Use UI to change a object in a Context object array based on dropdown list UI
This allows the changing of variables in one object of an array of objects (stored in the example in a Context Flow file variable) based on a key in the object. Reading the variables to initiate the Drop down and number UI objects was easy, but writing them back was more difficult but this cracked it.
The example is used to adjust several variables in a thing that controls a Solar hot water system, with each variable having upper and lower limits (also stored in the object).
Just add new objects to the Context array to add new variables to adjust.
[{"id":"ab266f1b.4a31c","type":"catch","z":"d05da15.a8b596","name":"","scope":null,"uncaught":false,"x":110,"y":573,"wires":[["da3e8088.d4077"]]},{"id":"da3e8088.d4077","type":"debug","z":"d05da15.a8b596","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":340,"y":573,"wires":[]},{"id":"c80b6306.f7794","type":"link out","z":"d05da15.a8b596","name":"To MQTT Out","links":[],"x":1182.5,"y":395,"wires":[]},{"id":"9d0dc549.726b48","type":"rbe","z":"d05da15.a8b596","name":"","func":"rbei","gap":"","start":"","inout":"out","property":"payload","x":1089.5,"y":395,"wires":[["c80b6306.f7794"]]},{"id":"a387befa.a8e5","type":"group","z":"d05da15.a8b596","name":"Change Shed HW Settings","style":{"label":true},"nodes":["22a9690.feefb96","cd625b5c.06c908","b32855bd.ebd618","5c88f455.6ad7dc","c34a8550.4cb248","4dafae4.7f1525","238d8e4d.084b32","854e9345.85924","59f59a84.e4e434","32534936.6e4066","466dfb76.6e7f74","b8aa97b5.04d4a8","fd7791db.fb8cf","f1e74695.25b908","f4225898.728088","8bca0ccc.e539d","ae10ada2.9e3a","6232d173.c4704"],"x":31,"y":161,"w":995.5,"h":362},{"id":"22a9690.feefb96","type":"inject","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":164,"y":482,"wires":[["32534936.6e4066"]]},{"id":"cd625b5c.06c908","type":"ui_numeric","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"Set Temp","label":"Temperature C","tooltip":"","group":"56dd1777.0149a8","order":2,"width":0,"height":0,"wrap":false,"passthru":false,"topic":"","format":"{{value}}","min":"-10","max":"100","step":1,"x":882,"y":335,"wires":[["59f59a84.e4e434"]]},{"id":"b32855bd.ebd618","type":"ui_ui_control","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"to SHW Settings UI","events":"change","x":301.5,"y":204,"wires":[["f1e74695.25b908"]]},{"id":"5c88f455.6ad7dc","type":"change","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"disable control","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":707.5,"y":203,"wires":[["cd625b5c.06c908","238d8e4d.084b32"]]},{"id":"c34a8550.4cb248","type":"change","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","rules":[{"t":"set","p":"SHW","pt":"msg","to":"#:(file)::SHW","tot":"flow"},{"t":"set","p":"options","pt":"msg","to":"SHW[].key","tot":"jsonata"},{"t":"delete","p":"ParamKey","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":310.5,"y":336,"wires":[["4dafae4.7f1525","238d8e4d.084b32"]]},{"id":"4dafae4.7f1525","type":"ui_dropdown","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","label":"New Drop down","tooltip":"","place":"Select option","group":"56dd1777.0149a8","order":1,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":511.5,"y":335,"wires":[["854e9345.85924"]]},{"id":"238d8e4d.084b32","type":"debug","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930.5,"y":202,"wires":[]},{"id":"854e9345.85924","type":"change","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","rules":[{"t":"set","p":"SHW","pt":"msg","to":"#:(file)::SHW","tot":"flow"},{"t":"set","p":"ParamKey","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"Param","pt":"msg","to":"SHW[key=$$.payload]","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"Param.current","tot":"msg"},{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":696,"y":335,"wires":[["238d8e4d.084b32","cd625b5c.06c908"]]},{"id":"59f59a84.e4e434","type":"change","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","rules":[{"t":"set","p":"SHW","pt":"msg","to":"#:(file)::SHW","tot":"flow"},{"t":"set","p":"ParamKey","pt":"msg","to":"ParamKey","tot":"flow"},{"t":"set","p":"Param","pt":"msg","to":"SHW[key=$$.ParamKey]","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$min(\t   [\t       $max([$$.Param.min, $$.payload]),\t       $$.Param.max\t   ]\t)","tot":"jsonata"},{"t":"set","p":"Param.current","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"#:(file)::SHW","pt":"flow","to":"$map(\t   SHW,\t   function($v, $i){\t       $v.key!=$$.ParamKey?$v:$merge([$v, {\"current\":payload}])\t   }\t)\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"Param.MQTTtopic","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":879.5,"y":396,"wires":[["238d8e4d.084b32","cd625b5c.06c908","9d0dc549.726b48"]]},{"id":"32534936.6e4066","type":"template","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"Shed Hot water control Array","field":"payload","fieldType":"msg","format":"json","syntax":"plain","template":"[{\"key\":\"ShedTankMaxTemp\",\"current\":80,\"max\":100,\"min\":30,\"MQTTtopic\":\"Shed/HotWater/Tank/MaxTemp\"},{\"key\":\"ShedTubeFrostTemp\",\"current\":10,\"max\":25,\"min\":-10,\"MQTTtopic\":\"Shed/HotWater/Tubes/FrostTemp\"},{\"key\":\"ShedTubeOnTempDiff\",\"current\":10,\"max\":25,\"min\":5,\"MQTTtopic\":\"Shed/HotWater/Pump/OnTempDiff\"},{\"key\":\"ShedTubeOffTempDrop\",\"current\":4,\"max\":20,\"min\":1,\"MQTTtopic\":\"Shed/HotWater/Pump/OffTempDrop\"}]","output":"str","x":372.5,"y":482,"wires":[["b8aa97b5.04d4a8"]]},{"id":"466dfb76.6e7f74","type":"debug","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":854.5,"y":480,"wires":[]},{"id":"b8aa97b5.04d4a8","type":"json","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","property":"payload","action":"","pretty":false,"x":567.5,"y":482,"wires":[["fd7791db.fb8cf"]]},{"id":"fd7791db.fb8cf","type":"change","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","rules":[{"t":"set","p":"#:(file)::SHW","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":714.5,"y":481,"wires":[["466dfb76.6e7f74"]]},{"id":"f1e74695.25b908","type":"switch","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","property":"name","propertyType":"msg","rules":[{"t":"eq","v":"Shed Hot Water Settings","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":525.5,"y":204,"wires":[["c34a8550.4cb248","5c88f455.6ad7dc"]]},{"id":"f4225898.728088","type":"ui_button","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","group":"ddb08462.c1f2f8","order":2,"width":"3","height":"1","passthru":false,"label":"Settings","tooltip":"","color":"","bgcolor":"","icon":"fa-wrench","payload":"Shed Hot Water Settings","payloadType":"str","topic":"","x":117,"y":205,"wires":[["b32855bd.ebd618"]]},{"id":"8bca0ccc.e539d","type":"ui_button","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"","group":"56dd1777.0149a8","order":3,"width":"3","height":"1","passthru":false,"label":" Done","tooltip":"","color":"","bgcolor":"","icon":"fa-hand-o-left","payload":"Water","payloadType":"str","topic":"","x":129.5,"y":390,"wires":[["ae10ada2.9e3a"]]},{"id":"ae10ada2.9e3a","type":"ui_ui_control","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"Back to Water UI","events":"all","x":315.5,"y":389,"wires":[[]]},{"id":"6232d173.c4704","type":"comment","z":"d05da15.a8b596","g":"a387befa.a8e5","name":"Initiate Flow Variable","info":"","x":165.5,"y":435,"wires":[]},{"id":"56dd1777.0149a8","type":"ui_group","z":"","name":"Settings","tab":"b0b54239.86619","order":1,"disp":true,"width":"6","collapse":false},{"id":"ddb08462.c1f2f8","type":"ui_group","z":"","name":"Shed","tab":"979abaed.39ad78","order":1,"disp":true,"width":"6","collapse":false},{"id":"b0b54239.86619","type":"ui_tab","z":"","name":"Shed Hot Water Settings","icon":"fa-settings","order":9,"disabled":false,"hidden":true},{"id":"979abaed.39ad78","type":"ui_tab","z":"","name":"Water","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
Created 6 years, 7 months ago
  • catch (x1)
  • change (x5)
  • debug (x3)
  • json (x1)
  • link out (x1)
  • rbe (x1)
  • switch (x1)
  • template (x1)
  • Context-arrays
  • Dynamic-array-change
  • UI
  • IOT
