nr-energyschedule 1.0.0
Node-RED Implementation of the Energy Schedule API
npm install nr-energyschedule
nr-energyschedule
A Node-RED node for smart energy consumption scheduling based on the Corrently GrünstromIndex (GreenPowerIndex). This node helps optimize the energy consumption of your devices by scheduling their operation during periods of favorable electricity conditions - whether that's lowest cost, highest renewable energy content, or maximum user comfort.
Description
The Energy Schedule node uses the Corrently API to create and manage energy consumption schedules. It's designed for the German energy market and uses the GrünstromIndex to determine optimal operation times for electrical devices and systems.
Key Features
  • Optimize for different goals (price, CO2 emissions, or comfort)
  • Flexible scheduling with configurable active hours
  • Support for consecutive and non-consecutive operation periods
  • Real-time status monitoring
  • Persistent schedule tracking across Node-RED restarts
  • Simple boolean output for easy device control
  • Detailed schedule information for advanced use cases
Use Cases
  1. Smart Home Appliances
    • Schedule washing machines to run during cheap/green energy periods
    • Optimize dishwasher operation for overnight running
    • Control water heaters based on energy availability
  2. Electric Vehicle Charging
    • Smart charging when renewable energy is abundant
    • Cost-optimized charging schedules
    • CO2-minimized charging patterns
  3. Heat Pump Management
    • Optimize heating cycles based on energy prices
    • Buffer heat during green energy periods
    • Balance comfort and efficiency
  4. Energy Storage Systems
    • Schedule battery charging during optimal periods
    • Support grid stability through smart timing
    • Maximize self-consumption of solar energy
Prerequisites
  • Location must be in Germany (uses German postal codes/Postleitzahl)
  • Node-RED installation
  • Optional: Personal API token from Corrently Console
or install via the Node-RED Palette Manager.
Node Settings
  • Name: Optional node name
  • ZIP: German postal code (Postleitzahl) for location-specific scheduling
  • Personal Token: Your Corrently API token (optional)
  • Law: Optimization strategy
    • comfort: Optimize for user convenience (default)
    • price: Optimize for lowest electricity cost
    • co2: Optimize for lowest CO2 emissions
  • Coverage Hours: How many hours ahead to schedule (default: 24)
  • Active Hours: Required operation hours within coverage period (default: 1)
  • Consecutive Hours: Whether operation hours must be consecutive (default: true)
Input
The node accepts a payload with scheduling requirements:
    "zip": "69168",                    // Optional: override configured ZIP
    "coverageHours": 24,              // Optional: override configured coverage
    "requirements": {
        "law": "price",               // Optional: override configured law
        "activeHours": 4,             // Optional: override configured hours
        "consecutiveHours": true,     // Optional: override configured setting
        "energyDemand": 10,           // Required energy in kWh
        "maxLoad": 3500,              // Maximum power in watts
        "avgLoad": 2000               // Average power in watts
Outputs
  1. Status Output (first output)
        "payload": true  // or false - indicates if schedule is currently active
  2. Details Output (second output)
        "payload": {
            "scheduleId": "...",
            "timeSlots": [...],
            "progress": {...},
            // Additional schedule details
Example Flows
Example flows are included in the exsamples directory:
  • basic-schedule-flow.json: Basic washing machine scheduling
  • ev-charging-flow.json: Electric vehicle charging optimization
  • dynamic-requirements-flow.json: Dynamic requirement calculation
Limitations
  • Geographic Restriction: This node only works in Germany as it relies on the GrünstromIndex (GreenPowerIndex) which is specifically designed for the German energy market.
  • ZIP Code Required: A valid German postal code (Postleitzahl) is required for proper operation.
  • API Rate Limits: May apply depending on your Corrently API access level.
Apache-2.0
Credits
  • Uses the Corrently API and GrünstromIndex
  • Developed for the Node-RED community
Version: 1.0.0
Updated 2 years, 1 month ago
3 in the last week
  • energy-schedule
  • energyschedule
  • electricity
  • fahrplanmanagement
  • corrently
