sqlite-plugin-red 0.0.3
Adding a tab to show and edit the structure of a sqlite database. Needs node-red-node-sqlite.
npm install sqlite-plugin-red
Sqlite Tab RED
Adding a sidebar tab for Node-RED to show and edit sqlite database structures
Requirements
Requires the Node-RED node: node-red-node-sqlite.
Instructions
The UI will help you to visualize and create your sqlite database, all within Node-RED.
  • Select, create or delete your your sqlite database files in the first row.
  • Select, create, rename or delete your tables in the second row.
  • If a table is selected you can add, remove or change your sqlite table columns.
  • If done press the confirm button.
Screenshot of a the Sqlite Tab.
Notes
There is currently no input safeproof implemented, as sqlite will return an error if something is not correct. For example: Creating a autoincrement column without setting the column to INTEGER.
This will be planned in the future.
Developers
If you want to modify something inside the sqlite-plugin-red.html file, I recommend to use SIR.
With help of SIR you can handle the sqlite-plugin-red.svelte file in which the code is much cleaner and easier to handle.
Version: 0.0.3
Updated 5 years, 8 months ago
Rating: 4.0 3
62 in the last week
  • sqlite-plugin-red
  • sqlite
  • database
  • db
  • sql
