rb-iot-node-red 1.0.1
Ringbeller IoT Node-RED Nodes & Flows
npm install rb-iot-node-red
This Node-RED module implements the Ringbeller IoT node bindings API. It also includes sample flows for testing the nodes.
Prerequisites
  1. Node v14
  2. Node-RED v1.2.9
Install dependencies
# Install Node.js
$ curl -sL https://deb.nodesource.com/setup_14.x | sudo bash -
$ sudo apt-get install -y nodejs
# Install Node-RED
$ sudo npm install -g --unsafe-perm node-red
# Install audio packages
$ sudo apt-get install -y libasound2-dev libsndfile1-dev
Local installation
# Build module
$ npm install
# In Node-RED directory:
$ npm install <path to location of module>
Installation via npm
$ npm install rb-iot-node-red
Run tests
# Run unit tests
$ npm test
# Generate code coverage report
$ npm run test:coverage
The following nodes are available with this module:
Flows
These sample flows can be imported from the example folder:
Configures the modem
Chat
Sends & receives messages
IVR
Plays audio based on keypad input.
Version: 1.0.1
Updated 6 years, 2 months ago
4 in the last week
  • send-sms
  • receive-sms
  • send-mms
  • mms-config
  • place-call
  • receive-call
  • get-call-status
  • end-call
  • begin-audio-playback
  • end-audio-playback
  • wait-for-audio-playback
  • begin-audio-recording
  • end-audio-recording
  • get-keypad-input
  • connect
  • configure
  • settings
