Health-Endpoint Monitoring
DESCRIPTION: This subflow continuosly checks the connection health between client and the server by sending requests and gathers status codes, SSL certificate and DNS status. Also validates the returned URL, calculates the aproximate data of network and DNS latency. In general it monitors the status of the network all together. Domain name, DNS time health points, response time health points are the variables that can be changed by the user. healthendpointmonitoring_general
DETAILS:
  • This subflow runs every 5 seconds. This time interval was chosen low enough to check the system health frequently but also high enough to don't keep the system busy.
  • While using this subflow you don't need to define msg.url yourself. You just turn msg.payload into the url desired. Flow will automatically change it to url.
  • The flow returns "Healthy" if enough points received from checks made, returns "Facing Issues!" if points gathered is not good but still requires attention, returns "UNHEALTHY!!!" if points gathered show that there are multiple issues and can cause fatal outcomes.
Here are the input variables: healthendpointmonitoring_inputs
NOTE: The output and point calculating parts will be updated soon. But they are still useful.
[{"id":"5a2417f0c7c60cc8","type":"subflow","name":"Subflow 12","info":"","category":"","in":[],"out":[{"x":2040,"y":220,"wires":[{"id":"251a33a10dec253f","port":0}]}],"env":[{"name":"Domain Name","type":"str","value":""},{"name":"Healthy Dns Time Limit","type":"num","value":"200"},{"name":"Unhealthy Dns Time Limit","type":"num","value":"400"},{"name":"Healthy Response Time Limit","type":"num","value":"900"},{"name":"Unhealthy Response Time Limit","type":"num","value":"2000"}],"meta":{},"color":"#DDAA99"},{"id":"2ec708d7bf7139e6","type":"dnsquery","z":"5a2417f0c7c60cc8","name":"","domain_nameType":"env","domain_name":"Domain Name","record_typeType":"rectype","record_type":"ANY","dns_ip":"","x":590,"y":340,"wires":[["414584f0381fb7b6"]]},{"id":"c2d119ef282b98bc","type":"change","z":"5a2417f0c7c60cc8","name":"","rules":[{"t":"set","p":"healthyDnsLimit","pt":"flow","to":"Healthy Dns Time Limit","tot":"env"},{"t":"set","p":"unhealthyDnsLimit","pt":"flow","to":"Unhealthy Dns Time Limit","tot":"env"},{"t":"set","p":"healthyResponseLimit","pt":"flow","to":"Healthy Response Time Limit","tot":"env"},{"t":"set","p":"unhealthyResponseLimit","pt":"flow","to":"Unhealthy Response Time Limit","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":180,"wires":[["2ec708d7bf7139e6","cce9418665fdcba3","9a9cf7cd1ec53002","6b9659c82c8b8d17"]]},{"id":"99f4a1e93c3698aa","type":"inject","z":"5a2417f0c7c60cc8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"timestamp","v":"","vt":"date"},{"p":"urlTime","v":"1","vt":"num"},{"p":"dnsTime","v":"1","vt":"num"},{"p":"urlOutputs","v":"true","vt":"bool"},{"p":"dnsOutputs","v":"true","vt":"bool"},{"p":"urlPoints","v":"0","vt":"num"},{"p":"dnsPoints","v":"0","vt":"num"},{"p":"overallHealth","v":"0","vt":"num"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"http://vancouver.craigslist.org/search/sss?format=rss&query=cars","payloadType":"str","x":110,"y":180,"wires":[["c2d119ef282b98bc"]]},{"id":"cce9418665fdcba3","type":"change","z":"5a2417f0c7c60cc8","name":"","rules":[{"t":"set","p":"url","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":80,"wires":[["59b551f1c5c752ca"]]},{"id":"9a9cf7cd1ec53002","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\nconst d = new Date();\n\n\n\n\nif(flow.get(\"time2\")){\n    \n    msg.urlTime = flow.get(\"time2\") - flow.get(\"time1\");\n\n    flow.set(\"time1\", 0);\n    flow.set(\"time2\", 0);\n    return msg;\n} else {\n    \n    flow.set(\"time1\", msg.timestamp);\n\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1200,"y":160,"wires":[["d8db8c2588f4e64b"]]},{"id":"7483702afcb45faf","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"const d = new Date();\n\nflow.set(\"time2\", d.getTime());\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1020,"y":80,"wires":[["9a9cf7cd1ec53002"]]},{"id":"59b551f1c5c752ca","type":"http request","z":"5a2417f0c7c60cc8","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"","persist":false,"authType":"","senderr":false,"x":810,"y":80,"wires":[["7483702afcb45faf"]]},{"id":"414584f0381fb7b6","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"const d = new Date();\n\nflow.set(\"time4\", d.getTime());\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":340,"wires":[["6b9659c82c8b8d17"]]},{"id":"6b9659c82c8b8d17","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\n\nconst d = new Date();\n\n\n\nif(flow.get(\"time4\")){\n\n    msg.dnsTime = flow.get(\"time4\") - flow.get(\"time3\");\n\n    flow.set(\"time3\", 0);\n    flow.set(\"time4\", 0);\n    return msg;\n    \n} else {\n    flow.set(\"time3\", msg.timestamp);\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1200,"y":280,"wires":[["7ffe7575ea6b3220"]]},{"id":"d8db8c2588f4e64b","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\nconst sslPattern = /https/;\n\nif(msg.urlTime <= flow.get(\"healthyResponseLimit\")){\n    msg.urlPoints += 2;\n} else if (msg.urlTime <= flow.get(\"unhealthyResponseLimit\")){\n    msg.urlPoints += 1;\n}\n\n/*if(msg.url === msg.responseUrl){\n    msg.urlPoints += 1;\n} else {\n    msg.urlPoints = 0;\n}*/\n\nif(msg.statusCode === 200 && msg.responseUrl.match(sslPatern)) {\n    msg.urlPoints += 1;\n} else {\n    msg.urlPoints = 0;\n}\n\nflow.set(\"overallUrlHealth\", msg.urlPoints);\nmsg.urlPoints = 1;\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1420,"y":160,"wires":[["9c092a5dcd783ea4"]]},{"id":"7ffe7575ea6b3220","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\n\nif(msg.dnsTime <= flow.get(\"healthyDnsLimit\")){\n    msg.dnsPoints += 2;\n} else if (msg.dnsTime <= flow.get(\"unhealthyDnsLimit\")){\n    msg.dnsPoints += 1;\n}\n\nif(msg.payload.ok){\n    msg.dnsPoints += 1;\n}\n\nflow.set(\"overallDnsHealth\", msg.dnsPoints);\nmsg.dnsPoints = 1;\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1420,"y":280,"wires":[["9c092a5dcd783ea4"]]},{"id":"9c092a5dcd783ea4","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\nif(!msg.urlPoints){\n    msg.overallHealth += flow.get(\"overallDnsHealth\");\n    return;\n} else if(!msg.dnsPoints){\n    msg.overallHealth += flow.get(\"overallUrlHealth\");\n}\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1640,"y":220,"wires":[["251a33a10dec253f"]]},{"id":"251a33a10dec253f","type":"function","z":"5a2417f0c7c60cc8","name":"","func":"\nif(msg.overallHealth >= 4){\n    msg.payload = \"Healthy\";\n} else if (msg.overallHealth >= 2){\n    msg.payload = \"Facing Issues!\"\n} else {\n    msg.payload = \"UNHEALTHY!!!\"\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1840,"y":220,"wires":[[]]}]
Created 4 years, 4 months ago
  • change (x2)
  • function (x8)
  • http request (x1)
  • Health
  • Backend
  • Health-Monitoring
  • Cloud
