tams-plc-order-get 1.0.50
Provides a set of nodes to Node-RED to help control tams.
This module is tams-plc-order-get node.
These nodes require node.js version 12 or more recent.
From version 2.10.0 you can create and install widget nodes like other Node-RED nodes.
Pre-requisites
The Node-RED-Dashboard requires Node-RED to be installed.
To install the node run the following from your Node-RED user directory (~/.node-red
npm install tams-plc-order-get
Or install the node from the Palette section of your Node-RED editor by searching by name (tams-plc-order-get
