OMV Control from Node-RED
Node-RED flow to control and monitor OMV from Node-RED.
[{"id":"fc5b67ddec4d44b3","type":"tab","label":"Open Media Vault","disabled":false,"info":"","env":[{"name":"username","value":"admin","type":"str"},{"name":"password","type":"cred"},{"name":"url","value":"192.168.0.97","type":"str"},{"name":"isSSL","value":"false","type":"bool"}],"credentials":{"password":"__PWRD__"}},{"id":"07c14fcefbbc8ef0","type":"group","z":"fc5b67ddec4d44b3","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["42aabe312f85166b","b462b141711dc8b9","069cbf9aa9737bb9","5e830760495ac684","a76e607bfaad6df7","d5dc94f59e265b67","d9eb63db549f8a26","49cec531070a1e70","bd7e0b1c88cb6fa8","ffb3cb0ac92452c4","2d4ceb80b1f48c3c","c00cdc048159ae15","54705525a089e546"],"x":54,"y":39,"w":1112,"h":202},{"id":"9d02bb13a6093667","type":"group","z":"fc5b67ddec4d44b3","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["f746a74b39398e4f","8e46bb3e1b991dee","ad03f06199ddd903","78f9b0459503c8e9","3881ddf11a80a3d8","f35ce4bd29e567f9","7af9cec876b44f1c","1664605d1e5bad08","752122a354f0fbd2","1dce9cc0f0a269a1","3869318d53932dbf","ab3a7a315d5bddb3","3ed1cdd4319d39bb","9d65d8079235e61f"],"x":54,"y":259,"w":1432,"h":222},{"id":"f3e38f8d1093721c","type":"group","z":"fc5b67ddec4d44b3","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["24c120fbc0b30ac2","14723cb8a29f66f7","2839a54ab4e6f1e5"],"x":54,"y":519,"w":392,"h":122},{"id":"42aabe312f85166b","type":"http request","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":140,"wires":[["d9eb63db549f8a26"]]},{"id":"b462b141711dc8b9","type":"inject","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"10 Mins","props":[],"repeat":"600","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":160,"y":80,"wires":[["a76e607bfaad6df7"]]},{"id":"069cbf9aa9737bb9","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Set Params","func":"let url = (env.get(\"isSSL\") ? \"https://\" : \"http://\") + env.get(\"url\") + \"/rpc.php\";\n\nlet sessionKey = flow.get(\"SESSION_KEY\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nif(!sessionKey)\n    throw(\"Session key is empty.\");\n\nmsg.headers = {\n    Cookie: \"X-OPENMEDIAVAULT-SESSIONID=\" + sessionKey\n}\nmsg.payload = { \"service\": \"FileSystemMgmt\", \"method\":\"enumerateFilesystems\" , \"params\": \"\"}\nmsg.url = url;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":140,"wires":[["42aabe312f85166b"]]},{"id":"5e830760495ac684","type":"http request","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":80,"wires":[["d5dc94f59e265b67"]]},{"id":"a76e607bfaad6df7","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Set Creds","func":"let username = env.get(\"username\");\nlet password = env.get(\"password\");\nlet url = (env.get(\"isSSL\") ? \"https://\" : \"http://\")+env.get(\"url\") +\"/rpc.php\";\nif (!username || !password)\n    throw (\"Username or Password is empty!!.\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nmsg.url = url;\nmsg.payload = {\n    \"service\": \"Session\",\n    \"method\": \"login\",\n    \"params\": {\n        \"username\": username,\n        \"password\": password\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":80,"wires":[["5e830760495ac684"]]},{"id":"d5dc94f59e265b67","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Save Session Key","func":"if (msg.responseCookies){\n    var sessionKey = msg.responseCookies['X-OPENMEDIAVAULT-SESSIONID'].value;\n    if(!sessionKey || msg.statusCode !== 200){\n        throw(\"Server did not respond with Session Key.\");\n    }\n    else{\n        flow.set(\"SESSION_KEY\", sessionKey);\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":730,"y":80,"wires":[["069cbf9aa9737bb9","ffb3cb0ac92452c4"]]},{"id":"d9eb63db549f8a26","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Parse","func":"var data = msg.payload;\n\nif (!!data.response) {\n    msg.payload = data.response.map((e) => {\n        if (e.size == -1)\n            return null;\n        return [{\n                \"available\":  Number(e.available),\n                \"size\": Number(e.size),\n                \"percentage\": Number(e.percentage)\n            },{\n                \"mountpoint\": e.mountpoint,\n                \"name\": e.devicename,\n                \"type\": e.type,\n            }\n        ]\n    });\n\n    return msg\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":140,"wires":[["bd7e0b1c88cb6fa8"]]},{"id":"49cec531070a1e70","type":"influxdb out","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","influxdb":"ab16f9bf.34d058","name":"Influx","measurement":"drive_spaces_omv","precision":"","retentionPolicy":"","database":"database","precisionV18FluxV20":"ms","retentionPolicyV18Flux":"","org":"wglabz","bucket":"omv","x":1090,"y":180,"wires":[]},{"id":"bd7e0b1c88cb6fa8","type":"split","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":890,"y":180,"wires":[["49cec531070a1e70"]]},{"id":"ffb3cb0ac92452c4","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Set Params","func":"let url = (env.get(\"isSSL\") ? \"https://\" : \"http://\") + env.get(\"url\") + \"/rpc.php\";\n\nlet sessionKey = flow.get(\"SESSION_KEY\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nif(!sessionKey)\n    throw(\"Session key is empty.\");\n\nmsg.headers = {\n    Cookie: \"X-OPENMEDIAVAULT-SESSIONID=\" + sessionKey\n}\nmsg.payload = { \"service\": \"system\", \"method\":\"getInformation\" , \"params\": \"\"}\nmsg.url = url;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":200,"wires":[["2d4ceb80b1f48c3c"]]},{"id":"2d4ceb80b1f48c3c","type":"http request","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":200,"wires":[["c00cdc048159ae15"]]},{"id":"c00cdc048159ae15","type":"function","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Parse","func":"var data = msg.payload.response;\nif(data){\n    msg.payload = [[\n        {\n            \"available\": Number(data.memFree),\n            \"size\": Number(data.memTotal),\n            \"percentage\": Number(data.memUtilization) * 100\n        },\n        {\n            \"name\": \"RAM\",\n        }\n    ], [\n            {\n                \"percentage\": Number(data.cpuUsage) * 100,\n            },\n            {\n                \"name\": \"CPU\",\n            }\n        ]\n    ]\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":200,"wires":[["bd7e0b1c88cb6fa8"]]},{"id":"f746a74b39398e4f","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Set Params","func":"let url = (env.get(\"isSSL\") ? \"https://\" : \"http://\") + env.get(\"url\") + \"/rpc.php\";\n\nlet sessionKey = flow.get(\"SESSION_KEY\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nif(!sessionKey)\n    throw(\"Session key is empty.\");\n\nmsg.headers = {\n    Cookie: \"X-OPENMEDIAVAULT-SESSIONID=\" + sessionKey\n}\nmsg.payload = { \"service\": \"system\", \"method\": \"reboot\", \"params\": {\"delay\": 1}}\nmsg.url = url;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":320,"wires":[["8e46bb3e1b991dee"]]},{"id":"8e46bb3e1b991dee","type":"http request","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":1090,"y":380,"wires":[["7af9cec876b44f1c"]]},{"id":"ad03f06199ddd903","type":"http in","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Shutdown OMV","url":"/omv/shutdown","method":"get","upload":false,"swaggerDoc":"","x":160,"y":440,"wires":[["3869318d53932dbf"]]},{"id":"78f9b0459503c8e9","type":"http response","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"","statusCode":"","headers":{},"x":1410,"y":380,"wires":[]},{"id":"3881ddf11a80a3d8","type":"http in","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Reboot OMV","url":"/omv/reboot","method":"get","upload":false,"swaggerDoc":"","x":150,"y":320,"wires":[["1664605d1e5bad08"]]},{"id":"f35ce4bd29e567f9","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Set Params","func":"let url = (env.get(\"isSSL\") ? \"https://\" : \"http://\") + env.get(\"url\") + \"/rpc.php\";\n\nlet sessionKey = flow.get(\"SESSION_KEY\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nif(!sessionKey)\n    throw(\"Session key is empty.\");\n\nmsg.headers = {\n    Cookie: \"X-OPENMEDIAVAULT-SESSIONID=\" + sessionKey\n}\nmsg.payload = { \"service\": \"system\", \"method\": \"shutdown\", \"params\": {\"delay\": 1}}\nmsg.url = url;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":440,"wires":[["8e46bb3e1b991dee"]]},{"id":"24c120fbc0b30ac2","type":"catch","z":"fc5b67ddec4d44b3","g":"f3e38f8d1093721c","name":"HTTP Errors","scope":["42aabe312f85166b","5e830760495ac684","2d4ceb80b1f48c3c","8e46bb3e1b991dee"],"uncaught":false,"x":150,"y":560,"wires":[["14723cb8a29f66f7"]]},{"id":"14723cb8a29f66f7","type":"debug","z":"fc5b67ddec4d44b3","g":"f3e38f8d1093721c","name":"debug 7","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":340,"y":560,"wires":[]},{"id":"7af9cec876b44f1c","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Status Code","func":"if(msg.statusCode == \"EHOSTUNREACH\"){\n    msg.statusCode = 509;\n    msg.payload= {\n        error: \"OMV Server not reachable.\",\n        timestamp: new Date()\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1270,"y":380,"wires":[["78f9b0459503c8e9"]]},{"id":"1664605d1e5bad08","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Set Creds","func":"let username = env.get(\"username\");\nlet password = env.get(\"password\");\nlet url = (env.get(\"isSSL\") ? \"https://\" : \"http://\")+env.get(\"url\") +\"/rpc.php\";\nif (!username || !password)\n    throw (\"Username or Password is empty!!.\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nmsg.url = url;\nmsg.payload = {\n    \"service\": \"Session\",\n    \"method\": \"login\",\n    \"params\": {\n        \"username\": username,\n        \"password\": password\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":320,"wires":[["752122a354f0fbd2"]]},{"id":"752122a354f0fbd2","type":"http request","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":320,"wires":[["1dce9cc0f0a269a1"]]},{"id":"1dce9cc0f0a269a1","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Save Session Key","func":"if (msg.responseCookies){\n    var sessionKey = msg.responseCookies['X-OPENMEDIAVAULT-SESSIONID'].value;\n    if(!sessionKey || msg.statusCode !== 200){\n        throw(\"Server did not respond with Session Key.\");\n    }\n    else{\n        flow.set(\"SESSION_KEY\", sessionKey);\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":730,"y":320,"wires":[["f746a74b39398e4f"]]},{"id":"3869318d53932dbf","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Set Creds","func":"let username = env.get(\"username\");\nlet password = env.get(\"password\");\nlet url = (env.get(\"isSSL\") ? \"https://\" : \"http://\")+env.get(\"url\") +\"/rpc.php\";\nif (!username || !password)\n    throw (\"Username or Password is empty!!.\");\n\nif (!url)\n    throw (\"Please provide the URL.\");\n\nmsg.url = url;\nmsg.payload = {\n    \"service\": \"Session\",\n    \"method\": \"login\",\n    \"params\": {\n        \"username\": username,\n        \"password\": password\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":440,"wires":[["ab3a7a315d5bddb3"]]},{"id":"ab3a7a315d5bddb3","type":"http request","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"http","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":440,"wires":[["3ed1cdd4319d39bb"]]},{"id":"3ed1cdd4319d39bb","type":"function","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"Save Session Key","func":"if (msg.responseCookies){\n    var sessionKey = msg.responseCookies['X-OPENMEDIAVAULT-SESSIONID'].value;\n    if(!sessionKey || msg.statusCode !== 200){\n        throw(\"Server did not respond with Session Key.\");\n    }\n    else{\n        flow.set(\"SESSION_KEY\", sessionKey);\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":730,"y":440,"wires":[["f35ce4bd29e567f9"]]},{"id":"54705525a089e546","type":"comment","z":"fc5b67ddec4d44b3","g":"07c14fcefbbc8ef0","name":"Fetch metrices every 10 mins","info":"","x":1000,"y":80,"wires":[]},{"id":"9d65d8079235e61f","type":"comment","z":"fc5b67ddec4d44b3","g":"9d02bb13a6093667","name":"REST API to shutdown or reboot","info":"","x":1190,"y":300,"wires":[]},{"id":"2839a54ab4e6f1e5","type":"comment","z":"fc5b67ddec4d44b3","g":"f3e38f8d1093721c","name":"Catch All Errors","info":"","x":160,"y":600,"wires":[]},{"id":"ab16f9bf.34d058","type":"influxdb","hostname":"influxdb","port":"8086","protocol":"http","database":"openhab_db","name":"InfluxDB OpenHAB DB","usetls":false,"tls":"","influxdbVersion":"2.0","url":"http://influxdb:8086","rejectUnauthorized":true}]
Created 2 years, 3 months ago
Rating: 5 1
  • catch (x1)
  • comment (x3)
  • function (x13)
  • http in (x2)
  • http request (x6)
  • http response (x1)
  • split (x1)
  • group (x3)
  • influxdb (x1)
  • influxdb out (x1)
  • omv
  • rpc
