Telegram container flow
My container flow for Node-Red with Telegram and Home Assistant.
[{"id":"39baa218.c4d536","type":"telegram command","z":"2fc90dbf.fe8da2","name":"","command":"/container@bot","bot":"","strict":false,"hasresponse":true,"x":80,"y":360,"wires":[["4097a26.8cb785c","401211a5.735ce8","3bd16e6b.af89e2"],[]]},{"id":"4097a26.8cb785c","type":"api-current-state","z":"2fc90dbf.fe8da2","name":"Haal datum GFT op","server":"","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"sensor.afvalinfo_gft","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":450,"y":300,"wires":[["4b850ce4.621cc4"]]},{"id":"401211a5.735ce8","type":"api-current-state","z":"2fc90dbf.fe8da2","name":"Haal datum papier op","server":"","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.afvalinfo_papier","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":460,"y":360,"wires":[["aaefdb58.bd3c2"]]},{"id":"3bd16e6b.af89e2","type":"api-current-state","z":"2fc90dbf.fe8da2","name":"Haal datum plastic op","server":"","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"sensor.afvalinfo_pbd","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":460,"y":420,"wires":[["8f824bbf.52ac1"]]},{"id":"b00fac2f.99b368","type":"join","z":"2fc90dbf.fe8da2","name":"Voeg samen","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":890,"y":360,"wires":[["9861f5ba.a77ea8"]]},{"id":"4b850ce4.621cc4","type":"function","z":"2fc90dbf.fe8da2","name":"Geef label mee","func":"msg.topic = \"gft\"\nreturn msg;","outputs":1,"noerr":0,"x":680,"y":300,"wires":[["b00fac2f.99b368"]]},{"id":"aaefdb58.bd3c2","type":"function","z":"2fc90dbf.fe8da2","name":"Geef label mee","func":"msg.topic = \"papier\"\nreturn msg;","outputs":1,"noerr":0,"x":680,"y":360,"wires":[["b00fac2f.99b368"]]},{"id":"8f824bbf.52ac1","type":"function","z":"2fc90dbf.fe8da2","name":"Geef label mee","func":"msg.topic = \"pbd\"\nreturn msg;","outputs":1,"noerr":0,"x":680,"y":420,"wires":[["b00fac2f.99b368"]]},{"id":"9861f5ba.a77ea8","type":"function","z":"2fc90dbf.fe8da2","name":"Maak telegram","func":"msg.payload = {\n    chatId : 0,\n    type : 'message',\n    content : '*Container!*\\r\\nGFT: '+msg.payload.gft+'\\r\\nPapier: '+msg.payload.papier+'\\r\\nPlastic: '+msg.payload.pbd+''\n}\nmsg.payload.options = {parse_mode : \"Markdown\"};\nreturn msg;","outputs":1,"noerr":0,"x":1060,"y":360,"wires":[["3ed977b3.ace45"]]},{"id":"3ed977b3.ace45","type":"telegram sender","z":"2fc90dbf.fe8da2","name":"Verstuur Telegram","bot":"","x":1250,"y":360,"wires":[[]]},{"id":"750a356e.149d04","type":"telegram command","z":"2fc90dbf.fe8da2","name":"","command":"/container","bot":"","strict":false,"hasresponse":true,"x":60,"y":400,"wires":[["4097a26.8cb785c","401211a5.735ce8","3bd16e6b.af89e2"],[]]}]
Created 5 years, 5 months ago
  • function (x4)
  • join (x1)
