MyQ garage door open email
I use this flow in conjunction with a inputs from home assistant to send an email to my phone number to alert me my garage door has been left open for a period of time determined by the slider in home assistant
[{"id":"fda28113496a33c8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"5148bc926a41467f","type":"server-state-changed","z":"fda28113496a33c8","name":"Door","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"cover.garage_door","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"door","valueType":"str"}],"x":70,"y":140,"wires":[["971bbc5907ea71e5"]]},{"id":"3febdb22c8610c93","type":"delay","z":"fda28113496a33c8","name":"delay","pauseType":"delayv","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":590,"y":100,"wires":[["d7ea137e93ae866f"]]},{"id":"fbf5a9bb582a6b71","type":"switch","z":"fda28113496a33c8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":310,"y":100,"wires":[["b493041269fafc8b"],["8728a3538d1bed29"]]},{"id":"8728a3538d1bed29","type":"change","z":"fda28113496a33c8","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":120,"wires":[["3febdb22c8610c93"]]},{"id":"b493041269fafc8b","type":"change","z":"fda28113496a33c8","name":"to millisecs","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay*60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":80,"wires":[["3febdb22c8610c93"]]},{"id":"971bbc5907ea71e5","type":"api-current-state","z":"fda28113496a33c8","name":"Alert","server":"8cd93e38.ec024","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_number.door_open_alert","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"delay","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":190,"y":120,"wires":[["fbf5a9bb582a6b71"]]},{"id":"d7ea137e93ae866f","type":"change","z":"fda28113496a33c8","name":"to min","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay/60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":100,"wires":[["4d27a31ae09e602e"]]},{"id":"4d27a31ae09e602e","type":"template","z":"fda28113496a33c8","name":"format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Garge door has been open for {{delay}} minutes","output":"str","x":830,"y":100,"wires":[["04938ee29639c6bf"]]},{"id":"92e9c478a77ba83f","type":"server-state-changed","z":"fda28113496a33c8","name":"email to","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_text.email","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"email","valueType":"str"}],"x":830,"y":140,"wires":[["04938ee29639c6bf"]]},{"id":"2c94e4e05c0dabe4","type":"api-current-state","z":"fda28113496a33c8","name":"email on/off","server":"8cd93e38.ec024","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.garage_door_email","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1230,"y":120,"wires":[["b38f2b0784bfff21"],[]]},{"id":"04938ee29639c6bf","type":"join","z":"fda28113496a33c8","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":950,"y":120,"wires":[["459b3c37c78c8ecb"]]},{"id":"459b3c37c78c8ecb","type":"change","z":"fda28113496a33c8","name":"change","rules":[{"t":"move","p":"payload.email","pt":"msg","to":"to","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"ALERT! GARAGE DOOR LEFT OPEN","tot":"str"},{"t":"move","p":"payload.door","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":120,"wires":[["2c94e4e05c0dabe4"]]},{"id":"b38f2b0784bfff21","type":"debug","z":"fda28113496a33c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1250,"y":200,"wires":[]},{"id":"8cd93e38.ec024","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
