["97fad63dc64436e9"]]},{"id":"8c3c9ce3f77812d1","type":"comment","z":"47ac12f779aeb262","name":"Zero-JavaScript charting using the Datatype font. \\n Mostly useful for inline charts. \\n Limited to single colour. Easily updated using UIBUILDER's dynamic data features.","info":"","x":330,"y":60,"wires":[]},{"id":"e1e80149b9503e62","type":"global-config","env":[],"modules":{"node-red-contrib-uibuilder":"7.6.2"}}]
Created 6 months, 3 weeks ago
  • change (x2)
  • inject (x4)
  • link in (x1)
  • link out (x1)
  • template (x2)
  • global-config (x1)
  • group (x2)
  • uib-save (x1)
  • uibuilder (x1)
  • uibuilder
  • charts
  • charting
  • zero-code
  • no-javascript
