Smick_006_analog_in_v2
This flow shows the use of analog sensors (potentiometer, LDR, ...). You will learn how to configure Smick to generate:
  • Measurement sequences read from the sensor;
  • The LOW event when measurements fall below a certain threshold;
  • The High event when measurements exceed a certain threshold. The associated dashboard allows you to:
  • Enable / disable these events;
  • Measurements of real-time display on a received indicator (gauge);
  • Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.
[{"id":"82283593.256f98","type":"link out","z":"c50576d5.b7af18","name":"command","links":["d00f3010.4b85b"],"x":935,"y":400,"wires":[]},{"id":"b05f8481.58d868","type":"comment","z":"c50576d5.b7af18","name":"actions on actuators","info":"","x":750,"y":300,"wires":[]},{"id":"182a53b5.e0602c","type":"comment","z":"c50576d5.b7af18","name":"actions on dashboard","info":"","x":760,"y":700,"wires":[]},{"id":"7b9c1fec.633c3","type":"e-mail","z":"c50576d5.b7af18","server":"smtp.gmail.com","port":"465","name":"[email protected]","dname":"mail","x":710,"y":500,"wires":[]},{"id":"68b0bc07.f7e484","type":"twitter out","z":"c50576d5.b7af18","twitter":"","name":"tweet","x":710,"y":560,"wires":[]},{"id":"92c8a391.39b3f","type":"comment","z":"c50576d5.b7af18","name":"actions on social","info":"","x":740,"y":440,"wires":[]},{"id":"dba2835f.b5b5d","type":"function","z":"c50576d5.b7af18","name":"alarm msg","func":"function timeDate(tz) {\n    var d = new Date(Date.now()+tz*3600000);\n\n    return  d.getUTCHours() + \":\" +\n            d.getUTCMinutes() + \":\" +\n            d.getUTCSeconds() + \" \" +\n            d.getUTCDate()\t+\"/\" +\n            (d.getUTCMonth()+1) + \"/\" +\n            d.getUTCFullYear();\n}\n\nmsg.payload=msg.payload + \" level alarm at \" + timeDate(1);\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":700,"wires":[["390ea4e5.d7bf1c","38b4d5ef.66eb5a"]]},{"id":"52b00a19.992274","type":"comment","z":"c50576d5.b7af18","name":"events","info":"","x":250,"y":320,"wires":[]},{"id":"e213e6f9.afc0c8","type":"comment","z":"c50576d5.b7af18","name":"Description","info":"Questo flusso mostra l'uso di sensori analogici (Potentiometer, LDR,...).\nSi apprenderà come configurare smick per generare:\n- sequenze di misure lette dal sensore;\n- l'evento LOW quando le misure scendono al di sotto di una soglia data;\n- l'evento HIGH quando le misure superano una soglia data.\nLa dashboard associata consente di:\n- abilitare/disabilitare i suddetti eventi;\n- di visualizzare in tempo reale le misure ricevute su un indicatore (gauge);\n- di visualizzare l'ultimo allarme LOW/HIGH rilevato ed inviato su e-mail e twitter.\n\n\nThis flow shows the use of analog sensors (potentiometer, LDR, ...).\nYou will learn how to configure Smick to generate:\n- Measurement sequences read from the sensor;\n- The LOW event when measurements fall below a certain threshold;\n- The High event when measurements exceed a certain threshold.\nThe associated dashboard allows you to:\n- Enable / disable these events;\n- Measurements of real-time display on a received indicator (gauge);\n- Displays the last LOW / HIGH detected and sent to e-mail alarm and Twitter.","x":110,"y":80,"wires":[]},{"id":"d2515f8c.357ef","type":"comment","z":"c50576d5.b7af18","name":"Licence & History","info":"Package : Smick v.1\nModule  : LED - digital output\nAuthor  : Curci\nLicence : (CC) BY-NC-SA\n\nThis work is licensed under a Creative Commons \nAttribution-NonCommercial-ShareAlike \n4.0 International License.\n\nHistory\n\nDate        Author  Description\n2016.12.17  Curci   genesis","x":280,"y":80,"wires":[]},{"id":"9b87b83d.556c68","type":"comment","z":"c50576d5.b7af18","name":"BOM","info":"Bill Of Material\n\nHardware:\n\n    1 Human internet terminal (PC, tablet or smartphone) connected to the internet\n    1 Smick Wi-Fi connected to the internet\n    1 Pot | LDR + 10kohm resistor\n\nHW Connections:\n\n    Device  pin     Smick pin\n    Pot     left    GND\n    Pot     center  A0\n    Pot     right   3.3V\n    \n    or \n    \n    Device  pin     Smick pin    \n    LDR     1       GND\n    LDR     2       A0\n    R 10k   1       A0\n    R 10k   2       GND\n\nFlow Connections:\n\n    Smick_001_console\n\nAccount:\n\n    Wi-Fi credentials\n    MQTT broker\n    FRED\n    E-mail\n    Twitter\n","x":430,"y":80,"wires":[]},{"id":"cad53aa1.dde3e8","type":"ui_gauge","z":"c50576d5.b7af18","name":"analogic sensor","group":"7c709b15.0385b4","order":2,"width":0,"height":0,"gtype":"gage","title":"sensor","label":"","format":"{{value}}","min":0,"max":"1023","colors":["#00b500","#e6e600","#ca3838"],"x":740,"y":900,"wires":[]},{"id":"71f47e0a.f5777","type":"comment","z":"c50576d5.b7af18","name":"enable/disable","info":"","x":740,"y":220,"wires":[]},{"id":"390ea4e5.d7bf1c","type":"debug","z":"c50576d5.b7af18","name":"","active":true,"console":"false","complete":"payload","x":730,"y":620,"wires":[]},{"id":"38b4d5ef.66eb5a","type":"ui_text","z":"c50576d5.b7af18","group":"7c709b15.0385b4","order":3,"width":0,"height":0,"name":"alarm msg","label":"last alarm","format":"{{msg.payload}}","layout":"col-center","x":730,"y":760,"wires":[]},{"id":"5d74af2b.64375","type":"ui_dropdown","z":"c50576d5.b7af18","name":"","label":"mode","group":"7c709b15.0385b4","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"disable","value":"A0==NULL","type":"str"},{"label":"enable","value":"A0@1","type":"str"},{"label":"set LOW alarm","value":"LOW==A0<340","type":"str"},{"label":"set HIGH alarm","value":"HIGH==A0>680","type":"str"}],"payload":"","topic":"","x":710,"y":360,"wires":[["82283593.256f98"]]},{"id":"da035eef.f0ae6","type":"debug","z":"c50576d5.b7af18","name":"","active":true,"console":"false","complete":"payload","x":730,"y":840,"wires":[]},{"id":"4a2e69f2.1bb9e8","type":"link in","z":"c50576d5.b7af18","name":"response_event","links":["290027bd.4e4828"],"x":195,"y":700,"wires":[["187b99d0.1afeb6"]]},{"id":"187b99d0.1afeb6","type":"switch","z":"c50576d5.b7af18","name":"parse","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"HIGH|LOW","vt":"str","case":false},{"t":"else"}],"checkall":"false","outputs":2,"x":310,"y":700,"wires":[["dba2835f.b5b5d","390ea4e5.d7bf1c"],["da035eef.f0ae6","cad53aa1.dde3e8"]]},{"id":"7c709b15.0385b4","type":"ui_group","z":"","name":"Analogic sensor","tab":"b07a13ec.60f27","order":1,"disp":true,"width":"6"},{"id":"b07a13ec.60f27","type":"ui_tab","z":"","name":"Analogic input","icon":"dashboard","order":5}]
Created 10 years, 9 months ago
  • comment (x8)
  • debug (x2)
  • link in (x1)
  • link out (x1)
  • switch (x1)
  • Smick
  • iot
