PostNL notification (for Home Assistant)
For Dutch users only. A flow that gets all shipments from the PostNL App API and sends a notification (through Home Assistant) for upcoming deliveries.
Sample PostNL
You need the PostNL app (tested with IOS) and setup a proxy (like Charles Proxy) to retrieve the necessary information.
Replace the following items from information regarding the app:
In the Set Payload Refresh Token node
  • GET_REFRESH_TOKEN_FROM_APP
  • GET_USER_AGENT_FROM_APP
Refresh token PostNL
In the Get PostNL API node
  • GET_DEVICE_TOKEN_FROM_APP
Device token and User agent PostNL
You can only see the refresh token when the access token on your device is expired. Make sure your proxy is setup before you open the app, otherwise you'll have to wait an hour.
This flow will retrieve an access_token first, before asking the api for shipments. You can replace the Home Assistant notifications for something else.
This is not tied to an official API, so it may stop working. I've been running this for a few day's, so it seems to work fine for now.
Like this flow? Then please encourage me to make more!
Buy Me A Coffee
[{"id":"26ad711013720db1","type":"inject","z":"6bd02c2a2c231ca5","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":130,"y":380,"wires":[["7390eecb2a68187b"]]},{"id":"7390eecb2a68187b","type":"change","z":"6bd02c2a2c231ca5","name":"Set Payload Refresh Token","rules":[{"t":"set","p":"payload","pt":"msg","to":"refresh_token=GET_REFRESH_TOKEN_FROM_APP&client_id=pnl-app&grant_type=refresh_token","tot":"str"},{"t":"set","p":"headers.content-type","pt":"msg","to":"application/x-www-form-urlencoded; charset=UTF-8","tot":"str"},{"t":"set","p":"headers.user-agent","pt":"msg","to":"GET_USER_AGENT_FROM_APP","tot":"str"},{"t":"set","p":"headers.accept","pt":"msg","to":"*/*","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":380,"wires":[["bb95aaed0e1ab77a"]]},{"id":"bb95aaed0e1ab77a","type":"http request","z":"6bd02c2a2c231ca5","name":"Get Bearer Token","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://jouw.postnl.nl/identity/connect/token","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":590,"y":380,"wires":[["9b8af9562bd9b403"]]},{"id":"9b8af9562bd9b403","type":"switch","z":"6bd02c2a2c231ca5","name":"Check access_token key","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"access_token","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":830,"y":380,"wires":[["c73bfa4f62f12627"],["3db74ddcab5f9fd1"]]},{"id":"c73bfa4f62f12627","type":"change","z":"6bd02c2a2c231ca5","name":"Set Bearer Token","rules":[{"t":"set","p":"token","pt":"msg","to":"\"Bearer \" & msg.payload.access_token","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":480,"wires":[["51f06d75d07accfc"]]},{"id":"3db74ddcab5f9fd1","type":"api-call-service","z":"6bd02c2a2c231ca5","name":"Notify Mobile on error","server":"0eecc4b4dd856bd2","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\t   \"title\": \"PostNL\",\t   \"message\": \"PostNL flow broken\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1120,"y":380,"wires":[[]]},{"id":"51f06d75d07accfc","type":"http request","z":"6bd02c2a2c231ca5","name":"Get PostNL API","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://jouw.postnl.nl/services/serverdrivenui/api/Screen/OverviewTab","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"app-version","valueType":"other","valueValue":"5.7.3"},{"keyType":"other","keyValue":"api-version","valueType":"other","valueValue":"1.5.1"},{"keyType":"other","keyValue":"app-platform","valueType":"other","valueValue":"iOS"},{"keyType":"other","keyValue":"device-token","valueType":"other","valueValue":"GET_DEVICE_TOKEN_FROM_APP"},{"keyType":"other","keyValue":"user-agent","valueType":"other","valueValue":"GET_USER_AGENT_FROM_APP"},{"keyType":"other","keyValue":"app-country","valueType":"other","valueValue":"NL"},{"keyType":"other","keyValue":"authorization","valueType":"msg","valueValue":"token"}],"x":400,"y":480,"wires":[["233e69e220541b2d"]]},{"id":"233e69e220541b2d","type":"change","z":"6bd02c2a2c231ca5","name":"Get Shipments (From section 1)","rules":[{"t":"set","p":"payload","pt":"msg","to":"msg.payload.screen.sections[1].items","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":480,"wires":[["d8f40413e2ddd21b"]]},{"id":"d8f40413e2ddd21b","type":"split","z":"6bd02c2a2c231ca5","name":"Split Shipments (From array)","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":940,"y":480,"wires":[["f9f76e584b87828f"]]},{"id":"f9f76e584b87828f","type":"change","z":"6bd02c2a2c231ca5","name":"Change Track & Trace URL","rules":[{"t":"change","p":"payload.action.url","pt":"msg","from":"https://jouw.postnl.nl/services/serverdrivenui/api/TrackAndTrace/","fromt":"str","to":"https://jouw.postnl.nl/track-and-trace/","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":580,"wires":[["8e9a58fd6ffe92be"]]},{"id":"8e9a58fd6ffe92be","type":"switch","z":"6bd02c2a2c231ca5","name":"Check Shipments Today","property":"payload.title","propertyType":"msg","rules":[{"t":"cont","v":"Vandaag","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":580,"wires":[["da1b704d1cdab83b"]]},{"id":"da1b704d1cdab83b","type":"api-call-service","z":"6bd02c2a2c231ca5","name":"Notify Mobile","server":"0eecc4b4dd856bd2","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\t   \"title\": \"PostNL\",\t   \"message\": msg.payload.contentDescription.description,\t   \"data\": {\t       \"actions\": [\t           {\t               \"action\": \"URI\",\t               \"title\": \"Track & Trace\",\t               \"uri\": msg.payload.action.url\t            }\t        ]\t   }\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":580,"wires":[[]]},{"id":"0eecc4b4dd856bd2","type":"server","name":"Home Assistant","version":5,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false,"credentials":{"host":"","access_token":""}}]
Created 4 years, 3 months ago
  • change (x4)
  • http request (x2)
  • split (x1)
  • switch (x2)
  • PostNL
  • Parcel
  • Shipment
  • Delivery
  • Notification
  • Dutch
  • HomeAssistant
