Algorithmia Colorize
Colorize an Image using the Algorithmia API.
screenshot
This flow lets you:
  • upload an image to your collection using Node-RED
  • process the image on Algorithmia
  • download the resulting image to Node-Red
Preparation
  • Sign up and get an API-key here.
  • Create a collection named "blackandwhite" on Algorithmia
  • Adapt the API-key and the absolute paths for loading and saving your images in this Node-RED flow
Requirements
[{"id":"6cc0299f.ecc15","type":"tab","label":"algorithmia colorize","disabled":false,"info":""},{"id":"4c762c40.50c0fc","type":"http request","z":"6cc0299f.ecc15","name":"POST request","method":"POST","ret":"obj","paytoqs":false,"url":"https://api.algorithmia.com/v1/algo/deeplearning/ColorfulImageColorization/1.1.14?timeout=300","tls":"","persist":false,"proxy":"","authType":"","x":1340,"y":300,"wires":[["450a0300.99169c"]]},{"id":"7d0f454b.39f5f4","type":"debug","z":"6cc0299f.ecc15","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1830,"y":200,"wires":[]},{"id":"67ae3ce8.46f97c","type":"file in","z":"6cc0299f.ecc15","name":"","filename":"/Users/martin/Desktop/grace-hopper.jpg","format":"","chunk":false,"sendError":false,"encoding":"none","x":460,"y":200,"wires":[["9fbc40fe.404128","df9314f1.b863d8"]]},{"id":"28636962.19a8d6","type":"change","z":"6cc0299f.ecc15","name":"image param","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"image\": msg.payload}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":300,"wires":[["964c3430.7dd11"]]},{"id":"8466c2b2.2c2df8","type":"inject","z":"6cc0299f.ecc15","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":200,"wires":[["67ae3ce8.46f97c"]]},{"id":"50b90d.4028f6f4","type":"file","z":"6cc0299f.ecc15","name":"","filename":"/Users/martin/Desktop/grace-hopper-colorized.jpg ","appendNewline":false,"createDir":false,"overwriteFile":"true","encoding":"none","x":1730,"y":400,"wires":[[]]},{"id":"5655e469.56aaf4","type":"debug","z":"6cc0299f.ecc15","name":"show output filename","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1800,"y":300,"wires":[]},{"id":"450a0300.99169c","type":"change","z":"6cc0299f.ecc15","name":"extract file url","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.result.output","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1540,"y":300,"wires":[["5655e469.56aaf4","15da65d0.af96b2"]]},{"id":"3c9fb2a3.e98e5e","type":"comment","z":"6cc0299f.ecc15","name":"Upload a black and white image","info":"","x":250,"y":160,"wires":[]},{"id":"870fcbbc.ecf3d8","type":"comment","z":"6cc0299f.ecc15","name":"Colorize the image with AI magic ","info":"","x":250,"y":260,"wires":[]},{"id":"3b67ea1a.1f1076","type":"http request","z":"6cc0299f.ecc15","name":"GET request","method":"GET","ret":"bin","paytoqs":false,"url":"https://api.algorithmia.com/v1/data/{{{payload}}}","tls":"","persist":false,"proxy":"","authType":"","x":1330,"y":400,"wires":[["50b90d.4028f6f4","c2ca6e91.b98cf"]]},{"id":"c2ca6e91.b98cf","type":"image viewer","z":"6cc0299f.ecc15","name":"","width":"782","data":"payload","dataType":"msg","x":1110,"y":500,"wires":[[]]},{"id":"15da65d0.af96b2","type":"split","z":"6cc0299f.ecc15","name":"split data URL","splt":"data://","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":760,"y":400,"wires":[["7a16c27e.4d2d5c"]]},{"id":"7a16c27e.4d2d5c","type":"switch","z":"6cc0299f.ecc15","name":"extract path","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":970,"y":400,"wires":[["f6fc197d.e0e3b"]]},{"id":"7b530a48.e2251c","type":"comment","z":"6cc0299f.ecc15","name":"Download the result","info":"","x":210,"y":360,"wires":[]},{"id":"f9cd6b01.a8f35","type":"http request","z":"6cc0299f.ecc15","name":"PUT request","method":"PUT","ret":"obj","paytoqs":false,"url":"https://api.algorithmia.com/v1/data/.my/{{{collection}}}/{{{filename}}}","tls":"","persist":false,"proxy":"","authType":"","x":1330,"y":200,"wires":[["99b8cd2d.32cc8"]]},{"id":"df9314f1.b863d8","type":"change","z":"6cc0299f.ecc15","name":"filename","rules":[{"t":"set","p":"filename","pt":"msg","to":"grace-hopper.jpg","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":200,"wires":[["110dcb68.b3798d"]]},{"id":"99b8cd2d.32cc8","type":"change","z":"6cc0299f.ecc15","name":"get result","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.result","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1520,"y":200,"wires":[["7d0f454b.39f5f4","28636962.19a8d6"]]},{"id":"9fbc40fe.404128","type":"image viewer","z":"6cc0299f.ecc15","name":"","width":"782","data":"payload","dataType":"msg","x":290,"y":500,"wires":[[]]},{"id":"712dba32.a6d9ec","type":"change","z":"6cc0299f.ecc15","name":"","rules":[{"t":"set","p":"algorithmia_apikey","pt":"global","to":"Simple INSERT-YOUR-APIKEY-HERE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":100,"wires":[[]]},{"id":"f70a4cb7.153408","type":"inject","z":"6cc0299f.ecc15","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":100,"wires":[["712dba32.a6d9ec"]]},{"id":"ee3bb60c.55563","type":"comment","z":"6cc0299f.ecc15","name":"Set your API KEY here!","info":"","x":220,"y":60,"wires":[]},{"id":"b2e78c16.1717a","type":"change","z":"6cc0299f.ecc15","name":"authorization","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\t   \"Authorization\": $globalContext(\"algorithmia_apikey\")\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":200,"wires":[["f9cd6b01.a8f35"]]},{"id":"964c3430.7dd11","type":"change","z":"6cc0299f.ecc15","name":"authorization","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\t   \"Authorization\": $globalContext(\"algorithmia_apikey\")\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":300,"wires":[["4c762c40.50c0fc"]]},{"id":"f6fc197d.e0e3b","type":"change","z":"6cc0299f.ecc15","name":"authorization","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\t   \"Authorization\": $globalContext(\"algorithmia_apikey\")\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":400,"wires":[["3b67ea1a.1f1076"]]},{"id":"110dcb68.b3798d","type":"change","z":"6cc0299f.ecc15","name":"image collection","rules":[{"t":"set","p":"collection","pt":"msg","to":"blackandwhite","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":960,"y":200,"wires":[["b2e78c16.1717a"]]},{"id":"c9040b11.717828","type":"inject","z":"6cc0299f.ecc15","d":true,"name":"data://.algo/deeplearning/ColorfulImageColorization/temp/lincoln.png","topic":"","payload":"data://.algo/deeplearning/ColorfulImageColorization/temp/lincoln.png","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":370,"y":400,"wires":[["15da65d0.af96b2"]]},{"id":"79a023bb.183174","type":"inject","z":"6cc0299f.ecc15","d":true,"name":"data://deeplearning/example_data/lincoln.jpg","topic":"","payload":"data://deeplearning/example_data/lincoln.jpg","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":300,"wires":[["28636962.19a8d6"]]}]
Collection Info
Created 6 years, 5 months ago
  • change (x9)
  • comment (x4)
  • debug (x2)
  • file (x1)
  • file in (x1)
  • http request (x3)
  • inject (x4)
  • split (x1)
  • switch (x1)
  • #neuralnet
  • #deeplearning
  • #ai
  • #colorize
  • #photography
  • #algorithmia
