red-contrib-loop-energy-meter 0.1.0
Socket access to loop energy saver service.
Loop Energy Meter Node
This is a very simple NodeRed node for the Loop Energy Saver, a realtime energy monitoring device.
There is no official API, but the dashboard uses a WebSocket service to display current usage data. Inspired by Loop Energy Meter API HTTP Proxy, this simple Node effectively listens for the electric_realtime event to obtain realtime data from the loop energy saver.
Deployment
Note the configuration that is required, serial and secret credentials. You can get these values
by logging into your-loop.com, opening your browser's console, and typing in
Drupal.settings.navetas_realtime - the returned JSON object contains these values.
These values can then be set in the nodes properties.
Releases
0.1.0
Initial version
