node-red-node-twitter 1.2.0
A Node-RED node to talk to Twitter
npm install node-red-node-twitter
Node-RED nodes to talk to Twitter.
The Twitter API will NOT deliver 100% of all tweets. This does NOT give access to the Twitter Firehose.
Tweets of who you follow will include their retweets and favourites.
Provides two nodes - one to receive messages, and one to send.
Input
Twitter input node. Can be used to search either:
  • the public or a user's stream for tweets containing the configured search term
  • all tweets by specific users
  • direct messages received by the authenticated user
Use space for and, and comma , for or when searching for multiple terms.
Sets the msg.topic to tweets/ and then appends the senders screen name.
Sets msg.location to the tweeters location if known.
When returning events it sets the msg.payload to the twitter event, a full list is documented by Twitter.
Sets msg.tweet to the full tweet object as documented by Twitter.
Note: This node is not connected to the FireHose, so will not return 100% of all tweets to a busy @id or #hashtag.
Note: when set to a specific user's tweets, or your direct messages, the node is subject to Twitter's API rate limiting. If you deploy the flows multiple times within a 15 minute window, you may exceed the limit and will see errors from the node. These errors will clear when the current 15 minute window passes.
Output
Tweets the msg.payload.
To send a Direct Message (DM) - use a payload like.
    D {username} {message}
If msg.media exists and is a Buffer object, this node will treat it as an image and attach it to the tweet.
If msg.params exists and is an object of name:value pairs, this node will treat it as parameters for the update request.
Version: 1.2.0
Updated 3 years, 4 months ago
Rating: 2.5 4
2465 in the last week
  • twitter-credentials
  • twitter in
  • twitter out
  • twitter
  • Nick O'Leary
  • Dave Conway-Jones
