Jsonata functions in change and switch nodes
image of the flow
JSONata, when used in Change and Switch nodes, offers several advantages over the Function node:
Simplicity and Readability: JSONata expressions are concise and easy to read. They allow you to perform complex operations without writing custom JavaScript code. If your logic involves simple transformations or filtering, JSONata can simplify your flow.
No JavaScript Knowledge Required:
JSONata doesn’t require knowledge of JavaScript. You can achieve powerful data manipulation without writing any code. This is especially helpful for users who are not comfortable with programming.
Built-In Functions:
JSONata provides built-in functions for common tasks (e.g., filtering, mapping, averaging). You can leverage these functions directly within your flow. No need to reinvent the wheel by writing custom functions.
Performance and Efficiency:
JSONata expressions are optimized for performance. They execute faster than custom JavaScript code in many cases. If your flow processes large amounts of data, JSONata can be more efficient.
Visual Flow Design:
Using JSONata in Change and Switch nodes keeps your flow visually clean. You can see the data transformations directly in the flow editor. This improves maintainability and collaboration.
Avoiding Errors:
JSONata expressions are less error-prone than writing custom JavaScript. They handle edge cases and type conversions automatically. This reduces the risk of bugs and unexpected behavior.
However, there are scenarios where the Function node is more suitable, such as complex custom logic or interactions with external APIs. Consider using JSONata when it aligns with your specific use case and simplifies your flow. 😊
[{"id":"d453483289da3934","type":"tab","label":"Jsonata functions in change and switch nodes","disabled":false,"info":"","env":[]},{"id":"f2a5f22d3fc8e171","type":"group","z":"d453483289da3934","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["change-node","a0f8bd27aac2ab8a","0c2ddce5c5bec030","03715a5fae318ffe","bf798eb98f122a93","5aa8115ebbedd66d","c226939519be562e","a76a8b003e253c84","e7a5993c5c0aecb4","610be256bb817d5f","6ac2859594cb5482","da88afb97d5c7f7d","2a1ff35dd73a8810","9c09566edc0646dc","ceeb403b70eac57f","c50c8f8f65696498","89e4b93d632dddd4","e447ee0532d47111","56569a7ed642eb54","2899ed44efd448e4","28126c67f43c60ff","6a7b96a46a63fec2","bdf9b2d7d699863d","09d62714d850951a","ec2929307bba8085","073e19198072986f","271dffd3d2f19d5e","cf9a8ef6bbb8765d"],"x":14,"y":327,"w":912,"h":654},{"id":"c9926a80df8df90a","type":"group","z":"d453483289da3934","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["switch-node","output-node","2a6d0edb9e05ec00","7b481c16a5d92aa1","0204ed8e08489563","01d3acf629e0f155","e3044e9589a9c926","69d89f0d0dfb04d2"],"x":14,"y":39,"w":872,"h":282},{"id":"a1644ae16bfbf881","type":"group","z":"d453483289da3934","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["67c89b2e70efd5b8","6cc6c82391a57ac8","c36980a8e61d5ee2","b615853f8c276cc0","cc906e310cb2264d","78ecf335e4828eab","4b0461924b6a5264","fbf27dd6c9c0a3e4","359964d1ce8c8dce","cbb91d9e1dec6d2c","3abcc579974ab059","1baa0b8bce318912","a69aabf1375cf258","1de29715d0faccc7","ae2c4602234dc770","aa772dcfbfe98818","bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9","1c16cb7c9977363d","dad51de4ba248c5a","a34b06ad45edc041","12ca6ddac16dc230","92d8cbc5b4795233","241a936b1121990d"],"x":14,"y":1411,"w":812,"h":590},{"id":"e18160b41608a380","type":"group","z":"d453483289da3934","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["9014dd5742bc38ec","72ce328b79c96871","9c810afb99ec5daa","156e91bc329a9d05","9f83166b65f56826","c8a8c4743a7256bd","4e96b6c7c72e412e","9bbb0cf10dea8979","978bb02f2c9733b2","ac61977b2aab7e5c","3b1b2a86942b5f39","6bb0aa214594e7d3","8ffe086c815e7074","1e1d68fdcb7f725e","ea8cd1a5c876d3c3","5f9b8b559e77c869","4662878b388dc582"],"x":14,"y":1019,"w":752,"h":342},{"id":"fc7da1fa95073336","type":"group","z":"d453483289da3934","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["e8d75a2afe2f6455","35ba9740985e6653","1e41c67f74d54493","9cfaca4b599bc886","1ad3d8133cee5f6c","4c9acbc2901cadc4","67ca45923a15c469","f822462cbea4a952","c30e91c4e7a69e15","11ecaa44960bde1a","c96e55ec02939974","5294a71762afe834","ab50555de72a6914","99265c6da8aa3a3c","40dd75432855f288","391d8042ff1aee49","cf5c65cd09679dc6","68c08e2dd63551b2","fb2914f1f0935669","cf34ba49e1cb916e","1e441f3ea85dc380","2988441467eda07b","37e70723eecbdff7","06892b9c2a149aad","267d42b98c233bc3","66342c2d020661db","5a82aaa74c5bfca9","31c315b845ceaa53","856ad5d0dbd9ddd3","6921ab136857f13f","dc89d043a81a9c7e","1dad9b01f3d638af"],"x":14,"y":2011,"w":1132,"h":1470},{"id":"switch-node","type":"switch","z":"d453483289da3934","g":"c9926a80df8df90a","name":"Compare Payloads","property":"payload1","propertyType":"msg","rules":[{"t":"jsonata_exp","v":"payload1 = payload2","vt":"jsonata"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":180,"wires":[["output-node"],["7b481c16a5d92aa1"]]},{"id":"output-node","type":"debug","z":"d453483289da3934","g":"c9926a80df8df90a","name":"payload equal","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":760,"y":160,"wires":[]},{"id":"change-node","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"(payload - 32) / 1.8","rules":[{"t":"set","p":"payload","pt":"msg","to":"(payload - 32) / 1.8","tot":"jsonata"}],"x":390,"y":480,"wires":[["2a1ff35dd73a8810"]]},{"id":"a0f8bd27aac2ab8a","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"Debug Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":700,"y":480,"wires":[]},{"id":"0c2ddce5c5bec030","type":"inject","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"53","payloadType":"num","x":110,"y":480,"wires":[["c50c8f8f65696498"]]},{"id":"2a6d0edb9e05ec00","type":"inject","z":"d453483289da3934","g":"c9926a80df8df90a","name":"inject number payload1 = 400 and payload2 = 401","props":[{"p":"payload1","v":"400","vt":"num"},{"p":"payload2","v":"401","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":160,"wires":[["switch-node"]]},{"id":"03715a5fae318ffe","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"$round((payload - 32) / 1.8, 2)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$round((payload - 32) / 1.8, 2)","tot":"jsonata"}],"x":450,"y":820,"wires":[["2899ed44efd448e4"]]},{"id":"bf798eb98f122a93","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"Debug Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":800,"y":820,"wires":[]},{"id":"5aa8115ebbedd66d","type":"inject","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"53","payloadType":"num","x":110,"y":820,"wires":[["da88afb97d5c7f7d"]]},{"id":"7b481c16a5d92aa1","type":"debug","z":"d453483289da3934","g":"c9926a80df8df90a","name":"not equal","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":740,"y":200,"wires":[]},{"id":"0204ed8e08489563","type":"inject","z":"d453483289da3934","g":"c9926a80df8df90a","name":"inject number payload1 = 400 and payload2 = 401","props":[{"p":"payload1","v":"401","vt":"num"},{"p":"payload2","v":"401","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":200,"wires":[["switch-node"]]},{"id":"c226939519be562e","type":"function","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"function 30","func":"let payload = msg.payload;\nmsg.temp_f = (payload - 32) / 1.8;\nmsg.payload = msg.temp_f;\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":620,"wires":[["89e4b93d632dddd4"]]},{"id":"a76a8b003e253c84","type":"inject","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"53","payloadType":"num","x":110,"y":620,"wires":[["9c09566edc0646dc"]]},{"id":"e7a5993c5c0aecb4","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"time","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"time","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":620,"wires":[]},{"id":"610be256bb817d5f","type":"function","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"function 31","func":"let payload = msg.payload;\nmsg.temp_f = (payload - 32) / 1.8;\nmsg.payload = msg.temp_f.toFixed(2);\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":940,"wires":[["ec2929307bba8085"]]},{"id":"6ac2859594cb5482","type":"inject","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"53","payloadType":"num","x":110,"y":940,"wires":[["ceeb403b70eac57f"]]},{"id":"da88afb97d5c7f7d","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"start","rules":[{"t":"set","p":"start","pt":"msg","to":"$millis()","tot":"jsonata"}],"x":250,"y":820,"wires":[["03715a5fae318ffe"]]},{"id":"2a1ff35dd73a8810","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"end","rules":[{"t":"set","p":"end","pt":"msg","to":"$millis()","tot":"jsonata"},{"t":"set","p":"time","pt":"msg","to":"$abs(end - start)","tot":"jsonata"}],"x":550,"y":480,"wires":[["a0f8bd27aac2ab8a"]]},{"id":"9c09566edc0646dc","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"start","rules":[{"t":"set","p":"start","pt":"msg","to":"$millis()","tot":"jsonata"}],"x":250,"y":620,"wires":[["c226939519be562e"]]},{"id":"ceeb403b70eac57f","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"start","rules":[{"t":"set","p":"start","pt":"msg","to":"$millis()","tot":"jsonata"}],"x":230,"y":940,"wires":[["610be256bb817d5f"]]},{"id":"c50c8f8f65696498","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"start","rules":[{"t":"set","p":"start","pt":"msg","to":"$millis()","tot":"jsonata"}],"x":230,"y":480,"wires":[["change-node"]]},{"id":"89e4b93d632dddd4","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"end","rules":[{"t":"set","p":"end","pt":"msg","to":"$millis()","tot":"jsonata"},{"t":"set","p":"time","pt":"msg","to":"$abs(end - start)","tot":"jsonata"}],"x":550,"y":620,"wires":[["e7a5993c5c0aecb4","e447ee0532d47111","56569a7ed642eb54","cf9a8ef6bbb8765d"]]},{"id":"e447ee0532d47111","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"start","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"start","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":660,"wires":[]},{"id":"56569a7ed642eb54","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"end","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"end","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":700,"wires":[]},{"id":"2899ed44efd448e4","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"end","rules":[{"t":"set","p":"end","pt":"msg","to":"$millis()","tot":"jsonata"},{"t":"set","p":"time","pt":"msg","to":"$abs(end - start)","tot":"jsonata"}],"x":650,"y":820,"wires":[["bf798eb98f122a93"]]},{"id":"28126c67f43c60ff","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"Debug Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":700,"y":940,"wires":[]},{"id":"6a7b96a46a63fec2","type":"comment","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"Farenheit to Celcius conversion\\n and measure execution time in milliseconds. ","info":"","x":210,"y":380,"wires":[]},{"id":"bdf9b2d7d699863d","type":"comment","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"With Jsonata  round the result using two decimals","info":"","x":240,"y":760,"wires":[]},{"id":"09d62714d850951a","type":"comment","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"With a function node, round the results using two decimals","info":"","x":270,"y":880,"wires":[]},{"id":"ec2929307bba8085","type":"change","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"end","rules":[{"t":"set","p":"end","pt":"msg","to":"$millis()","tot":"jsonata"},{"t":"set","p":"time","pt":"msg","to":"$abs(end - start)","tot":"jsonata"}],"x":530,"y":940,"wires":[["28126c67f43c60ff"]]},{"id":"01d3acf629e0f155","type":"comment","z":"d453483289da3934","g":"c9926a80df8df90a","name":"Compare two payloads using jsonata in switch node","info":"","x":230,"y":80,"wires":[]},{"id":"073e19198072986f","type":"comment","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"With Jsonata","info":"","x":130,"y":440,"wires":[]},{"id":"271dffd3d2f19d5e","type":"comment","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"With a function node","info":"","x":150,"y":560,"wires":[]},{"id":"e3044e9589a9c926","type":"inject","z":"d453483289da3934","g":"c9926a80df8df90a","name":"inject string payload1 = abcd and payload2 = abcde","props":[{"p":"payload1","v":"abcd","vt":"str"},{"p":"payload2","v":"abcde","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":240,"wires":[["switch-node"]]},{"id":"69d89f0d0dfb04d2","type":"inject","z":"d453483289da3934","g":"c9926a80df8df90a","name":"inject string payload1 = ab cd and payload2 = ab cd","props":[{"p":"payload1","v":"ab cd","vt":"str"},{"p":"payload2","v":"ab cd","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":280,"wires":[["switch-node"]]},{"id":"cf9a8ef6bbb8765d","type":"debug","z":"d453483289da3934","g":"f2a5f22d3fc8e171","name":"deg C","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":580,"wires":[]},{"id":"9014dd5742bc38ec","type":"change","z":"d453483289da3934","g":"e18160b41608a380","name":"$average(example)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$average(example)","tot":"jsonata"}],"x":470,"y":1120,"wires":[["9c810afb99ec5daa"]]},{"id":"72ce328b79c96871","type":"inject","z":"d453483289da3934","g":"e18160b41608a380","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1120,"wires":[["156e91bc329a9d05"]]},{"id":"9c810afb99ec5daa","type":"debug","z":"d453483289da3934","g":"e18160b41608a380","name":"debug 572","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1120,"wires":[]},{"id":"156e91bc329a9d05","type":"template","z":"d453483289da3934","g":"e18160b41608a380","name":"array [4, 7, 13]","field":"example","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[4, 7, 13]","output":"json","x":280,"y":1120,"wires":[["9014dd5742bc38ec"]]},{"id":"9f83166b65f56826","type":"change","z":"d453483289da3934","g":"e18160b41608a380","name":"$min(example)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$min(example)","tot":"jsonata"}],"x":460,"y":1200,"wires":[["4e96b6c7c72e412e"]]},{"id":"c8a8c4743a7256bd","type":"inject","z":"d453483289da3934","g":"e18160b41608a380","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1200,"wires":[["9bbb0cf10dea8979"]]},{"id":"4e96b6c7c72e412e","type":"debug","z":"d453483289da3934","g":"e18160b41608a380","name":"debug 573","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1200,"wires":[]},{"id":"9bbb0cf10dea8979","type":"template","z":"d453483289da3934","g":"e18160b41608a380","name":"array [4, 7, 13]","field":"example","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[4, 7, 13]","output":"json","x":280,"y":1200,"wires":[["9f83166b65f56826"]]},{"id":"978bb02f2c9733b2","type":"change","z":"d453483289da3934","g":"e18160b41608a380","name":"$max(example)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$max(example)","tot":"jsonata"}],"x":460,"y":1260,"wires":[["3b1b2a86942b5f39"]]},{"id":"ac61977b2aab7e5c","type":"inject","z":"d453483289da3934","g":"e18160b41608a380","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1260,"wires":[["6bb0aa214594e7d3"]]},{"id":"3b1b2a86942b5f39","type":"debug","z":"d453483289da3934","g":"e18160b41608a380","name":"debug 574","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1260,"wires":[]},{"id":"6bb0aa214594e7d3","type":"template","z":"d453483289da3934","g":"e18160b41608a380","name":"array [4, 7, 13]","field":"example","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[4, 7, 13]","output":"json","x":280,"y":1260,"wires":[["978bb02f2c9733b2"]]},{"id":"8ffe086c815e7074","type":"change","z":"d453483289da3934","g":"e18160b41608a380","name":"$sum(example)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(example)","tot":"jsonata"}],"x":460,"y":1320,"wires":[["ea8cd1a5c876d3c3"]]},{"id":"1e1d68fdcb7f725e","type":"inject","z":"d453483289da3934","g":"e18160b41608a380","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1320,"wires":[["5f9b8b559e77c869"]]},{"id":"ea8cd1a5c876d3c3","type":"debug","z":"d453483289da3934","g":"e18160b41608a380","name":"debug 575","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":1320,"wires":[]},{"id":"5f9b8b559e77c869","type":"template","z":"d453483289da3934","g":"e18160b41608a380","name":"array [4, 7, 13]","field":"example","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[4, 7, 13]","output":"json","x":280,"y":1320,"wires":[["8ffe086c815e7074"]]},{"id":"67c89b2e70efd5b8","type":"comment","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"Boolean Casting\\n The $boolean() function casts an argument to a Boolean using specific rules:\\n - true remains unchanged.\\n - An empty string (\"\") evaluates to false.\\n  - A non-empty string evaluates to true.\\n - Numeric 0 evaluates to false, and any non-zero number evaluates to true.\\n - An array evaluates to true if it contains at least one truthy value. \\n - An empty array evaluates to false. \\n - An object evaluates to true if it is non-empty. \\n - A function evaluates to false","info":"","x":310,"y":1560,"wires":[]},{"id":"4662878b388dc582","type":"comment","z":"d453483289da3934","g":"e18160b41608a380","name":"Jsonat aggregation functions","info":"","x":160,"y":1060,"wires":[]},{"id":"6cc6c82391a57ac8","type":"change","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"$boolean(myValue)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$boolean(myValue)","tot":"jsonata"}],"x":530,"y":1720,"wires":[["359964d1ce8c8dce"]]},{"id":"c36980a8e61d5ee2","type":"change","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"$not(myValue)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$not(myValue)","tot":"jsonata"}],"x":520,"y":1780,"wires":[["1de29715d0faccc7"]]},{"id":"b615853f8c276cc0","type":"change","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"$exists(myValue)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$exists(myValue)","tot":"jsonata"}],"x":530,"y":1840,"wires":[["ae2c4602234dc770"]]},{"id":"cc906e310cb2264d","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"empty string","props":[{"p":"myValue","v":"","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":1720,"wires":[["aa772dcfbfe98818"]]},{"id":"78ecf335e4828eab","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"has a value","props":[{"p":"myValue","v":"has a value","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":1760,"wires":[["1c16cb7c9977363d"]]},{"id":"4b0461924b6a5264","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"[1,0,0,0,2]","props":[{"p":"myValue","v":"[1,0,0,0,2]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":1840,"wires":[["a34b06ad45edc041"]]},{"id":"fbf27dd6c9c0a3e4","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"[]","props":[{"p":"myValue","v":"[]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":1880,"wires":[["12ca6ddac16dc230"]]},{"id":"359964d1ce8c8dce","type":"debug","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"debug 576","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":1720,"wires":[]},{"id":"cbb91d9e1dec6d2c","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"object","props":[{"p":"myValue","v":"{   \"name\": \"John Doe\",   \"age\": 30,   \"city\": \"New York\" }","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":1920,"wires":[["92d8cbc5b4795233"]]},{"id":"3abcc579974ab059","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"a function","props":[{"p":"myValue","v":"","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":1960,"wires":[["a69aabf1375cf258"]]},{"id":"1baa0b8bce318912","type":"inject","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"0","props":[{"p":"myValue","v":"0","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":1800,"wires":[["dad51de4ba248c5a"]]},{"id":"a69aabf1375cf258","type":"function","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"function","func":"msg.myValue = function test() { return; }\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":1960,"wires":[["241a936b1121990d"]]},{"id":"1de29715d0faccc7","type":"debug","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"debug 577","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":1780,"wires":[]},{"id":"ae2c4602234dc770","type":"debug","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"debug 578","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":1840,"wires":[]},{"id":"aa772dcfbfe98818","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 347","mode":"link","links":["bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9"],"x":245,"y":1720,"wires":[]},{"id":"bcf20b234e44acbf","type":"link in","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link in 287","links":["aa772dcfbfe98818","1c16cb7c9977363d","dad51de4ba248c5a","a34b06ad45edc041","12ca6ddac16dc230","92d8cbc5b4795233","241a936b1121990d"],"x":405,"y":1720,"wires":[["6cc6c82391a57ac8"]]},{"id":"8da5fd7a2f916bc0","type":"link in","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link in 288","links":["aa772dcfbfe98818","1c16cb7c9977363d","dad51de4ba248c5a","a34b06ad45edc041","12ca6ddac16dc230","92d8cbc5b4795233","241a936b1121990d"],"x":405,"y":1780,"wires":[["c36980a8e61d5ee2"]]},{"id":"d60a120cc36142d9","type":"link in","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link in 289","links":["aa772dcfbfe98818","1c16cb7c9977363d","dad51de4ba248c5a","a34b06ad45edc041","12ca6ddac16dc230","92d8cbc5b4795233","241a936b1121990d"],"x":405,"y":1840,"wires":[["b615853f8c276cc0"]]},{"id":"1c16cb7c9977363d","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 348","mode":"link","links":["bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9"],"x":245,"y":1760,"wires":[]},{"id":"dad51de4ba248c5a","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 349","mode":"link","links":["bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9"],"x":205,"y":1800,"wires":[]},{"id":"a34b06ad45edc041","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 350","mode":"link","links":["d60a120cc36142d9","8da5fd7a2f916bc0","bcf20b234e44acbf"],"x":235,"y":1840,"wires":[]},{"id":"12ca6ddac16dc230","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 351","mode":"link","links":["bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9"],"x":205,"y":1880,"wires":[]},{"id":"92d8cbc5b4795233","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 352","mode":"link","links":["bcf20b234e44acbf","8da5fd7a2f916bc0","d60a120cc36142d9"],"x":215,"y":1920,"wires":[]},{"id":"241a936b1121990d","type":"link out","z":"d453483289da3934","g":"a1644ae16bfbf881","name":"link out 353","mode":"link","links":["d60a120cc36142d9","8da5fd7a2f916bc0","bcf20b234e44acbf"],"x":375,"y":1960,"wires":[]},{"id":"e8d75a2afe2f6455","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$keys():\\n - Signature: $keys(object)\\n - Returns an array containing the keys in the object.\\n - If the argument is an array of objects, the returned array\\n contains a de-duplicated list of all the keys in all the objects.","info":"","x":250,"y":2100,"wires":[]},{"id":"35ba9740985e6653","type":"inject","z":"d453483289da3934","g":"fc7da1fa95073336","name":"{ \"name\": \"John\", \"age\": 30 }","props":[{"p":"myObject","v":"{ \"name\": \"John\", \"age\": 30 }","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":620,"y":2060,"wires":[["1ad3d8133cee5f6c"]]},{"id":"1e41c67f74d54493","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$keys(myObject)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$keys(myObject)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":2120,"wires":[["9cfaca4b599bc886"]]},{"id":"9cfaca4b599bc886","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"keys","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":2120,"wires":[]},{"id":"1ad3d8133cee5f6c","type":"link out","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link out 354","mode":"link","links":["4c9acbc2901cadc4","11ecaa44960bde1a","99265c6da8aa3a3c","68c08e2dd63551b2","b780861c05c8f4bb"],"x":775,"y":2060,"wires":[]},{"id":"4c9acbc2901cadc4","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 290","links":["1ad3d8133cee5f6c"],"x":505,"y":2120,"wires":[["1e41c67f74d54493"]]},{"id":"67ca45923a15c469","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$lookup():\\n - Signature: $lookup(object, key)\\n - Returns the value associated with the specified key in the object.\\n - If the first argument is an array of objects,\\n it searches all objects and returns values associated with occurrences of the key.","info":"","x":320,"y":2300,"wires":[]},{"id":"f822462cbea4a952","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$lookup(myObject, \"age\")","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lookup(myObject, \"age\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":2300,"wires":[["c30e91c4e7a69e15"]]},{"id":"c30e91c4e7a69e15","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"lookup","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":2300,"wires":[]},{"id":"11ecaa44960bde1a","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 291","links":["b8afdd753f773b75","1ad3d8133cee5f6c"],"x":625,"y":2300,"wires":[["f822462cbea4a952"]]},{"id":"c96e55ec02939974","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$spread():\\n - Signature: $spread(object)\\n - Splits an object containing key/value pairs into an array of objects,\\n each with a single key/value pair from the input object.\\n - If the parameter is an array of objects, the resultant array contains\\n an object for every key/value pair in every object in the supplied array.","info":"","x":290,"y":2540,"wires":[]},{"id":"5294a71762afe834","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$spread(myObject)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$spread(myObject)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":2540,"wires":[["ab50555de72a6914"]]},{"id":"ab50555de72a6914","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"spread","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":2540,"wires":[]},{"id":"99265c6da8aa3a3c","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 292","links":["b8afdd753f773b75","1ad3d8133cee5f6c"],"x":585,"y":2540,"wires":[["5294a71762afe834"]]},{"id":"40dd75432855f288","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$merge():\\n - Signature: $merge(array<object>)\\n - Merges an array of objects into a single object containing\\n all key/value pairs from each object in the input array.\\n - If any input objects contain the same key, the returned object\\n will contain the value of the last occurrence in the array.","info":"","x":260,"y":2720,"wires":[]},{"id":"391d8042ff1aee49","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$merge(myObject)","rules":[{"t":"set","p":"payload","pt":"msg","to":"$merge(myObject)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":2740,"wires":[["cf5c65cd09679dc6"]]},{"id":"cf5c65cd09679dc6","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"merge","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":2740,"wires":[]},{"id":"68c08e2dd63551b2","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 293","links":["b8afdd753f773b75","1ad3d8133cee5f6c","cf34ba49e1cb916e"],"x":585,"y":2740,"wires":[["391d8042ff1aee49"]]},{"id":"fb2914f1f0935669","type":"inject","z":"d453483289da3934","g":"fc7da1fa95073336","name":"{ \"name\": \"John\", \"age\": 30, \"age\": 30 }","props":[{"p":"myObject","v":"{ \"name\": \"John\", \"age\": 30, \"age\": 30 }","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":750,"y":2680,"wires":[["cf34ba49e1cb916e"]]},{"id":"cf34ba49e1cb916e","type":"link out","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link out 355","mode":"link","links":["68c08e2dd63551b2"],"x":935,"y":2680,"wires":[]},{"id":"1e441f3ea85dc380","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$sift() filters an object based on a condition.","info":"","x":220,"y":2920,"wires":[]},{"id":"2988441467eda07b","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$sift(myObject, function($v, $k) { $k ~> /^Customer/ })","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sift(myObject, function($v, $k) { $k ~> /^Customer/ })","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":3320,"wires":[["37e70723eecbdff7"]]},{"id":"37e70723eecbdff7","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"sift","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":3320,"wires":[]},{"id":"06892b9c2a149aad","type":"inject","z":"d453483289da3934","g":"fc7da1fa95073336","name":"    \"Customer1\": {\\n         \"CustomerID\": 12345,\\n         \"Name\": \"Billy Bob\",\\n         \"Model\": \"Y\"\\n     },\\n     \"Employee1\": {\\n         \"EmployeeID\": 24680,\\n         \"Name\": \"Fred Rock\",\\n         \"Model\": \"3\"\\n     },\\n     \"Employee2\": {\\n         \"EmployeeID\": 13579,\\n         \"Name\": \"Ash Luis\",\\n         \"Model\": \"S\"\\n","props":[{"p":"myObject","v":"{\"Customer1\":{\"CustomerID\":12345,\"Name\":\"Billy Bob\",\"Model\":\"Y\"},\"Employee1\":{\"EmployeeID\":24680,\"Name\":\"Fred Rock\",\"Model\":\"3\"},\"Employee2\":{\"EmployeeID\":13579,\"Name\":\"Ash Luis\",\"Model\":\"S\"},\"Customer2\":{\"CustomerID\":54321,\"Name\":\"Amber Daniels\",\"Model\":\"X\"},\"Customer3\":{\"CustomerID\":98765,\"Name\":\"April Star\",\"Model\":\"3\"}}","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":640,"y":3080,"wires":[["267d42b98c233bc3"]]},{"id":"267d42b98c233bc3","type":"link out","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link out 356","mode":"link","links":["b780861c05c8f4bb","66342c2d020661db","55bcd51ace38eb2e"],"x":765,"y":3080,"wires":[]},{"id":"66342c2d020661db","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 294","links":["267d42b98c233bc3"],"x":515,"y":3320,"wires":[["2988441467eda07b"]]},{"id":"5a82aaa74c5bfca9","type":"comment","z":"d453483289da3934","g":"fc7da1fa95073336","name":"filter on key: customer","info":"","x":600,"y":3280,"wires":[]},{"id":"31c315b845ceaa53","type":"change","z":"d453483289da3934","g":"fc7da1fa95073336","name":"$sift(myObject, function($v, $k) { $k = \"name\" or $k = \"age\" })\t","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sift(myObject, function($v, $k) { $k = \"Name\" or $k = \"Model\" })\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":3440,"wires":[["856ad5d0dbd9ddd3"]]},{"id":"856ad5d0dbd9ddd3","type":"debug","z":"d453483289da3934","g":"fc7da1fa95073336","name":"sift","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":3440,"wires":[]},{"id":"6921ab136857f13f","type":"inject","z":"d453483289da3934","g":"fc7da1fa95073336","name":"{ \"name\": \"John\", \"age\": 30, \"age\": 30 }","props":[{"p":"myObject","v":"{ \"name\": \"John\", \"age\": 30, \"age\": 30 }","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":670,"y":3380,"wires":[["dc89d043a81a9c7e"]]},{"id":"dc89d043a81a9c7e","type":"link out","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link out 357","mode":"link","links":["1dad9b01f3d638af","62bf372e9a1487f0"],"x":845,"y":3380,"wires":[]},{"id":"1dad9b01f3d638af","type":"link in","z":"d453483289da3934","g":"fc7da1fa95073336","name":"link in 295","links":["dc89d043a81a9c7e"],"x":515,"y":3440,"wires":[["31c315b845ceaa53"]]}]
Collection Info
Created 1 year, 1 month ago
Rating: 5 1
  • change (x23)
  • comment (x14)
  • debug (x22)
  • function (x3)
  • inject (x23)
  • link in (x9)
  • link out (x11)
  • switch (x1)
  • template (x4)
  • jsonata
  • change node
  • switch node
