Run-To-Waste Hydroponics Flow
This flow manages 2 lights, 3 fans & and two way valve watering system for a run to waste hydroponic system.
How To Setup Flow:
  1. Import flow into node red - google for more info
  2. Double click the "Call Service" nodes (there blue, if u cant find them search "call service" in the top left "filter nodes" search bar.
  3. you will see an option called "Server" to the right its a "pencil icon" click it once.
You Have 2 Options Here:
  1. click the checkbox that says: "I use the home assistant add-on" (not using the addon?) (here's the link if you want to: https://github.com/zachowj/hass-node-red)
Or Alternatively:
  1. Goto: http://"your.hass.os.ipAdress":8123/profile
  2. Scroll down to "Long-Lived Access Tokens"
  3. Click "Create token"
  4. Name your token anything you want and click "ok"
  5. Copy the "Token API" and paste it somewhere safe to use for later.
  6. Go back into "Node Red" Double click the "Call Service" nodes (there blue, if u cant find them search "call service" in the top left "filter nodes" search bar.
  7. you will see an option called "Server" to the right its a "pencil icon" click it once.
  8. there's an option that says "Access Token" paste that "token API" here.
  9. there's an option that says "base url" this will be:
  10. http://"your.hass.os.ipAdress":8123
  11. here's another example: http://10.0.0.0:8123 OR http://192.168.1.1:8123
  12. Restart Home Assistant
Possible Install Issues:
  1. bad base url, Solution = get rid of "/" at the end for example: "http://10.0.0.0:8123/ <-bad base url" "http://10.0.0.0:8123 <-good base url"
  2. this is the limit of my help... sorry feel free to google any more help you require.
System Requirements:
  1. 2x lights
  2. 3x fans
  3. 2x water flow valves
  4. 1x fish pump
  5. 8x smart plugs/switches
What Will This Flow Do:
  1. @ dawn turns on the lights and fans then.
  2. sends an audio notification letting you know what just happened.
  3. @ sunrise it waters plant 1 & 2 then.
  4. sends an audio notification letting you know what just happened.
  5. @ sunset it waters the plants 1 & 2 again.
  6. sends an audio notification letting you know what just happened.
  7. after a set duration, turns off the lights & fans.
  8. sends an audio notification letting you know what just happened.
  9. there's also a manual watering btn in the dashboard.
  10. you can also adjust the light and water timers from the dashboard.
Coming Soon:
  1. automatic temp & humidity control
  2. Automatic Tank refill
  3. ec dosing & calibration
  4. ph dosing & calibration
[{"id":"5ddea951.416828","type":"tab","label":"Timers","disabled":false,"info":""},{"id":"b03f9ae.86bd568","type":"bigtimer","z":"5ddea951.416828","outtopic":"","outpayload1":"on","outpayload2":"","name":"Sunrise","comment":"Best Time to water your plants","lat":"-31.952744848191998","lon":"115.86044311523439","starttime":"5003","endtime":"5003","starttime2":"0","endtime2":"0","startoff":"-1","endoff":"1","startoff2":"-1","endoff2":"1","offs":0,"outtext1":"oh. BrawndO! has what plants crave! It's got electrolytes!","outtext2":"","timeout":"1440","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":80,"y":100,"wires":[["f4fb9fb9.75667"],[],["961c17be.8391f8"]]},{"id":"f4fb9fb9.75667","type":"link out","z":"5ddea951.416828","name":"","links":["cd328a2e.e9d7f8","832f9514.ab2828","fff4f759.5df888"],"x":195,"y":160,"wires":[]},{"id":"c11f6481.d94078","type":"bigtimer","z":"5ddea951.416828","outtopic":"","outpayload1":"on","outpayload2":"","name":"Sunset","comment":"2nd Best Time to water your plants","lat":"-31.952744848191998","lon":"115.86044311523439","starttime":"5004","endtime":"5004","starttime2":"0","endtime2":"0","startoff":"-1","endoff":"1","startoff2":"0","endoff2":"0","offs":0,"outtext1":"oh. BrawndO! has what plants crave! It's got electrolytes!","outtext2":"","timeout":"1440","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":80,"y":160,"wires":[["f4fb9fb9.75667"],[],["961c17be.8391f8"]]},{"id":"da499045.12c1e","type":"ui_button","z":"5ddea951.416828","name":"Manual Water Btn-UI","group":"7ef0c7f2.6c31c8","order":0,"width":0,"height":0,"passthru":false,"label":"Manual Water","tooltip":"","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":420,"y":240,"wires":[["1d08311b.dd0d0f","f4fb9fb9.75667","ff7613cd.599ef"]]},{"id":"1d08311b.dd0d0f","type":"change","z":"5ddea951.416828","name":"disable ui btn","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":240,"wires":[["da499045.12c1e"]]},{"id":"3835cc66.1c5184","type":"link in","z":"5ddea951.416828","name":"","links":["190ed027.6ff1d","680a418b.2de2b"],"x":275,"y":240,"wires":[["da499045.12c1e"]]},{"id":"ff233b5b.818908","type":"link out","z":"5ddea951.416828","name":"","links":["caeec570.666218","394c4880.c3e4f8"],"x":215,"y":240,"wires":[]},{"id":"99a6fafa.b5e998","type":"inject","z":"5ddea951.416828","name":"Ui Btn Reset","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":110,"y":240,"wires":[["ff233b5b.818908"]]},{"id":"2d1a95d8.b053ba","type":"link out","z":"5ddea951.416828","name":"","links":["2d0c17ba.25b078","933a8e2d.3bc0c","1cd02a50.737a06","8bbe6e95.8f4cb","4f719f3.803f46","1b54a32c.80ac5d"],"x":195,"y":40,"wires":[]},{"id":"dcee3e31.c509b","type":"api-call-service","z":"5ddea951.416828","name":"Outlet Fan on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"switch.kasa_smart_plug_bd36_0","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":260,"y":80,"wires":[[]]},{"id":"9c259367.9e468","type":"api-call-service","z":"5ddea951.416828","name":"Outlet Fan off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":760,"y":300,"wires":[[]]},{"id":"960c95e0.3d0238","type":"bigtimer","z":"5ddea951.416828","outtopic":"","outpayload1":"on","outpayload2":"","name":"Dawn","comment":"Best Time to Turn lights on","lat":"-31.952744848191998","lon":"115.86044311523439","starttime":"5000","endtime":"5000","starttime2":"0","endtime2":"0","startoff":"-1","endoff":"1","startoff2":"-1","endoff2":"1","offs":0,"outtext1":"oh. Turning Knee Grow lights on!","outtext2":"","timeout":"1440","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":70,"y":40,"wires":[["dcee3e31.c509b","2d1a95d8.b053ba"],[],["961c17be.8391f8"]]},{"id":"d6d9b4dd.426b88","type":"link in","z":"5ddea951.416828","name":"","links":["f4154823.50bfb8","2501f2f7.2fb6ee"],"x":35,"y":300,"wires":[["6367417e.c6659"]]},{"id":"ecf48d4c.d8d1c","type":"link in","z":"5ddea951.416828","name":"","links":["1bf1abd1.f8dd84","2c295fa8.965bc"],"x":35,"y":340,"wires":[["a74873a4.e7754"]]},{"id":"6c8b0b0.1800bf4","type":"switch","z":"5ddea951.416828","name":"","property":"sensorA","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":300,"wires":[["374b91bf.d8583e"]]},{"id":"374b91bf.d8583e","type":"switch","z":"5ddea951.416828","name":"","property":"sensorB","propertyType":"flow","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":430,"y":300,"wires":[["61e4d1f0.25b7d"]]},{"id":"6367417e.c6659","type":"change","z":"5ddea951.416828","name":"","rules":[{"t":"set","p":"sensorA","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":300,"wires":[["6c8b0b0.1800bf4"]]},{"id":"a74873a4.e7754","type":"change","z":"5ddea951.416828","name":"","rules":[{"t":"set","p":"sensorB","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":160,"y":340,"wires":[["6c8b0b0.1800bf4"]]},{"id":"316f2701.6d4608","type":"debug","z":"5ddea951.416828","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":340,"wires":[]},{"id":"61e4d1f0.25b7d","type":"change","z":"5ddea951.416828","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Sequence completed","tot":"str"},{"t":"set","p":"sensorA","pt":"flow","to":"false","tot":"bool"},{"t":"set","p":"sensorB","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":300,"wires":[["316f2701.6d4608","9c259367.9e468"]]},{"id":"59b88f4c.46db","type":"ui_numeric","z":"5ddea951.416828","name":"water Timer Adjustment","label":"Water-Seconds","tooltip":"","group":"e561bc12.075aa","order":1,"width":0,"height":0,"wrap":true,"passthru":false,"topic":"","format":"{{msg.payload}}","min":"10","max":"1800","step":"30","x":130,"y":460,"wires":[["44532507.26827c"]]},{"id":"44532507.26827c","type":"change","z":"5ddea951.416828","name":"Flow Delay - For Function","rules":[{"t":"set","p":"delay1","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":460,"wires":[[]]},{"id":"b663c957.5a7828","type":"delay","z":"5ddea951.416828","name":"Wait Timer","pauseType":"delayv","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":590,"y":420,"wires":[["c6b55e90.72d89"]]},{"id":"d455324c.f6f92","type":"function","z":"5ddea951.416828","name":"","func":"msg.delay = flow.get('delay1') * 1000\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":420,"wires":[["b663c957.5a7828"]]},{"id":"82686bc1.3adb78","type":"api-call-service","z":"5ddea951.416828","name":"Valve 1 on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"switch.kasa_smart_plug_bd36_0","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":150,"y":420,"wires":[["95ef7697.ba0ab8"]]},{"id":"1b46a98b.44d576","type":"api-call-service","z":"5ddea951.416828","name":"Valve 1 off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"switch.kasa_smart_plug_bd36_0","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":420,"wires":[["30988e14.81ddf2"]]},{"id":"95ef7697.ba0ab8","type":"api-call-service","z":"5ddea951.416828","name":"Pump on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"switch.kasa_smart_plug_bd36_1","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":300,"y":420,"wires":[["d455324c.f6f92"]]},{"id":"c6b55e90.72d89","type":"api-call-service","z":"5ddea951.416828","name":"Pump off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"switch.kasa_smart_plug_bd36_1","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":740,"y":420,"wires":[["1b46a98b.44d576"]]},{"id":"fff4f759.5df888","type":"link in","z":"5ddea951.416828","name":"","links":["f4fb9fb9.75667"],"x":35,"y":420,"wires":[["82686bc1.3adb78"]]},{"id":"30988e14.81ddf2","type":"link out","z":"5ddea951.416828","name":"","links":["738dc65f.e37978","c3f8735b.6698c"],"x":995,"y":420,"wires":[]},{"id":"8045d67b.952a78","type":"comment","z":"5ddea951.416828","name":"Tent 1 Water","info":"","x":90,"y":380,"wires":[]},{"id":"375d7ece.9a6f02","type":"api-call-service","z":"5ddea951.416828","name":"Tent 1 Light on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":160,"y":540,"wires":[["41c67528.b529ac"]]},{"id":"dbe8d199.0ba5e","type":"api-call-service","z":"5ddea951.416828","name":"Tent 1 light off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":580,"y":540,"wires":[["1fedf4b6.9987db"]]},{"id":"c2d7ac5d.02131","type":"function","z":"5ddea951.416828","name":"","func":"msg.delay = flow.get('delay2') * 1000\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":580,"wires":[["10e8ac14.9ed244"]]},{"id":"10e8ac14.9ed244","type":"delay","z":"5ddea951.416828","name":"Wait Timer","pauseType":"delayv","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":690,"y":580,"wires":[["dbe8d199.0ba5e"]]},{"id":"2b7f81f3.5651be","type":"ui_numeric","z":"5ddea951.416828","name":"Light Timer Adjustment","label":"Hours Of Light","tooltip":"","group":"e561bc12.075aa","order":1,"width":0,"height":0,"wrap":true,"passthru":false,"topic":"","format":"{{msg.payload}}","min":"12","max":"18","step":"6","x":120,"y":580,"wires":[["d6ca7dda.e3d17"]]},{"id":"d6ca7dda.e3d17","type":"change","z":"5ddea951.416828","name":"Flow Delay - For Function","rules":[{"t":"set","p":"delay2","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":580,"wires":[[]]},{"id":"4f719f3.803f46","type":"link in","z":"5ddea951.416828","name":"","links":["2d1a95d8.b053ba"],"x":35,"y":540,"wires":[["375d7ece.9a6f02"]]},{"id":"41c67528.b529ac","type":"api-call-service","z":"5ddea951.416828","name":"Tent 1 Inlet Fan on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":350,"y":540,"wires":[["c2d7ac5d.02131"]]},{"id":"1fedf4b6.9987db","type":"api-call-service","z":"5ddea951.416828","name":"Tent 1 Inlet Fan off","server":"4a73486b.14a158","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":770,"y":540,"wires":[["2501f2f7.2fb6ee"]]},{"id":"2501f2f7.2fb6ee","type":"link out","z":"5ddea951.416828","name":"","links":["cd1bf35c.d8677","d6d9b4dd.426b88"],"x":895,"y":540,"wires":[]},{"id":"9487e94b.12bf98","type":"comment","z":"5ddea951.416828","name":"Tent 1 Light/Fan","info":"","x":100,"y":500,"wires":[]},{"id":"e258f451.812bb8","type":"comment","z":"5ddea951.416828","name":"Tent 2 Water","info":"","x":90,"y":620,"wires":[]},{"id":"4fbe9b91.98cbc4","type":"ui_numeric","z":"5ddea951.416828","name":"Water Timer Adjustments","label":"Water-Seconds","tooltip":"","group":"e5f48f81.46069","order":1,"width":0,"height":0,"wrap":true,"passthru":false,"topic":"","format":"{{msg.payload}}","min":"10","max":"1800","step":"30","x":130,"y":700,"wires":[["dc6eedfb.0a36b"]]},{"id":"dc6eedfb.0a36b","type":"change","z":"5ddea951.416828","name":"Flow Delay - For Function","rules":[{"t":"set","p":"delay3","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":700,"wires":[[]]},{"id":"c4ce18ae.778018","type":"api-call-service","z":"5ddea951.416828","name":"Pump on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"switch.kasa_smart_plug_bd36_1","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":300,"y":660,"wires":[["a76482b1.64803"]]},{"id":"5e2f828d.c0c7ec","type":"api-call-service","z":"5ddea951.416828","name":"Pump off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"switch.kasa_smart_plug_bd36_1","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":740,"y":660,"wires":[["36e88143.78dc7e"]]},{"id":"c990aaa7.196b18","type":"api-call-service","z":"5ddea951.416828","name":"Valve 2 on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"switch.kasa_smart_plug_bd36_2","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":150,"y":660,"wires":[["c4ce18ae.778018"]]},{"id":"36e88143.78dc7e","type":"api-call-service","z":"5ddea951.416828","name":"Valve 2 off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"switch.kasa_smart_plug_bd36_2","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":660,"wires":[["6eb89214.d9ea6c"]]},{"id":"c9098e6d.1aaae","type":"delay","z":"5ddea951.416828","name":"Wait Timer","pauseType":"delayv","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":590,"y":660,"wires":[["5e2f828d.c0c7ec"]]},{"id":"a76482b1.64803","type":"function","z":"5ddea951.416828","name":"","func":"msg.delay = flow.get('delay3') * 1000\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":660,"wires":[["c9098e6d.1aaae"]]},{"id":"c3f8735b.6698c","type":"link in","z":"5ddea951.416828","name":"","links":["743d2be1.f92124","30988e14.81ddf2"],"x":35,"y":660,"wires":[["c990aaa7.196b18"]]},{"id":"6eb89214.d9ea6c","type":"change","z":"5ddea951.416828","name":"Re Enable ui btn","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":700,"wires":[["680a418b.2de2b"]]},{"id":"680a418b.2de2b","type":"link out","z":"5ddea951.416828","name":"","links":["60378d53.193734","3835cc66.1c5184"],"x":955,"y":700,"wires":[]},{"id":"394c4880.c3e4f8","type":"link in","z":"5ddea951.416828","name":"","links":["b76e7f7d.6f6a5","ff233b5b.818908"],"x":675,"y":700,"wires":[["6eb89214.d9ea6c"]]},{"id":"7b614127.b997c","type":"comment","z":"5ddea951.416828","name":"Tent 2 Light/Fan","info":"","x":100,"y":740,"wires":[]},{"id":"2e7545cb.3cd08a","type":"api-call-service","z":"5ddea951.416828","name":"Tent 2 Light on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":160,"y":780,"wires":[["75a98fbf.32fa5"]]},{"id":"a03362cd.5a4b6","type":"api-call-service","z":"5ddea951.416828","name":"Tent 2 Inlet Fan off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_off","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":830,"y":820,"wires":[["2c295fa8.965bc"]]},{"id":"d6a952b2.07bc2","type":"function","z":"5ddea951.416828","name":"","func":"msg.delay = flow.get('delay4') * 1000\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":520,"y":780,"wires":[["83d9edeb.03f3e"]]},{"id":"83d9edeb.03f3e","type":"delay","z":"5ddea951.416828","name":"Wait Timer","pauseType":"delayv","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":670,"y":780,"wires":[["a68a8532.eecdf8"]]},{"id":"3f33ccd5.477e54","type":"ui_numeric","z":"5ddea951.416828","name":"Light Timer Adjustment","label":"Hours Of Light","tooltip":"","group":"e5f48f81.46069","order":1,"width":0,"height":0,"wrap":true,"passthru":false,"topic":"","format":"{{msg.payload}}","min":"12","max":"18","step":"6","x":360,"y":820,"wires":[["b1a9281a.d50588"]]},{"id":"b1a9281a.d50588","type":"change","z":"5ddea951.416828","name":"Flow Delay - For Function","rules":[{"t":"set","p":"delay4","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":820,"wires":[[]]},{"id":"1b54a32c.80ac5d","type":"link in","z":"5ddea951.416828","name":"","links":["2d1a95d8.b053ba"],"x":35,"y":780,"wires":[["2e7545cb.3cd08a"]]},{"id":"75a98fbf.32fa5","type":"api-call-service","z":"5ddea951.416828","name":"Tent 2 Inlet Fan on","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":350,"y":780,"wires":[["d6a952b2.07bc2"]]},{"id":"a68a8532.eecdf8","type":"api-call-service","z":"5ddea951.416828","name":"Tent 2 Light off","server":"4a73486b.14a158","version":1,"debugenabled":true,"service_domain":"switch","service":"turn_on","entityId":"","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":840,"y":780,"wires":[["a03362cd.5a4b6"]]},{"id":"2c295fa8.965bc","type":"link out","z":"5ddea951.416828","name":"","links":["3ffccbc2.913694","ecf48d4c.d8d1c"],"x":955,"y":820,"wires":[]},{"id":"961c17be.8391f8","type":"ui_audio","z":"5ddea951.416828","name":"","group":"7ef0c7f2.6c31c8","voice":"Google UK English Male","always":true,"x":240,"y":120,"wires":[]},{"id":"ff7613cd.599ef","type":"change","z":"5ddea951.416828","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"oh. BrawndO! has what plants crave! It's got electrolytes!","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":200,"wires":[["961c17be.8391f8"]]},{"id":"e88d7691.7fee48","type":"inject","z":"5ddea951.416828","name":"on","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":90,"y":200,"wires":[["f4fb9fb9.75667","ff7613cd.599ef"]]},{"id":"7ef0c7f2.6c31c8","type":"ui_group","name":"Manual Water Btn","tab":"4933fd87.3254d4","order":1,"disp":false,"width":"6","collapse":false},{"id":"4a73486b.14a158","type":"server","name":"Home Assistant Server1","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"e561bc12.075aa","type":"ui_group","name":"Tent 1","tab":"4933fd87.3254d4","order":2,"disp":false,"width":"6","collapse":false},{"id":"e5f48f81.46069","type":"ui_group","name":"Tent 2","tab":"4933fd87.3254d4","order":3,"disp":false,"width":"6","collapse":false},{"id":"4933fd87.3254d4","type":"ui_tab","name":"Hydroponics System Controls","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Created 5 years, 9 months ago
Rating: 5 1
  • change (x10)
  • comment (x4)
  • delay (x4)
  • function (x4)
  • inject (x2)
  • link in (x8)
  • link out (x7)
  • switch (x2)
  • lights
  • irragation
  • fan
  • hydroponics
  • run-to-waste
  • environment
