nodered-contrib-sms77 3.2.2
sms77 node collection for Node-RED.
npm install nodered-contrib-sms77
Node-RED node collection for sending SMS , text-to-speech calls and number validation via sms77.
Run the following command in your Node-RED user directory - usually ~/.node-red:
NPM npm install nodered-contrib-sms77
Yarn yarn add nodered-contrib-sms77
Request Options
sms77-config node
API Key: An API key from sms77 - create one in your developer dashboard.
Name: An arbitrary name for the node, helpful if you use multiple configurations.
sms77-sms node
Use this node for sending SMS.
Config*: A sms77-config node.
Message*: The SMS text which defaults to msg.payload. May not exceed 1520 characters.
*Recipient(s)**: SMS recipient(s) separated by comma defaulting to msg.topic.
From (Sender): Set a custom sender identifier.
Label: Set a custom label for sorting analytics.
Foreign ID: Optionally set a custom value returned in callbacks.
UDH: Set a custom user data header.
TTL: Set a custom time to live in minutes.
Delay: Set a custom date for time-delayed dispatch in the form of a Unix timestamp or a date/time string formatted as yyyy-mm-dd hh:ii.
Return JSON?: If enabled, the API returns a detailed JSON response.
Unicode?: If enabled, enforce unicode encoding ignoring API detection.
Flash?: If enabled, SMS get sent as flash.
Details?: If enabled, the API returns dispatch specific information - is ignored if json is enabled.
UTF8?: If enabled, enforce UTF8 encoding ignoring API detection.
Debug?: If enabled, the API validates the request but doesn't send out SMS - useful for testing.
No Reload?: If enabled, dispatch of duplicate SMS, text and recipient alike within 180 seconds, gets allowed.
Performance Tracking?: If enabled, links found in the text get replaced with a shortened URL and click tracking enabled.
Name: An arbitrary name for the node helpful for identification.
sms77-voice node
Use this node for converting a text to speech, call a number and read the message out loud.
Message*: The text to convert to voice which defaults to msg.payload. May not exceed 10.000 characters.
*Recipient(s)**: The recipient(s) of the call separated by comma defaulting to msg.topic .
From (Caller): The caller identifier which must be your own virtual number or a shared number.
Is XML?: If enabled, the API parses the text as XML format.
sms77-lookup node
Use this node for performing number lookups.
*Number(s)**: The phone number(s) to look up separated by comma.
Type*: The lookup type to perform.
Return JSON?: If enabled, the API returns a detailed JSON response for MNP lookups. All other types return JSON by default.
Required options are marked with an asterisk (*).
Visit our API Documentation for a detailed request description.
Support
Need help? Feel free to contact us.
MIT
Version: 3.2.2
Updated 4 years, 2 months ago
23 in the last week
  • sms77-config
  • sms77-lookup
  • sms77-sms
  • sms77-voice
  • cnam
  • hlr
  • mnp
  • sms
  • sms77
  • text2speech
  • tts
