Octopus UK Flux Calculator
This flow will look at your consumption data from 2022 and rate the costs based on the new Flux tarrif.
Its designed for users who are already on the Tesla Energy Plan which has now been discontinued and replaced with Flux.
A few caveats:
  • These flux rates so far are the national averages, so there will be regional variaions I imagine, I’m in the South West whcih is a more expensive region.
  • The flow doesn't take into account the shift between BST & GMT as the Octopus API returns UTC all the time and timezone stuff is hard!
  • I’ve not taken into account standing charges as these are basically the same on any tarrif
This assumes that the import and export pattern will be the same when you setup your powerwall for Time of Use as it was on TEP under Teslas control
You will need an Octopus API key for your account from https://octopus.energy/dashboard/developer/ Along with your electricity meter Serial number and your import and export MPANs, these can be found in your Octopus account
[{"id":"f6ba8b7b30f4e2cb","type":"http request","z":"4c90073d297b222d","name":"GET Import","method":"GET","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":830,"y":380,"wires":[["3a6f17a9f31e9c35"]]},{"id":"5ebe88b7b1ec9cb8","type":"split","z":"4c90073d297b222d","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1190,"y":380,"wires":[["150dbdca01686331"]]},{"id":"3a6f17a9f31e9c35","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.results","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":380,"wires":[["5ebe88b7b1ec9cb8"]]},{"id":"636a06998edd1f09","type":"template","z":"4c90073d297b222d","name":"","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"https://{{apikey}}:@api.octopus.energy/v1/electricity-meter-points/{{importmpan}}/meters/{{meter}}/consumption","output":"str","x":680,"y":380,"wires":[["f6ba8b7b30f4e2cb"]]},{"id":"5ebc13f0ad75b45f","type":"inject","z":"4c90073d297b222d","name":"Set MPANs, Meter ID, API Key and Dates","props":[{"p":"payload.period_from","v":"2022-01-01T00:00:00+0100","vt":"str"},{"p":"payload.period_to","v":"2022-12-31T23:59:00+0100","vt":"str"},{"p":"payload.page_size","v":"20000","vt":"str"},{"p":"apikey","v":"sk_live_XXXXXXXXXXXX","vt":"str"},{"p":"meter","v":"XXXXXXX","vt":"str"},{"p":"importmpan","v":"XXXXXXXXXXXX","vt":"str"},{"p":"exportmpan","v":"XXXXXXXXXXXX","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":220,"y":500,"wires":[["0497ba7168f88387","3f56243c23dca03a"]]},{"id":"a599f6d61a1e4469","type":"http request","z":"4c90073d297b222d","name":"GET Export","method":"GET","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":850,"y":620,"wires":[["4fc0c7e303bf879a"]]},{"id":"beebeb2ba7f668aa","type":"split","z":"4c90073d297b222d","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1190,"y":620,"wires":[["75b2d6fe7ca089d2"]]},{"id":"4fc0c7e303bf879a","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.results","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":620,"wires":[["beebeb2ba7f668aa"]]},{"id":"e85286e9a179c6a0","type":"template","z":"4c90073d297b222d","name":"","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"https://{{apikey}}:@api.octopus.energy/v1/electricity-meter-points/{{exportmpan}}/meters/{{meter}}/consumption","output":"str","x":680,"y":620,"wires":[["a599f6d61a1e4469"]]},{"id":"150dbdca01686331","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"payload.start","pt":"msg","to":"$number($split($replace($split(payload.interval_start, \"T\")[1], \"Z\", ''), \":\")[0])\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":380,"wires":[["8d9859e2c7b62231"]]},{"id":"8d9859e2c7b62231","type":"switch","z":"4c90073d297b222d","name":"","property":"payload.start","propertyType":"msg","rules":[{"t":"btwn","v":"2","vt":"num","v2":"4","v2t":"num"},{"t":"btwn","v":"16","vt":"num","v2":"18","v2t":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1550,"y":380,"wires":[["f111a4d48f940eb1"],["c3221a2ded9c6b7a"],["9080b04015b4d633"]]},{"id":"75b2d6fe7ca089d2","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"payload.start","pt":"msg","to":"$number($split($replace($split(payload.interval_start, \"T\")[1], \"Z\", ''), \":\")[0])\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":620,"wires":[["3abde9c03ef68fde"]]},{"id":"3abde9c03ef68fde","type":"switch","z":"4c90073d297b222d","name":"","property":"payload.start","propertyType":"msg","rules":[{"t":"btwn","v":"2","vt":"num","v2":"4","v2t":"num"},{"t":"btwn","v":"16","vt":"num","v2":"18","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":1550,"y":620,"wires":[["399d9787c6742e7a"],["d9a75129aa874acb"],["8746417be566a715"]]},{"id":"f111a4d48f940eb1","type":"change","z":"4c90073d297b222d","name":"Rate Off-Peak","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"20.4","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"offpeak","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1800,"y":340,"wires":[["a0c60a62d0036298"]]},{"id":"c3221a2ded9c6b7a","type":"change","z":"4c90073d297b222d","name":"Rate Peak","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"47.5","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"peak","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1790,"y":380,"wires":[["a0c60a62d0036298"]]},{"id":"9080b04015b4d633","type":"change","z":"4c90073d297b222d","name":"Rate Daytime","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"34","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"day","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1800,"y":420,"wires":[["a0c60a62d0036298"]]},{"id":"a0c60a62d0036298","type":"function","z":"4c90073d297b222d","name":"Sum","func":"var t = flow.get(msg.topic);\nt += msg.payload.cost\nflow.set(msg.topic, t)\nmsg.total = t\nvar i = flow.get(\"import\");\ni += msg.payload.consumption\nflow.set(\"import\", i)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2030,"y":380,"wires":[["b2b3bec857d0ed36"]]},{"id":"0497ba7168f88387","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"peak","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"offpeak","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"day","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"import","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":380,"wires":[["636a06998edd1f09"]]},{"id":"b2b3bec857d0ed36","type":"join","z":"4c90073d297b222d","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":2150,"y":380,"wires":[["d29c40b0e805c4af"]]},{"id":"1205e9dd8b9d22f9","type":"debug","z":"4c90073d297b222d","name":"Totals Import","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"totals","targetType":"msg","statusVal":"","statusType":"auto","x":2510,"y":380,"wires":[]},{"id":"399d9787c6742e7a","type":"change","z":"4c90073d297b222d","name":"Rate Offpeak","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"9.4","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"offpeak","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1770,"y":580,"wires":[["7b88446f22b7c786"]]},{"id":"d9a75129aa874acb","type":"change","z":"4c90073d297b222d","name":"Rate Peak","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"36.5","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"peak","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1770,"y":620,"wires":[["7b88446f22b7c786"]]},{"id":"8746417be566a715","type":"change","z":"4c90073d297b222d","name":"Rate Daytime","rules":[{"t":"set","p":"payload.rate","pt":"msg","to":"23","tot":"num"},{"t":"set","p":"payload.cost","pt":"msg","to":"payload.consumption*payload.rate","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"day","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1780,"y":660,"wires":[["7b88446f22b7c786"]]},{"id":"7b88446f22b7c786","type":"function","z":"4c90073d297b222d","name":"Sum","func":"var t = flow.get(msg.topic);\nt += msg.payload.cost\nflow.set(msg.topic, t)\nmsg.total = t\nvar e = flow.get(\"export\");\ne += msg.payload.consumption\nflow.set(\"export\", e)\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2030,"y":620,"wires":[["88cfd5358ccfff11"]]},{"id":"88cfd5358ccfff11","type":"join","z":"4c90073d297b222d","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":2150,"y":620,"wires":[["8285dc624c35f5aa"]]},{"id":"887faf743172e5fd","type":"debug","z":"4c90073d297b222d","name":"Totals Export","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"totals","targetType":"msg","statusVal":"","statusType":"auto","x":2510,"y":620,"wires":[]},{"id":"3f56243c23dca03a","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"peak","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"offpeak","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"day","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"export","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":620,"wires":[["e85286e9a179c6a0"]]},{"id":"d29c40b0e805c4af","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"import","tot":"str"},{"t":"set","p":"totals","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"totals.day_cost","pt":"msg","to":"day","tot":"flow"},{"t":"set","p":"totals.offpeak_cost","pt":"msg","to":"offpeak","tot":"flow"},{"t":"set","p":"totals.peak_cost","pt":"msg","to":"peak","tot":"flow"},{"t":"set","p":"totals.import_kwh","pt":"msg","to":"import","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":2300,"y":380,"wires":[["1205e9dd8b9d22f9"]]},{"id":"8285dc624c35f5aa","type":"change","z":"4c90073d297b222d","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"export","tot":"str"},{"t":"set","p":"totals","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"totals.day_cost","pt":"msg","to":"day","tot":"flow"},{"t":"set","p":"totals.offpeak_cost","pt":"msg","to":"offpeak","tot":"flow"},{"t":"set","p":"totals.peak_cost","pt":"msg","to":"peak","tot":"flow"},{"t":"set","p":"totals.export_kwh","pt":"msg","to":"export","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":2300,"y":620,"wires":[["887faf743172e5fd"]]}]
Created 2 years, 5 months ago
  • change (x14)
  • debug (x2)
  • function (x2)
  • http request (x2)
  • join (x2)
  • split (x2)
  • switch (x2)
  • template (x2)
  • uk
  • octopusenergy
  • tesla
  • powerwall
