smithtek-node-red-remot3 1.2.0
**Installation** Install using the `NodeRED palette manager` smithtek-node-red-remot3
npm install smithtek-node-red-remot3
Installation Install using the NodeRED palette manager smithtek-node-red-remot3
The remoteit nodes allow you to connect your pass-port node red instance to the remote3.it service. From the flow editor you can configure and deploy HTTP, or SSH services. To use the service you must have a www.remot3.it account. It allows you to effortlessly setup secure access to your node red so you can configure from anywhere in the world.
enter image description here
Settings / Register Device
You must have a valid account with remot3.it. /using your account username email and password you can register your node red to the remote service. You must be connected to the internet for the device to connect and register. properties are as follows: If using this node on non Smithtek devices you must also install remoteit sudo apt install remoteit
  • Email
  • Password
  • Device Name
  • select service
  • Service Name
  • Service Port
User Email
Email address you have with your remot3.it account.string
User Password
The password you have with your remot3.it account. string
When you enter the above the node will work for a short while trying to connect to the service. When it is connected to the service you will be able to add and register your device.
Device name
Add a name to your device. It will automatically add "passport" to your chosen name. Example joeblogs will result in "passport_joeblogs.string
Select Service
From the dropdown box, add a service, currently only HTTP and SSH is available.
Service Name
Name your service. string
Service port
Select a port number for your added service. Make sure it follows your system rules with regards to ports available. integer
Remove service
This will remove the added service from your node red and your remot3.it webservice. Warning, this cannot be undone
Copyright (c) 2021 www.smithtek.com.au Licenced under the terms of the GPLv3
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL DAMIEN CLARK BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Acknowledgements
We would like to thank the following people for their hard word, time and
  • Sensorhub.tech
  • Nick O'Leary and Dave Conway-Jones for creating Node-Red
Version: 1.2.0
Updated 5 years, 9 months ago
License: GPL-3.0
1 in the last week
  • smithtek-node-red-remot3
  • node-red-contrib
  • node
  • iot
  • smithtek
