JSON API to connect Watson Assistant to Facebook Messenger thru ChatFuel
This a REST API (JSON) to be used to connect to Facebook Messenger thru ChatFuel. It works with multiples responses from Watson Assistant. Details how to connect Watson Assistant to Facebook Messenger thru ChatFuel on video below: https://www.youtube.com/watch?v=Oni7g2uK9PM
[{"id":"5564e882.739708","type":"http in","z":"28db7b91.70b264","name":"","url":"/facebook","method":"get","upload":false,"swaggerDoc":"","x":120,"y":200,"wires":[["8861d5d5.9111c8"]]},{"id":"8861d5d5.9111c8","type":"change","z":"28db7b91.70b264","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"req.query.message","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[["9f8e41dd.4562f"]]},{"id":"9f8e41dd.4562f","type":"watson-conversation-v1","z":"28db7b91.70b264","name":"","workspaceid":"917de967-1975-4535-a4ea-101f5023d211","multiuser":false,"context":true,"empty-payload":false,"default-endpoint":true,"service-endpoint":"https://gateway.watsonplatform.net/conversation/api","timeout":"","optout-learning":false,"x":420,"y":260,"wires":[["23148461.af666c"]]},{"id":"23148461.af666c","type":"function","z":"28db7b91.70b264","name":"","func":"var wc_output = [];\nif(msg.payload.output.text)\n{\n    for(x=0;x<msg.payload.output.text.length;x++)\n    {\n        wc_output[x] = {\"text\":msg.payload.output.text[x]};\n    }\n    msg.payload = wc_output;\n    return msg;\n}\nreturn null;\n","outputs":1,"noerr":0,"x":550,"y":260,"wires":[["29cee149.f0e4be"]]},{"id":"29cee149.f0e4be","type":"http response","z":"28db7b91.70b264","name":"","statusCode":"","headers":{},"x":630,"y":200,"wires":[]},{"id":"8b63bab9.256028","type":"comment","z":"28db7b91.70b264","name":"How to connect Watson Assistant to Facebook Messenger thru ChatFuel","info":"Watch the follwoing video to see how to connect  Watson Assistant to Facebook Messenger thru ChatFuel\n\nhttps://www.youtube.com/watch?v=Oni7g2uK9PM","x":300,"y":140,"wires":[]}]
Created 9 years, 3 months ago
Updated 8 years, 5 months ago
Rating: 5 2
  • change (x1)
  • http in (x1)
  • http response (x1)
  • Watson
  • Conversation
  • ChatFuel
