victron-vrm-api 0.5.0
Interface with the Victron Energy VRM API
npm install victron-vrm-api
This node makes it easy to use the VRM API for data retrieval. Though not all possible API calls have been implemented, it can be used for retrieving and creating alarms and fetching installations statistics. It can also be used to retrieve the solar forecast data.
VRM API flow
In order to allow the node to query your site, an access-token needs to be created and filled out in the configuration node.
Inputs
  • payload (string|number|json) - the trigger to query the VRM API
Outputs
  • payload (json) : the VRM answer
The output of the answer depends on the selected configuration. See the VRM API documentation in case you need assistance with interpreting the output.
  • Name (string) : The name of the node
  • VRM (config) : The configuration node
  • VRM site id (number) : The site to query. Note that this is the multi-digit number you see in the url of your vrm-site like this: https://vrm.victronenergy.com/installation/123456/
  • API type (string) : The query type
  • Verbose (boolean) : Show the used url in the debug tab?
There are currently 4 API types to choose from:
  • Users
  • Installations
  • Widgets
  • Dynamic ESS
Depending on the API type, more or less extra fields appear.
In case of installation stats there appear some extra configuration options
  • Attribute (string) : Which attribute to fetch
  • Interval (string) : Time between retrieved data points
  • Start (integer) : Timestamp from which to fetch data
  • End (integer) : Timestamp to which to fetch data
In case of installation `dess`` there are even more configuration options.
VRM API edit panel
Note that instead of filling out the number of the VRM site id for installations and widgets in the box, you can also use context variables, e.g. {{flow.siteId}} or {{global.vrmId}}. This allows to query the site that has been set in this context field. Of course you need to make sure that context contains a valid VRM site id first.
Examples
There are several examples included in the package. In order to use them, import them via the victron-vrm-api examples dropdown on the Import nodes page (accessible via the menu or by pressing ctrl-i).
Advanced usage
For advanced use cases where you need to query VRM API endpoints not yet implemented in the node, or even external APIs, you can use the custom query feature by sending specific message properties.
Requirements
To use the custom query feature, your message must include:
  • msg.method - The HTTP method (GET, POST, or PATCH)
  • msg.query - The API endpoint path
Optional properties
  • msg.url - Custom base URL (defaults to "https://vrmapi.victronenergy.com/v2")
  • msg.topic - Custom topic for the response (defaults to "custom")
  • msg.payload - Request body (for POST and PATCH methods)
How URL Construction Works
The final URL is constructed as follows:
finalURL = (msg.url || 'https://vrmapi.victronenergy.com/v2') + '/' + msg.query
References
Please use either the issues on the GitHub site or the Node-RED space on our community for questions, troubleshooting and suggestions.
Version: 0.5.0
Updated 1 month, 1 week ago
Rating: 4.2 5
388 in the last week
  • config-vrm-api
  • vrm-api
  • victron
  • vrm
  • api
