Arduino OPTA OPC-UA UI Client
⚑ Arduino_OPTA_OPC-UA
πŸ—‚ Overview
This project implements an πŸ–§ OPC-UA server on an πŸ”Œ Arduino OPTA platform, complemented by a 🌐 Node-RED client that serves as a control panel for the OPTA-based system. It enables real-time control and monitoring of:
  • βš™ OPTA relays
  • πŸ”˜ Digital inputs (e.g., buttons)
  • 🌑 Modbus-connected temperature and humidity sensor via the OPTA’s Modbus port
The repository was created to demonstrate seamless industrial device integration via OPC-UA for an interactive demoβ€”showcased at the πŸ€– Automate 2025 exhibition in Detroit.
πŸ“‘ What Is OPC-UA?
OPC Unified Architecture (OPC-UA) is a versatile, platform-agnostic communication protocol widely used in 🏭 industrial automation.
Key attributes:
  • πŸ”’ Secure by design – authentication, encryption, and integrity checks.
  • πŸ“ˆ Scalable and robust – from embedded devices to enterprise systems.
  • πŸ”„ Interoperable – information-model approach for structured data exchange.
  • πŸ’» Platform-independent – standardized, service-oriented architecture.
Leveraging OPC-UA in this project allows smooth integration between Arduino OPTA hardware and higher-level systems like Node-RED, creating a unified, interoperable control and monitoring interface.
πŸ–₯ node-red-opc-ua-client/
Contains the Node-RED flow that:
  • πŸ“‘ Connects as an OPC-UA client to the Arduino OPTA server
  • πŸŽ› Provides a dashboard to:
    • βš™ Toggle relays
    • πŸ”˜ Monitor button states
    • 🌑 Display sensor readings in real time
[{"id":"b95c86e74dc9406f","type":"tab","label":"OPC-UA","disabled":false,"info":"","env":[]},{"id":"a59f375690802a42","type":"group","z":"b95c86e74dc9406f","name":"","style":{"label":true},"nodes":["c263a3a56c11f124","34bd45f333eab18a","0159ff1ef70e89d0","0aa25d33b342dc12"],"x":34,"y":559,"w":672,"h":109.5},{"id":"342ae34d18db20b0","type":"group","z":"b95c86e74dc9406f","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["596388f0f9e091d7","fdaace6d400fbf2f","f0bd180120ee3da5","ba4e2ae132449f6a","74ee90883bd52478","47953c967cba1a58"],"x":34,"y":379,"w":912,"h":149.5},{"id":"05eff83989f131ef","type":"group","z":"b95c86e74dc9406f","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["8670d0d7b6e4b283","e3f59a3f940bde16","4f1fece8263783c6","72a6f1e340bd6e70","5cdf81538e141392","4eee15670b45ec36","6c5d4087a7fa0d95","93c85f3170000e84","b32795b75ab20e14","f0394a7ea192fd2c","1971a4ae7cc767cf"],"x":34,"y":31.5,"w":652,"h":329.5},{"id":"8670d0d7b6e4b283","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"05eff83989f131ef","item":"ns=0;i=50077.R1","datatype":"Boolean","value":"","name":"R1","x":290,"y":80,"wires":[["e3f59a3f940bde16"]]},{"id":"e3f59a3f940bde16","type":"OpcUa-Client","z":"b95c86e74dc9406f","g":"05eff83989f131ef","endpoint":"fd11cd9b5d90099e","action":"write","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","localkeyfile":"","securitymode":"None","securitypolicy":"None","useTransport":false,"maxChunkCount":1,"maxMessageSize":8192,"receiveBufferSize":8192,"sendBufferSize":8192,"setstatusandtime":false,"keepsessionalive":true,"name":"","x":580,"y":80,"wires":[[],[],[]]},{"id":"4f1fece8263783c6","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"05eff83989f131ef","item":"ns=0;i=50078.R2","datatype":"Boolean","value":"","name":"R2","x":290,"y":140,"wires":[["e3f59a3f940bde16"]]},{"id":"72a6f1e340bd6e70","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"05eff83989f131ef","item":"ns=0;i=50079.R3","datatype":"Boolean","value":"","name":"R3","x":290,"y":200,"wires":[["e3f59a3f940bde16"]]},{"id":"5cdf81538e141392","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"05eff83989f131ef","item":"ns=0;i=50080.R4","datatype":"Boolean","value":"","name":"R4","x":290,"y":260,"wires":[["e3f59a3f940bde16"]]},{"id":"4eee15670b45ec36","type":"ui_switch","z":"b95c86e74dc9406f","g":"05eff83989f131ef","name":"","label":"Relay 1","tooltip":"","group":"85144921.8931b8","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"0","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":120,"y":80,"wires":[["8670d0d7b6e4b283"]]},{"id":"6c5d4087a7fa0d95","type":"ui_switch","z":"b95c86e74dc9406f","g":"05eff83989f131ef","name":"","label":"Relay 2","tooltip":"","group":"85144921.8931b8","order":2,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"0","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":120,"y":140,"wires":[["4f1fece8263783c6"]]},{"id":"93c85f3170000e84","type":"ui_switch","z":"b95c86e74dc9406f","g":"05eff83989f131ef","name":"","label":"Relay 3","tooltip":"","group":"85144921.8931b8","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"0","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":120,"y":200,"wires":[["72a6f1e340bd6e70"]]},{"id":"b32795b75ab20e14","type":"ui_switch","z":"b95c86e74dc9406f","g":"05eff83989f131ef","name":"","label":"Relay 4","tooltip":"","group":"85144921.8931b8","order":4,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"0","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":120,"y":260,"wires":[["5cdf81538e141392"]]},{"id":"f0394a7ea192fd2c","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"05eff83989f131ef","item":"ns=0;i=50081.UL","datatype":"Boolean","value":"","name":"UL","x":290,"y":320,"wires":[["e3f59a3f940bde16"]]},{"id":"1971a4ae7cc767cf","type":"ui_switch","z":"b95c86e74dc9406f","g":"05eff83989f131ef","name":"","label":"User LED","tooltip":"","group":"f8b97d935f93f052","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"0","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":120,"y":320,"wires":[["f0394a7ea192fd2c"]]},{"id":"596388f0f9e091d7","type":"inject","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"0","payload":"true","payloadType":"bool","x":140,"y":480,"wires":[["f0bd180120ee3da5"]]},{"id":"fdaace6d400fbf2f","type":"OpcUa-Client","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","endpoint":"fd11cd9b5d90099e","action":"read","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","localkeyfile":"","securitymode":"None","securitypolicy":"None","useTransport":false,"maxChunkCount":1,"maxMessageSize":8192,"receiveBufferSize":8192,"sendBufferSize":8192,"setstatusandtime":false,"keepsessionalive":true,"name":"","x":460,"y":480,"wires":[["47953c967cba1a58"],[],[]]},{"id":"f0bd180120ee3da5","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","item":"ns=0;i=50083.Temp","datatype":"Boolean","value":"","name":"Temp","x":290,"y":480,"wires":[["fdaace6d400fbf2f"]]},{"id":"ba4e2ae132449f6a","type":"ui_gauge","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","name":"","group":"ba0d483bad0227fa","order":0,"width":0,"height":0,"gtype":"gage","title":"Temperature","label":"Β°C","format":"{{value}}","min":0,"max":"70","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":810,"y":480,"wires":[]},{"id":"c263a3a56c11f124","type":"inject","z":"b95c86e74dc9406f","g":"a59f375690802a42","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"0","payload":"true","payloadType":"bool","x":140,"y":620,"wires":[["0159ff1ef70e89d0"]]},{"id":"34bd45f333eab18a","type":"OpcUa-Client","z":"b95c86e74dc9406f","g":"a59f375690802a42","endpoint":"fd11cd9b5d90099e","action":"read","deadbandtype":"a","deadbandvalue":1,"time":10,"timeUnit":"s","certificate":"n","localfile":"","localkeyfile":"","securitymode":"None","securitypolicy":"None","useTransport":false,"maxChunkCount":1,"maxMessageSize":8192,"receiveBufferSize":8192,"sendBufferSize":8192,"setstatusandtime":false,"keepsessionalive":true,"name":"","x":460,"y":620,"wires":[["0aa25d33b342dc12"],[],[]]},{"id":"0159ff1ef70e89d0","type":"OpcUa-Item","z":"b95c86e74dc9406f","g":"a59f375690802a42","item":"ns=0;i=50069.Input","datatype":"Boolean","value":"","name":"Input","x":290,"y":620,"wires":[["34bd45f333eab18a"]]},{"id":"0aa25d33b342dc12","type":"ui_led","z":"b95c86e74dc9406f","g":"a59f375690802a42","order":0,"group":"bcd73c30755604c7","width":0,"height":0,"label":"Input1","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"false","valueType":"bool"},{"color":"#008000","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":630,"y":600,"wires":[]},{"id":"74ee90883bd52478","type":"ui_chart","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","name":"","group":"ba0d483bad0227fa","order":1,"width":0,"height":0,"label":"Temperature Chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":830,"y":420,"wires":[[]]},{"id":"47953c967cba1a58","type":"function","z":"b95c86e74dc9406f","g":"342ae34d18db20b0","name":"Round","func":"msg.payload = Number(msg.payload.toFixed(2))\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":460,"wires":[["74ee90883bd52478","ba4e2ae132449f6a"]]},{"id":"fd11cd9b5d90099e","type":"OpcUa-Endpoint","endpoint":"opc.tcp://192.168.1.42:4840","secpol":"None","secmode":"None","none":true,"login":false,"usercert":false,"usercertificate":"","userprivatekey":""},{"id":"85144921.8931b8","type":"ui_group","name":"OPTA Outputs","tab":"440c46c6.769ab8","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"f8b97d935f93f052","type":"ui_group","name":"OPTA LED","tab":"440c46c6.769ab8","order":3,"disp":true,"width":"6","collapse":false,"className":""},{"id":"ba0d483bad0227fa","type":"ui_group","name":"MD02 Sensor","tab":"440c46c6.769ab8","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"bcd73c30755604c7","type":"ui_group","name":"OPTA Inputs","tab":"440c46c6.769ab8","order":4,"disp":true,"width":"6","collapse":false,"className":""},{"id":"440c46c6.769ab8","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Created 6 months ago
  • inject (x2)
  • OpcUa-Client (x3)
  • OpcUa-Endpoint (x1)
  • OpcUa-Item (x7)
  • group (x3)
  • ui_chart (x1)
  • ui_gauge (x1)
  • ui_group (x4)
  • ui_led (x1)
  • ui_switch (x5)
  • OPC-UA
