Example flow used in Dashboard 2.0 Cypress E2E tests
Can be used in conjunction with this flow to check the messages being output from a node in Node-RED.
In this flow, our "Store Latest Msg" function node stores the received msg value into the global context store at global.msg. Then the Test Helper can be used in Cypress to retrieve this value to check validity of the output.
This flow, for example, provides Cypress with various instances of ui-button with which it can automate clicking/interaction and check the outputs.
[{"id":"node-red-tab-buttons","type":"tab","label":"UI Buttons","disabled":false,"info":"","env":[]},{"id":"dashboard-ui-base","type":"ui-base","name":"UI Name","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"]},{"id":"dashboard-ui-page-1","type":"ui-page","name":"Page 1","ui":"dashboard-ui-base","path":"/page1","icon":"","layout":"grid","theme":"dashboard-ui-theme","order":-1,"className":"","visible":"true","disabled":false},{"id":"dashboard-ui-theme","type":"ui-theme","name":"Theme Name","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"}},{"id":"test-helper","type":"function","z":"node-red-tab-buttons","name":"Store Latest Msg","func":"global.set('msg', msg)\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":350,"y":80,"wires":[[]]},{"id":"dashboard-ui-group","type":"ui-group","name":"Group 1","page":"dashboard-ui-page-1","width":"6","height":"1","order":-1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"dashboard-ui-button-str","type":"ui-button","z":"node-red-tab-buttons","group":"dashboard-ui-group","name":"","label":"Button 1 (str)","order":0,"width":0,"height":0,"passthru":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"button 1 clicked","payloadType":"str","topic":"button-str-topic","topicType":"str","x":100,"y":80,"wires":[["test-helper"]]},{"id":"dashboard-ui-button-json","type":"ui-button","z":"node-red-tab-buttons","group":"dashboard-ui-group","name":"","label":"Button 1 (json)","order":0,"width":0,"height":0,"passthru":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"{\"hello\": \"world\"}","payloadType":"json","topic":"button-json-topic","topicType":"str","x":120,"y":120,"wires":[["test-helper"]]}]
Created 3 years, 1 month ago
  • dashboard-2.0
  • e2e
  • cypress
  • tests
