door trigger light delay off
A simple flow to trigger lights when doors are opened, using Home Assistant and shelly 1L devices
[{"id":"d19fc40c8b2bd127","type":"server-state-changed","z":"bbf3f0397d1bf81a","name":"Back Door Open Trigger","server":"ea58b08c.075dc","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.back_door_detector","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":840,"wires":[["ea8023561a293147"],["d2bd13b7b39274c1","6f21de0790b72f58"]]},{"id":"aaace959c5d1f4bf","type":"ha-device","z":"bbf3f0397d1bf81a","name":"Back Lights on","server":"ea58b08c.075dc","version":0,"debugenabled":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"inputs":0,"deviceType":"trigger","device":"36189e9885f46965b34f2dc46ed48733","event":{"platform":"device","type":"turned_on","device_id":"36189e9885f46965b34f2dc46ed48733","entity_id":"switch.backlights","domain":"switch","metadata":{"secondary":false}},"capabilities":[],"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":680,"y":900,"wires":[["f2a6cff995119e1a"]]},{"id":"b6157a215793b5d8","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"Back Lights on","server":"ea58b08c.075dc","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.backlights"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":980,"y":760,"wires":[[]]},{"id":"f2a6cff995119e1a","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"backgardenspots on","server":"ea58b08c.075dc","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outsidetr"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":900,"wires":[[]]},{"id":"d57cd9f723581d5d","type":"comment","z":"bbf3f0397d1bf81a","name":"Back Door Opened","info":"","x":130,"y":780,"wires":[]},{"id":"6f21de0790b72f58","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"backgardenspots off","server":"ea58b08c.075dc","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outsidetr"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":960,"wires":[[]]},{"id":"d2bd13b7b39274c1","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"Back Lights off","server":"ea58b08c.075dc","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.backlights"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":980,"y":820,"wires":[[]]},{"id":"ea8023561a293147","type":"time-range-switch","z":"bbf3f0397d1bf81a","name":"Dark Outside","lat":"51.326038","lon":"-0.621","startTime":"sunsetStart","endTime":"sunriseEnd","startOffset":"0","endOffset":"5","x":450,"y":800,"wires":[["b6157a215793b5d8","f2a6cff995119e1a"],[]]},{"id":"0bcb95f827aa50f1","type":"ha-device","z":"bbf3f0397d1bf81a","name":"Back Lights off","server":"ea58b08c.075dc","version":0,"debugenabled":false,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"inputs":0,"deviceType":"trigger","device":"36189e9885f46965b34f2dc46ed48733","event":{"platform":"device","type":"turned_off","device_id":"36189e9885f46965b34f2dc46ed48733","entity_id":"switch.backlights","domain":"switch","metadata":{"secondary":false}},"capabilities":[],"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":680,"y":960,"wires":[["6f21de0790b72f58"]]},{"id":"ba242444ff07cbf0","type":"server-state-changed","z":"bbf3f0397d1bf81a","name":"Front Door Open Trigger","server":"ea58b08c.075dc","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.door_detector_3","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":1080,"wires":[["4be3f0337476bf67"],["4be3f0337476bf67","70b0adacb3c121a4"]]},{"id":"4be3f0337476bf67","type":"time-range-switch","z":"bbf3f0397d1bf81a","name":"Dark Outside","lat":"51.326038","lon":"-0.621","startTime":"sunsetStart","endTime":"sunriseEnd","startOffset":"0","endOffset":"5","x":450,"y":1040,"wires":[["16094c67749712a4"],[]]},{"id":"16094c67749712a4","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"Porch Light on","server":"fd3238f0.cbd4e8","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":["outside"],"deviceId":["41c2011f2a61684ab56ecd02ba20ef85"],"entityId":["light.door","light.hallwaylights"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":960,"y":1080,"wires":[["2a2a030955809cc3"]]},{"id":"70b0adacb3c121a4","type":"delay","z":"bbf3f0397d1bf81a","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":1100,"wires":[["a6419a47e8597c24"]]},{"id":"a6419a47e8597c24","type":"api-call-service","z":"bbf3f0397d1bf81a","name":"Porch Light off","server":"fd3238f0.cbd4e8","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":["41c2011f2a61684ab56ecd02ba20ef85"],"entityId":["light.door"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":960,"y":1140,"wires":[[]]},{"id":"2a2a030955809cc3","type":"delay","z":"bbf3f0397d1bf81a","name":"","pauseType":"delay","timeout":"60","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1240,"y":1080,"wires":[["a6419a47e8597c24"]]},{"id":"ea58b08c.075dc","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"},{"id":"fd3238f0.cbd4e8","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
Created 3 years, 4 months ago
  • delay (x2)
  • HA
  • homeassistant
  • shelly
