postgrestor-fork-ymedlop 0.0.2
temporal fork from postgrestor
npm install postgrestor-fork-ymedlop
Postgrestor :space_invader: is a Node-RED node allowing basic access to Postgres :elephant: database.
Postgrestor sets up a console to execute queries against the configured database.
msg.payload will contain the result object of the query. It has the following properties:
  • command: The sql command that was executed (e.g. "SELECT", "UPDATE", etc.)
  • rowCount: The number of rows affected by the SQL statement
  • oid: The oid returned
  • rows: An array of rows
Postgres implements a template engine allowing parameterized queries:
/* INTEGER id COLUMN */
SELECT * FROM table WHERE id = {{ msg.id }}
/* VARCHAR id COLUMN */
SELECT * FROM table WHERE id = '{{ msg.id }}'
Using the Node-RED Editor
From version 0.15 of Node-RED you can install Postgrestor directly using the editor. To do this select Manage Palette from the menu (top right), and then select the install tab in the palette.
You can now search for Postgrestor to install.
Installing npm packaged nodes
To install Postgrestor npm-packaged node, you can also, either install it locally within your user data directory (by default, $HOME/.node-red):
cd $HOME/.node-red
npm i postgrestor
or globally alongside Node-RED:
npm i -g posgtrestor
You will need to restart Node-RED for it to pick-up Postgrestor.
NPM
Screen shots
Version: 0.0.2
Updated 1 month ago
License: Apache
0 in the last day
1 in the last week
10 in the last month
  • postgresDB
  • postgrestor
  • postgresql
  • postgres
  • ymedlop
