vhv5-barcode-reader 0.1.8
Node-RED node for reading barcode and metadata JSON from an Omron VHV5 websocket endpoint.
npm install vhv5-barcode-reader
VHV5 Barcode Reader
Node-RED package with one VHV5 websocket reader node that emits two JSON outputs.
Install the npm package with npm install vhv5-barcode-reader.
Patch Notes
0.1.7
  • Fixed VHV5 websocket frame handling so MessagePack payloads are decoded correctly even when the websocket message is delivered as a buffer with an incorrect text/binary flag.
  • Fixed barcode extraction to prefer live VHV5 result fields such as outDataUTF8 and dataUTF8 instead of returning Base64 payload content.
  • Fixed symbology extraction to use the actual result type from the decoded VHV5 read event.
  • Added a regression test covering the live-style VHV5 ReaderReport payload shape.
Behavior
  • requires user input into Barcode readers IP address
  • Connects to Websocket of barcode reader
  • extracts metadata and transforms into JSON formatting
  • Extracts barcode-like fields from decoded VHV5 events.
  • Reconnects automatically after disconnects.
Outputs
Output 1 sends one message per successful read:
  "topic": "vhv5/barcode",
  "payload": {
    "barcode": "0041199006794",
    "symbology": "EAN13",
    "received_at": "2026-07-06T18:00:00.000Z",
    "host": "192.168.250.55",
    "port": 9003
Output 2 sends one message per successful read:
  "topic": "vhv5/barcode/metadata",
  "payload": {
    "image_key": "123456",
    "result_count": 1,
    "frame_format": "msgpack",
    "decoded_type": "object",
    "source": {
      "port": 9003,
      "websocket_url": "ws://192.168.250.55:9003"
    "event": {}
Example Flow
Import examples/vhv5-barcode-example.json into Node-RED, set the VHV5 host address, then deploy. The flow sends the barcode and metadata outputs to separate Debug sidebar entries.
Files
  • package.json: package manifest
  • vhv5-barcode-reader.js: runtime registration for the Node-RED node
  • vhv5-barcode-reader.html: editor UI for the Node-RED node
  • lib/vhv5-decoder.js: shared websocket decode and barcode extraction logic
Local Use
  1. Run npm.cmd install in this folder.
  2. In your Node-RED user directory, run npm.cmd install <path-to-this-folder>.
  3. Restart Node-RED.
  4. Add VHV5 Barcode to a flow.
Bugs
Report issues to the maintainer.
Version: 0.1.8
Updated 3 months ago
  • vhv5-barcode
  • omron
  • vhv5
  • barcode
  • websocket
  • msgpack
