tangbao-he-db-helper 1.0.30
MyBatis-style database helper for Node-RED with CRUD, SQL mapper, and multi-database support
npm install tangbao-he-db-helper
MyBatis-style database helper for Node-RED with MySQL and SQLite support.
  • SQL Mapper: Template engine with #{param}, ${param}, <if>, <foreach>
  • Query Node: Dedicated SELECT node for safe and simple query operations
  • CRUD Node: Pre-built operations like selectById, insert, updateById, etc.
  • MySQL: Connection pool, auto-reconnect, health check, multiple statements
  • SQLite: File-based local database, zero-config, no network required
  • Result Mapping: Auto snake_case to camelCase conversion
  • Transaction Support: withTransaction for safe batch operations
  • Dynamic Parameters: msg.tableName, msg.params, msg.operation for runtime flexibility
  • Array IN Support: Array values in conditions are automatically converted to IN (...)
  • Error Resilience: Database connection errors are caught and logged, never crash Node-RED
Node Type Description
tangbao-db-config Config Database connection settings (MySQL or SQLite)
tangbao-sql-mapper Config Reusable SQL templates
tangbao-db-query Flow Execute SELECT queries with SQL templates
tangbao-db-execute Flow Execute INSERT/UPDATE/DELETE with SQL templates
tangbao-db-crud Flow Pre-built CRUD operations (selectById, insert, updateById, etc.)
Requirements
  • Node.js >= 18.0
  • Node-RED >= 4.0.0
  • For SQLite support: better-sqlite3 >= 12.0.0 (installed separately)
Or install from a local .tgz file:
npm install /path/to/tangbao-he-db-helper-*.tgz
For SQLite support, also install:
npm install better-sqlite3
Then restart Node-RED.
Node Details
tangbao-db-config
Database connection configuration node. Supports both MySQL and SQLite.
Driver Selection:
Driver Use Case Required Extra Dependency
MySQL (default) Remote/centralized database mysql2 (auto-installed)
SQLite Local file database, embedded better-sqlite3 (manual install)
When you select a driver in the configuration panel, the available fields automatically switch:
  • MySQL: Host, Port, User, Password, Database, Charset, Timezone, Connection Pool Limit
  • SQLite: Database File Path only (e.g., /data/mydb.db or ./mydb.db)
MySQL Settings:
  • Host, Port, Database
  • User / Password (stored in Node-RED credentials, encrypted at rest)
  • Charset (default: UTF8_GENERAL_CI)
  • Timezone (default: local)
  • Connection Pool Limit (default: 50)
SQLite Settings:
  • Database File Path: Absolute or relative path to the .db file. If the file does not exist, it will be created automatically.
tangbao-sql-mapper
Config node for reusable SQL templates. Supports dynamic parameters and conditional logic.
Template Syntax:
  • #{param} — Parameter placeholder (prepared statement, safe from SQL injection)
  • ${param} — Direct string replacement (use with caution)
  • <if test="condition">...</if> — Conditional block
  • <foreach collection="list" item="item" open="(" separator="," close=")">#{item}</foreach> — Loop
Example:
SELECT * FROM ${tableName}
<where>
  <if test="name != null">AND name = #{name}</if>
  <if test="age != null">AND age > #{age}</if>
</where>
tangbao-db-query
Execute SELECT queries using SQL templates, SQL mapper, or raw SQL. Results are returned as an array in msg.payload.
Inputs:
  • msg.sql — Dynamic SQL (priority over node config and SQL mapper)
  • msg.params — SQL template parameters
  • msg.payload — Fallback for params
Outputs:
  • msg.payload — Query result array
Example:
msg.sql = "SELECT * FROM user WHERE status = #{status} ORDER BY id DESC";
msg.params = { status: 1 };
tangbao-db-execute
Execute SQL operations (INSERT/UPDATE/DELETE/SELECT) using SQL templates, SQL mapper, or raw SQL. Automatically detects query vs write operations based on SQL statement type.
Inputs:
Outputs:
  • For SELECT queries: msg.payload — Result array
  • For INSERT/UPDATE/DELETE: msg.payload — Object with affectedRows, insertId, changedRows
Example:
msg.sql = "UPDATE user SET name = #{name} WHERE id = #{id}";
msg.params = { id: 1, name: "Alice" };
tangbao-db-crud
Pre-built CRUD operations. No SQL writing needed.
Operations:
Operation Description Params Example SQLite Compatible
selectById Query by ID {id: 1} Yes
selectOne Query single by conditions {name: "Alice"} Yes
selectList Query list by conditions {status: 1} Yes
selectCount Count by conditions {status: 1} Yes
selectByIds Query by ID list [1, 2, 3] Yes
selectPage Paginated query {status: 1, pageNum: 1, pageSize: 10} Yes
insert Insert full fields {name: "Alice", age: 20} Yes
insertSelective Insert non-null fields {name: "Alice"} Yes
insertBatch Batch insert [{name: "A"}, {name: "B"}] Yes
updateById Update full fields by ID {id: 1, name: "Bob", age: 21} Yes
updateSelectiveById Update non-null fields by ID {id: 1, name: "Bob"} Yes
deleteById Delete by ID {id: 1} Yes
deleteByIds Delete by ID list [1, 2, 3] Yes
deleteAndInsertBatch Clear table and batch insert [{name: "A"}, {name: "B"}] Yes
upsertBatch Batch insert or update [{id: 1, name: "A"}] Yes (see note below)
SQLite Upsert Note: SQLite uses ON CONFLICT(id) DO UPDATE SET col = excluded.col instead of MySQL's ON DUPLICATE KEY UPDATE col = VALUES(col). The CRUD node automatically selects the correct syntax based on your configured driver.
Important: For upsertBatch to work with SQLite, the target table must have a PRIMARY KEY or UNIQUE constraint on the idColumn. Otherwise SQLite will raise a conflict resolution error.
Array to IN:
For selectList, selectOne, selectCount, and selectPage, array values are automatically converted to IN conditions:
msg.params = { equip_type_id: [1212101, 1212102] };
// Generates: WHERE equip_type_id IN (?, ?)
Range / Operator Query:
You can use object-style operators for range queries in selectList, selectOne, selectCount, and selectPage:
Operator SQL Generated Example Value
$eq = { $eq: 'active' }
$ne != { $ne: 0 }
$gt > { $gt: 1 }
$gte >= { $gte: '2025-01-01' }
$lt < { $lt: 100 }
$lte <= { $lte: '2025-12-31' }
$like LIKE { $like: '%error%' }
$between >= AND <= { $between: ['2025-01-01', '2025-12-31'] }
msg.params = {
  pageNum: 1,
  pageSize: 20,
  alarm_time: { $gte: '2025-12-07 00:00:00', $lte: '2026-06-05 23:59:59' },
  alarm_level: { $gt: 1 },
  alarm_desc: { $like: '%高温%' }
// Generates: WHERE alarm_time >= ? AND alarm_time <= ? AND alarm_level > ? AND alarm_desc LIKE ?
selectPage Output:
Returns a pagination object including total count:
  "list": [...],
  "total": 100,
  "pageNum": 1,
  "pageSize": 10,
  "pages": 10
Dynamic Usage:
Use msg.tableName, msg.params, msg.operation to operate on different tables with the same node:
// First message
msg.tableName = "user";
// Second message
msg.tableName = "order";
msg.params = { status: 2 };
Result Mapping (结果映射):
在数据库表字段通常使用下划线命名(如 user_name),而前端/JavaScript 中更习惯驼峰命名(如 userName)。结果映射用于自动转换查询结果的字段名。
选项 说明 示例
camelCase 下划线转驼峰 user_name → userName
none 不转换,保持原样 user_name → user_name
// 数据库返回: [{ user_name: "Alice", user_age: 20 }]
// 启用 camelCase 结果映射后,msg.payload:
[{ userName: "Alice", userAge: 20 }]
Param Mapping (参数映射):
参数映射用于在发送 SQL 之前,自动将传入参数的键名转换为数据库字段命名风格。这在你的前端传入驼峰命名参数,而数据库表使用下划线命名时非常有用。
选项 说明 示例
snakeCase 驼峰转下划线 { userName: "Alice" } → { user_name: "Alice" }
none 不转换,保持原样 { userName: "Alice" } → { userName: "Alice" }
// 前端传入
msg.params = { userName: "Alice", userAge: 20 };
// 启用 snakeCase 参数映射后,实际生成的 SQL:
// INSERT INTO user (user_name, user_age) VALUES (?, ?)
注意: 结果映射与参数映射相互独立,可按需分别设置。例如:
  • 前端 ↔ 数据库命名风格不一致:参数映射设为 snakeCase,结果映射设为 camelCase,实现全自动转换。
  • 前后端风格一致:两者均设为 none,不做任何转换。
Auto Table Loading (自动加载表名):
在配置 tangbao-db-crud 节点时,只需先选择数据库配置(tangbao-db-config),表名下拉框会自动从该数据库加载所有表名供你选择,无需手动输入。如果数据库连接尚未部署或无法访问,也可以点击右侧"自定义输入"按钮直接手写表名。
SQLite Usage Example
  1. Install better-sqlite3:
  2. Restart Node-RED.
  3. Create a tangbao-db-config node, select SQLite as the driver, and enter the database file path (e.g., ./data.db or an absolute path like /data/mydb.db).
  4. Use tangbao-db-crud or tangbao-db-query / tangbao-db-execute as usual. All CRUD operations work the same way.
SQLite vs MySQL Quick Reference
Feature MySQL SQLite
Connection TCP (host:port) Local file
Auth User / Password None
Pooling Yes (configurable) No (single connection)
Auto-reconnect Yes N/A
upsertBatch ON DUPLICATE KEY UPDATE ON CONFLICT DO UPDATE (requires PK/UNIQUE)
deleteAndInsertBatch Transaction Transaction
Table discovery information_schema sqlite_master
Multi-statement execute Supported with params Supported without params
Logging Configuration (日志配置)
本节点包使用 node.log / node.error 输出运行日志,其输出级别受 Node-RED 全局日志配置控制。
如需调整日志输出级别或关闭日志,请编辑 Node-RED 的 settings.js 文件:
logging: {
    console: {
        level: "info",    // 可选: trace, debug, info, warn, error, fatal
        metrics: false,
        audit: false
级别 效果
trace / debug 输出所有日志(包括 SQL 调试信息)
info 默认级别,输出 SQL 执行信息和错误
warn 仅输出警告和错误,隐藏常规 SQL 日志
error / fatal 仅输出错误信息
注意: Node-RED 目前没有为单个节点包单独设置日志级别的机制,上述配置为全局生效。建议在开发环境使用 info,生产环境使用 warn 或 error 以减少日志噪音。
Examples
See the examples/ folder for sample flows:
  • CRUD Example.json — CRUD operations demo
  • Execute Example.json — Custom SQL execution demo
  • Query Example.json — SELECT query demo
MIT
Version: 1.0.30
Updated 4 months, 3 weeks ago
Rating: 5.0 3
222 in the last week
  • tangbao-db-config
  • tangbao-sql-mapper
  • tangbao-db-query
  • tangbao-db-execute
  • tangbao-db-crud
  • database
  • mybatis
  • sql
  • crud
  • mysql
  • postgresql
  • sqlite
