Hive Hot Water boost control example.
A sample flow to control a Hive Thermostats hot water boost function.
The flow logs into the Hive website. Retrieves a list of nodes, finds the Hot Water Relay, and sets it in boost mode for 30 minutes.
Nodes to edit:
"Turn On" change the msg.action amount to be the number of minutes to run the boost
"Set Username and Password" Enter your hive website username and password
"Set Twitter Name" and "Tweet" Either remove these, or enter your details if you want to be notified that the flow was unable to login to Hive.
I use this with HA-Bridge / Domoticz / MQTT / Alexa to control my hot water at home.
With Alexa, I can say "Alexa, turn on the hot water" and she will run this flow (changing the start node to http inputs and calling from HA-Bridge). The native Alexa hive skill is more clunky, requiring "Alexa, tell hive to boost my hot water", and this always results in a 1 hour boost, which is too much.
[{"id":"5839ae0e.452f5","type":"http request","z":"e5a8dfd7.979f9","name":"Login to Hive","method":"POST","ret":"obj","url":"https://api-prod.bgchprod.info/omnia/auth/sessions","x":470,"y":220,"wires":[["594f91a4.a0ee9"]]},{"id":"809c9c17.bc751","type":"function","z":"e5a8dfd7.979f9","name":"Set Username and Password","func":"\nmsg.headers = {\n      'Content-Type' : 'application/vnd.alertme.zoo-6.1+json',\n      'Accept' : 'application/vnd.alertme.zoo-6.1+json',\n      'X-Omnia-Client' : 'Hive Web Dashboard'\n};\nmsg.payload = JSON.stringify({\n      sessions: [\n                  { username: \"EnterYourHiveUserIDHere\",\n                    password: \"EnterYourHivePasswordHere\",\n                    caller: \"WEB\" \n                  }\n                ]  \n    }\n)\n\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":120,"wires":[["5839ae0e.452f5"]]},{"id":"b0d60cf1.8e60e","type":"inject","z":"e5a8dfd7.979f9","name":"start","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":70,"y":80,"wires":[["6b7b6780.885978"]]},{"id":"47cadd4.87e7c24","type":"function","z":"e5a8dfd7.979f9","name":"set Hive request headers","func":"if(msg.payload.sessions !== undefined){\n\n    //save the session out to the msg so we can use it later on\n    msg.this_session = msg.payload.sessions[0].id;\n\n    msg.headers = {\n      'Content-Type' : 'application/vnd.alertme.zoo-6.1+json',\n      'Accept' : 'application/vnd.alertme.zoo-6.1+json',\n      'X-Omnia-Client' : 'Hive Web Dashboard',\n      'X-Omnia-Access-Token' : msg.this_session\n    }\n    return msg;\n}\n\nreturn null;","outputs":1,"noerr":0,"x":304,"y":289,"wires":[["c7941f64.4624e"]]},{"id":"c7941f64.4624e","type":"http request","z":"e5a8dfd7.979f9","name":"Get nodes from Hive","method":"GET","ret":"obj","url":"https://api-prod.bgchprod.info/omnia/nodes","tls":"","x":572,"y":289,"wires":[["dee54cb9.c29e8"]]},{"id":"dee54cb9.c29e8","type":"function","z":"e5a8dfd7.979f9","name":"Set Hot Water Boost","func":"\nvar hwnode = {};\n\nif(msg.payload.nodes !== undefined){\n    \n    var nodes = msg.payload.nodes;\n    \n    for (var n in nodes){\n        \n        var attribs = nodes[n].attributes;\n        \n        if(nodes[n].name==\"Receiver\"){\n            if(attribs.stateHotWaterRelay !== undefined){\n                hwnode = nodes[n];\n            }\n        }\n    }    \n}\n\nmsg.headers = {\n      'Content-Type' : 'application/vnd.alertme.zoo-6.1+json',\n      'Accept' : 'application/vnd.alertme.zoo-6.1+json',\n      'X-Omnia-Client' : 'Hive Web Dashboard',\n      'X-Omnia-Access-Token' : msg.this_session\n}\nmsg.url = \"https://api-prod.bgchprod.info/omnia/nodes/\"+hwnode.id;\nif (msg.action>0){\n    msg.payload =\n            { nodes:[{\n                    attributes : {\n                        activeHeatCoolMode: {targetValue:\"BOOST\"},\n                        scheduleLockDuration : {targetValue: msg.action}\n                    }\n                }]\n            };\n}else{\n    msg.payload =\n            { nodes:[{\n                    attributes : {\n                        activeHeatCoolMode: {targetValue:\"HEAT\"},\n                        activeScheduleLock : {targetValue: false}\n                    }\n                }]\n            };\n}\n\nreturn msg;\n\n","outputs":"1","noerr":0,"x":293,"y":376,"wires":[["22a00ef6.0a1722"]]},{"id":"5dcd6366.e89c7c","type":"function","z":"e5a8dfd7.979f9","name":"set Headers & URL for Logout","func":"msg.headers = {\n      'Content-Type' : 'application/vnd.alertme.zoo-6.1+json',\n      'Accept' : 'application/vnd.alertme.zoo-6.1+json',\n      'X-Omnia-Client' : 'Hive Web Dashboard',\n      'X-Omnia-Access-Token' : msg.this_session\n}\nmsg.url = \"https://api-prod.bgchprod.info/omnia/auth/sessions/\"+msg.this_session\n\nreturn msg;","outputs":1,"noerr":0,"x":330,"y":460,"wires":[["4bfb765c.f96cd8"]]},{"id":"4bfb765c.f96cd8","type":"http request","z":"e5a8dfd7.979f9","name":"logout from Hive","method":"DELETE","ret":"txt","url":"","tls":"","x":580,"y":460,"wires":[[]]},{"id":"594f91a4.a0ee9","type":"switch","z":"e5a8dfd7.979f9","name":"Logged In?","property":"statusCode","rules":[{"t":"neq","v":"200"},{"t":"eq","v":"200"}],"checkall":"true","outputs":2,"x":649,"y":219,"wires":[["2d68f050.f355"],["47cadd4.87e7c24"]]},{"id":"e41d7b0d.7fd448","type":"twitter out","z":"e5a8dfd7.979f9","twitter":"","name":"Tweet","x":970,"y":160,"wires":[]},{"id":"2d68f050.f355","type":"function","z":"e5a8dfd7.979f9","name":"Set Twitter Name","func":"msg.payload = \"D YourTwitterName unable to login to hive status code \"+msg.statusCode;\nreturn msg;","outputs":1,"noerr":0,"x":810,"y":160,"wires":[["e41d7b0d.7fd448"]]},{"id":"22a00ef6.0a1722","type":"http request","z":"e5a8dfd7.979f9","name":"Send Hot Water Boost","method":"PUT","ret":"obj","url":"","tls":"","x":561,"y":378,"wires":[["5dcd6366.e89c7c"]]},{"id":"6b7b6780.885978","type":"function","z":"e5a8dfd7.979f9","name":"Turn On","func":"//set the number of minutes that we want the HW boost to \n//be active for.  Set to 0 to turn off (see Turn Off node)\nmsg.action = 30;\nreturn msg;","outputs":1,"noerr":0,"x":220,"y":80,"wires":[["809c9c17.bc751"]]},{"id":"7c89c8c5.0c5d08","type":"inject","z":"e5a8dfd7.979f9","name":"start","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":70,"y":160,"wires":[["21b09c74.0102b4"]]},{"id":"21b09c74.0102b4","type":"function","z":"e5a8dfd7.979f9","name":"Turn Off","func":"//set the msg.action to zero to turn off the HW boost\nmsg.action = 0;\nreturn msg;","outputs":1,"noerr":0,"x":220,"y":160,"wires":[["809c9c17.bc751"]]},{"id":"7e807621.28c428","type":"comment","z":"e5a8dfd7.979f9","name":"Edit this node","info":"adding your own Hive website username and password","x":470,"y":80,"wires":[]},{"id":"f52799b7.d68fb8","type":"comment","z":"e5a8dfd7.979f9","name":"Edit these node, or remove them","info":"Either remove these nodes if you dont want to\ntweet a failed login, or add your twitter \ncredentials and set the message text ","x":870,"y":120,"wires":[]}]
Created 10 years, 9 months ago
Updated 7 years ago
  • comment (x2)
  • function (x7)
  • http request (x4)
  • inject (x2)
  • switch (x1)
  • Hive
  • Thermostat
  • Hot-water
  • boost
  • british
  • gas
