red-contrib-eyahd-taiponrock 1.0.1
creating node and publish it
node-red-contrib-eyahd-taiponrock
Overview
This node is a node for forcibly converting all the alphabet character strings passed as input to the character string "Eya-Taiponrock". Even if the input parameter passed is not a character string, "Eya-Taiponrock" is forcibly returned. In this process, it is a wonderful node that changed the sample node that was executing toLowerCase, which is an instance method of String object in JavaScript, to a process that just returns a meaningless constant.
how to use
It is used when you want to forcibly convert all the character strings of the parameters to be passed to "Eya-Taiponrock".
