node-red-contrib-image-tools 2.1.1
A dynamic image editor, image viewer, 1D/2D Barcode Generator and 1D/2D Barcode Decoder nodes
npm install node-red-contrib-image-tools
A Node-RED node to perform functions on images, generate and decode barcodes.
Screenshots - to whet the appetite
Image processing...
Image_processing
Get image from internet...
kittens
Printing text...
printing_text printing_text
Barcode decoding...
barcode-decoding
Barcode generating...
barcode-generating
FEATURES
  • Built in demos.
    • In Node-RED, look under the hamburger menu → import → examples → node-red-contrib-image-tools
  • Image node
    • Read image from file, http, base64 string or buffer
    • Print single or multi line text to an image
    • Over 40 image function built in with many more possible by using convolution kernels
    • Perform 1 or multiple (batch) images processes in each node
      • TIP: you can convert a function to batch JSON by clicking the button adjacent to the function dropdown field. Then simply edit the batch JSON into an array [{...},{...},{...}] to perform as many operations as needed in one go.
    • Create blank image by setting Image field to an object {"w":100,"h":100,"background":0}
    • All function parameters can be either fixed or passed in by msg/flow/global
    • Can output image data as a Jimp image, a buffer or base64 string.
    • All functions and parameters are self documenting - a tip under each item in the node editor helps the user
    • Partial (non animated) GIF loading & processing support (experimental)
  • Image viewer node
    • View images in the node-red editor (for preview / debug purposes)
    • Full credit to rikukissa and dceejay for the excellent node-red-contrib-image-output on which the "image viewer node" is heavily based. (Copy of MIT license included in src files as requested)
    • Features include ability to display a jimp image, buffer, file name, base64 string, Data URL, Image URL.
    • Works in Internet Explorer (IE11 tested)
  • Barcode Decode node
  • Barcode Generator node
    • Ability to create over 100 types of barcodes...
      • auspost • AusPost 4 State Customer Code
      • azteccode • Aztec Code
      • azteccodecompact • Compact Aztec Code
      • aztecrune • Aztec Runes
      • bc412 • BC412
      • channelcode • Channel Code
      • codablockf • Codablock F
      • code11 • Code 11
      • code128 • Code 128
      • code16k • Code 16K
      • code2of5 • Code 25
      • code32 • Italian Pharmacode
      • code39 • Code 39
      • code39ext • Code 39 Extended
      • code49 • Code 49
      • code93 • Code 93
      • code93ext • Code 93 Extended
      • codeone • Code One
      • coop2of5 • COOP 2 of 5
      • daft • Custom 4 state symbology
      • databarexpanded • GS1 DataBar Expanded
      • databarexpandedcomposite • GS1 DataBar Expanded Composite
      • databarexpandedstacked • GS1 DataBar Expanded Stacked
      • databarexpandedstackedcomposite • GS1 DataBar Expanded Stacked Composite
      • databarlimited • GS1 DataBar Limited
      • databarlimitedcomposite • GS1 DataBar Limited Composite
      • databaromni • GS1 DataBar Omnidirectional
      • databaromnicomposite • GS1 DataBar Omnidirectional Composite
      • databarstacked • GS1 DataBar Stacked
      • databarstackedcomposite • GS1 DataBar Stacked Composite
      • databarstackedomni • GS1 DataBar Stacked Omnidirectional
      • databarstackedomnicomposite • GS1 DataBar Stacked Omnidirectional Composite
      • databartruncated • GS1 DataBar Truncated
      • databartruncatedcomposite • GS1 DataBar Truncated Composite
      • datalogic2of5 • Datalogic 2 of 5
      • datamatrix • Data Matrix
      • datamatrixrectangular • Data Matrix Rectangular
      • datamatrixrectangularextension • Data Matrix Rectangular Extension
      • dotcode • DotCode
      • ean13 • EAN-13
      • ean13composite • EAN-13 Composite
      • ean14 • GS1-14
      • ean2 • EAN-2 (2 digit addon)
      • ean5 • EAN-5 (5 digit addon)
      • ean8 • EAN-8
      • ean8composite • EAN-8 Composite
      • flattermarken • Flattermarken
      • gs1-128 • GS1-128
      • gs1-128composite • GS1-128 Composite
      • gs1-cc • GS1 Composite 2D Component
      • gs1datamatrix • GS1 Data Matrix
      • gs1datamatrixrectangular • GS1 Data Matrix Rectangular
      • gs1dotcode • GS1 DotCode
      • gs1northamericancoupon • GS1 North American Coupon
      • gs1qrcode • GS1 QR Code
      • hanxin • Han Xin Code
      • hibcazteccode • HIBC Aztec Code
      • hibccodablockf • HIBC Codablock F
      • hibccode128 • HIBC Code 128
      • hibccode39 • HIBC Code 39
      • hibcdatamatrix • HIBC Data Matrix
      • hibcdatamatrixrectangular • HIBC Data Matrix Rectangular
      • hibcmicropdf417 • HIBC MicroPDF417
      • hibcpdf417 • HIBC PDF417
      • hibcqrcode • HIBC QR Code
      • iata2of5 • IATA 2 of 5
      • identcode • Deutsche Post Identcode
      • industrial2of5 • Industrial 2 of 5
      • interleaved2of5 • Interleaved 2 of 5 (ITF)
      • isbn • ISBN
      • ismn • ISMN
      • issn • ISSN
      • itf14 • ITF-14
      • japanpost • Japan Post 4 State Customer Code
      • kix • Royal Dutch TPG Post KIX
      • leitcode • Deutsche Post Leitcode
      • mailmark • Royal Mail Mailmark
      • matrix2of5 • Matrix 2 of 5
      • maxicode • MaxiCode
      • micropdf417 • MicroPDF417
      • microqrcode • Micro QR Code
      • msi • MSI Modified Plessey
      • onecode • USPS Intelligent Mail
      • pdf417 • PDF417
      • pdf417compact • Compact PDF417
      • pharmacode • Pharmaceutical Binary Code
      • pharmacode2 • Two-track Pharmacode
      • planet • USPS PLANET
      • plessey • Plessey UK
      • posicode • PosiCode
      • postnet • USPS POSTNET
      • pzn • Pharmazentralnummer (PZN)
      • qrcode • QR Code
      • rationalizedCodabar • Codabar
      • raw • Custom 1D symbology
      • rectangularmicroqrcode • Rectangular Micro QR Code
      • royalmail • Royal Mail 4 State Customer Code
      • sscc18 • SSCC-18
      • symbol • Miscellaneous symbols
      • telepen • Telepen
      • telepennumeric • Telepen Numeric
      • ultracode • Ultracode
      • upca • UPC-A
      • upcacomposite • UPC-A Composite
      • upce • UPC-E
      • upcecomposite • UPC-E Composite
IMPORTANT - Breaking changes in V1
Version 1 has breaking change ~ vs ~ V0.x versions. Existing flows using the "2D Barcode Decode" node will need to be modified. The easy way of fixing this is to delete any "2D Barcode Decode" & deploy, then update the node, then re-add the new "Barcode Decode" nodes.
Alternatively, you can avoid this issue by performing the following steps...
  1. Upgrade node-red-contrib-image-tools
  2. Stop node-red
  3. Make a backup of your flow.json file
  4. Opening your flow.json file in a text editor
  5. Search / replace all instances of "type":"2D Barcode Decoder" with "type":"Barcode Decoder"
  6. Save and close your flow file
  7. Start node-red
Pre-requisites
None!
Simple
The easiest wat to install is to use the Pallet Manager in node-red.
Install from GIT
Run the following command in the directory of your Node-RED install. (Usually this is ~/.node-red or %userprofile%\.node-red).
npm install Steve-Mcl/node-red-contrib-image-tools
Install from NPM
Install from local directory
Run the following command in the root directory of your Node-RED install. (Usually this is ~/.node-red or %userprofile%\.node-red).
npm install c:/tempfolder/node-red-contrib-image-tools
NOTES
  • Tested on Node V10, V12, V14 only. YMMV
  • Bugs are quite possible :)
Version: 2.1.1
Updated 2 years, 11 months ago
Rating: 4.8 24
1121 in the last week
  • jimp-image
  • Barcode Decoder
  • Barcode Generator
  • image viewer
  • barcode
  • datamatrix
  • QR
  • zxing
  • jimp
  • image editing
  • image processing
  • image manipulation
  • image viewer
  • png
  • jpg
  • jpeg
  • bmp
  • bitmap
  • resize
  • scale
  • crop
