ogema-io 0.0.2
Input and output nodes to access the OGEMA 2.0 resource graph
npm install ogema-io
ogema
Pre-requisite
You will need an OGEMA 2.0 framework running on a java platform. See http://www.ogema.org/ for an open source version for PC or raspberry pi. You will also need the mqtt-server App installed on the OGEMA-platform.
Run the following command to install the ogema node globally.
    npm -g i ogema-io
For detailed information about the usage of this node and an example flow visit https://www.ogema-source.net/wiki/display/OGEMA/ogema-io+for+node-red
MIT license
Version: 0.0.2
Updated 9 years ago
2 in the last week
  • ogema in
  • ogema out
  • OG-broker
  • ogema
  • iot
  • interoperability
