nodered-lutron-caseta 1.0.2
Lutron Caseta integration with Nodered
npm install nodered-lutron-caseta
Node for Lutron devices on node-red
Configuraiton
During configuration of the lutron node you have to provide the ip address of the Lutron Caseta Pro HUB. This module does not work with the basic version of the HUB as telnet connection is diabled on it. You will need to log into the lutron app and enable telnet.
The 2nd part of the configuration is to enter the switch ID and map it to a name. I did not find any clean way to query the device ID to name mapping form the HUB so it's a manual step.
To identify the device ID to name mapping you can create a status node with DEVICE set to "ALL", connect the output of this node to a debug node and it will show you all the devices as they change status. After this you can flip any of the device on this hub and it will show you ID for the device.
Version: 1.0.2
Rating: 1.5 6
12 in the last week
  • lutron-config
  • lutron-status
  • lutron-control
  • lutron
  • caseta
  • dimmer
  • light
  • switch
  • node
