node-red-contrib-dnsquery 1.0.7
Gets the DNS records of a given type of a domain name.
npm install node-red-contrib-dnsquery
By default this node gets the A records, but other record types can be queried. The "ANY" record type should return ALL available records (but unfortunately doesn't always work).
  • If in msg.payload there's a .domain_name:string, it overrides the domain_name setup in the config box Domain Name.
  • If in msg.payload there's a .record_type:string, it overrides the record_type setup in the config box Record Type.
  • If in msg.payload there's a .dns_ip:string, it overrides the dns_ip setup in the config box DNS IP.
Returns the data in msg.payload with following content:
   ok:boolean,
   error:errortxt,
   dns_ip: dns_ip,
   domain:domain,
   type:record_type,
   answer:[
      records
Uses by default the DNSs of the OS, but you can specify a different one in the config box DNS. dnsquery(v1.0.7)
Example:
example example example
Version: 1.0.7
Updated 5 years, 5 months ago
Rating: 4.0 4
50 in the last week
  • dnsquery
  • Jorge Chamorro Bieling, [email protected]
  • bartbutenaers, https://github.com/bartbutenaers
  • Stephen McLaughlin, https://github.com/Steve-Mcl
