rbflurry-node-red-contrib-bounding-box 0.0.4
A Node-RED custom node that processes and draws bounding boxes
npm install rbflurry-node-red-contrib-bounding-box
node-red-contrib-post-object-detection
This is a custom Node-RED node that draws bounding boxes from an Object Detection model.
Prerequisite
This custom Node-RED node leverages the `node-canvas` npm package to draw the bounding
boxes on a image. Please make sure the platform running Node-RED fulfills the
prerequisites listed [here](https://www.npmjs.com/package/canvas#compiling). For
example, while using Ubuntu, you need to run the following command to install
the dependencies:
sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
### Install this module:
Once you install the peer dependency and the prerequisites, you can install this module:
npm install node-red-contrib-post-object-detection
## Usage
There are two custom Node-RED nodes in this package:
- `bbox-image`: This is used to annotate an input original image with bounding boxes.
### `bbox-image` node
The `msg.payload` passed to this node should be an object containing these two
properties:
- `image`: The image data in `Buffer` data type
- `objects`: An object array containing a list of detected objects.
             Each object has the following information:
{ bbox: [x, y, w, h], className: string, score: number }
This node annotates the image by drawing the bounding boxes of detected objects onto it.
This annotated image is then output as a `Buffer` for the next node.
Version: 0.0.4
Updated 6 years, 10 months ago
Rating: 1.0 1
3 in the last week
  • Bounding-Box
  • Node-RED
