nodered-contrib-signal-client 2.4.2
Signal communicator client nodes for Node-RED
npm install nodered-contrib-signal-client
Platform License Downloads npm Rating github
Signal communicator client nodes to use the more secure messenger in Node-RED.
This is a third-party effort, and is NOT a part of the official Signal project or any other project of Open Whisper Systems.
Thanks for your donation
If you want to support this free project, any help is welcome. You can donate by clicking one of the following links:
PayPal
Buy Me A Coffee
NPM
You can install the nodes using node-red's "Manage palette" in the side bar.
Or run the following command in the root directory of your Node-RED installation
npm install nodered-contrib-signal-client --save
Dependencies
The nodes are tested with Node.js v14.15.3 and Node-RED v1.2.6 on Windows and Raspberry Pi OS.
Changelog
Changes can be followed here.
The Signal app on a smart phone is bound to a phone number. To use the Node-RED signal nodes, a phone number must be registered for a so-called account, which is used to authenticate the sender and receiver nodes. A phone number can be used either for a mobile phone or for a node account. Multiple devices or accounts cannot be used with one phone number.
But there's no reason to give Signal your mobile phone number. By providing Signal with any phone number at which you can receive an SMS or voice message, you can register a Signal account at that other phone number.
For example keep your cell phone number and Signal account on your cell phone as it is. Use your land line number or some other number for your Node-RED system.
Registration
A Registration is required so that you can communicate via Signal. Registering an account takes place in two phases:
Request a registration code
First, you'll request a registration code from the Signal server that you are authorized to use this number. The registration code can be queried through special nodes: request-sms or request-voice
The configuration of a Signal Communicator registration takes place in an account. An Account is tied to a phone number. When experimenting you probably want to get a temporary phone number via an online service like Google Voice rather than clobbering the keys for your own phone.
The password is an arbitrary string used for authentication against the Signal API. It will be registered with the Signal servers as part of the registration process.
The registration data determined are saved in the Node-RED settings. A directory is created within your Node-RED settings. The directory must be unique across all accounts. You can find the directory in "$HOME/.node-red" (Linux: /home/USER/.node-red/signal, Windows: C:\Users\USER.node-red\signal).
Live Server: For safety, a Signal staging server (testing server) can be used while you carry out your experiments. This means that it will only send and receive messages from other clients using the staging server!
Registration with Captcha
Sometimes an error message is displayed in the debug sidbar that looks something like this:
Signal client error: {"name":"HTTPError","code":402,"response":"<html>\n<head>\n<meta http-equiv=\"Content-Type\"
 content=\"text/html;charset=utf-8\"/>\n<title>Error 402 Payment Required</title>\n</head>\n<body><h2>HTTP ERROR 402
Payment Required</h2>\n<table>\n<tr><th>URI:</th><td>/v1/accounts/sms/code/+48*********</td></tr>\n<tr>
<th>STATUS:</th><td>402</td></tr>\n<tr><th>MESSAGE:</th><td>Payment Required</td></tr>\n<tr><th>SERVLET:
</th><td>io.dropwizard.jersey.setup.JerseyServletContainer-*******</td></tr>\n</table>\n\n</body>\n</html>\n"}
  1. Open https://signalcaptchas.org/registration/generate.html in your favorite browser
  2. Open the browser's developer console (see https://developers.google.com/web/tools/chrome-devtools/open)
  3. Answer the captcha
  4. On the developer console, find a line that looks like this: ... “signalcaptcha://{captcha code}” ... Copy the captcha code into the corresponding field.
  5. Deploy and repeat the registration
Interface
I/O Execution Message Properties Type Description
Input Injection button - - -
Output_1 Successful request payload string Success message
Output_2 Error on request payload string Failure message
Confirm the registration code
You'll receive an SMS message or a voice call with an registration code at the number your specified. Use the code to register your account with the Signal service:
Select the account for which the registration code was requested. Enter the registration code as received (format: "nnn-nnn" or "nnnnnn")
Don't forget to "Deploy" after configure the single nodes!
A "Deploy" or Node-RED restart is also necessary if the account for a receiver node is changed - especially after registration. This will restart all receive nodes with the actual configuration.
Success messages are not displayed in the "Debug messages" sidebar. You can connect a debug node to output 1 for this. This is not necessary for error messages. These are always output in the sidebar and in the log.
Interface
Sending a message
The "send" node is used to send a message.
A previously registered account is selected as sender.
The recipient's phone number can be configured to receive the message. Optionally, it can be passed in the message. If the number is in the message, it will be used (instead of the configured one). Output 1 forwards the sent message. The recipient number actually used is entered in this message.
The "Verbose Logging" checkbox is activated for extended log outputs in the Node-RED log. The logs are not shown in the "Debug messages" sidebar.
A text (payload.content) and one or more attachments in the form of files can be sent simultaneously in a message. To send files, the paths and file names are entered in the payload.attachments array. The paths are specified in absolute or relative terms (based on the user directory). You can find the directory in "$HOME/.node-red" (Linux: /home/USER/.node-red/signal, Windows: C:\Users\USER.node-red\signal). The files can be of any type. If they are sent to a receive node, they can be stored 1:1. A Signal messegner (e.g. on the mobile phone) interprets the files, if known. Otherwise he offers them for download.
Use disappearing messages to keep your message history tidy in your Signal communicator. The message will disappear from your devices after the timer has elapsed. Disappearing messages can be managed by anyone in the chat. Use the payload.expire property to the "send" node to configure the settings for that chat. The setting applies to any new message after the timer has been set or modified for all paticipants.
A simple flow can look like this:
Interface
I/O Execution Message Properties Type Optional Description
Input Send message payload.receiverNumber string yes The receiver's phone number
payload.content string no Message to send
payload.attachments array yes Array of file paths (absolute or relative)
payload.expire number yes Expire timeout
Output_1 Successful sent payload.receiverNumber string no Used receiver's phone number, either from the message or configured
payload.senderNumber string no The sender's phone number
payload.content string no Sent message
payload.attachments array yes Array of used file paths
Output_2 Error on sent payload object no Failure message object
Reveiving a message
The "receive" node is used to receive a message.
A previously registered account is selected as receiver.
Attachments are savend in the download directory. The donwload directory is specified in absolute or relative terms (based on the user directory). You can find the directory in "$HOME/.node-red" (Linux: /home/USER/.node-red/signal, Windows: C:\Users\USER.node-red\signal). If no download directory is specified, the attachments are copied to the root of the user directory.
The received message is contained in the payload of the output.
The attachments are saved in the download directory. One or more attachments can be received at the same time. They are saved with the filename and the extension of the sender. Attachments from a Signal messegner (e.g. on the mobile phone) can have a cryptic name if they were created temporarily.
If the setting for disappearing messages has been changed in the chat, a message will be sent. The new timer value (payload.expire) is shown in the output of the "receive" node. So that the timeout set by the client does not change, you can save it temporarily and transfer it with the next send (see exmaple 5).
To avoid problems ensure that you connect maximal one receiver node to one account.
Interface
Input - - - - -
Output_1 Successful receive payload.content string no Received message content
payload.senderUuid string no The sender's unique identification
payload.receiverNumber string no The receiver's phone number
payload.attachments array yes Array of the received file paths
payload.expire number yes Expire timeout, set by the sender (in seconds)
originalMessage string no Original received object from the underlying library @gausma/libsignal-service-javascript
Output_2 Error on receive payload object - Failure message object
Examples
Remark: All example flows can be found in the examples folder of this package. In Node-RED they can be imported via the import function (hambuger menu). Select the examples directly from the "Examples" vertical tab menue.
1 Registration flow
The registration code is requested either by the request-sms node or the request-voice node. The transmitted registration code is entered in the register node and the registration is carried out.
To display the success message you can connect a debug message to output 1. This is not necessary for error messages. These are always output in the sidebar and in the log.
Example: 01_registration
2 Simple receive
Use a Receive node to receive a message from your friend. A message that is sent to the configured account is displayed as a debug message. The telephone number and the id of the seder are also logged.
Example: 02_simple-receive
3 Simple send
You can send a message to your friend with the send node. In the example, the message is created by an inject node and thus the send node is triggered. The message is output in the debug node as confirmation.
Example: 03_simple-send
This example can easily be extended to send attachments. The payload is written as follows:
    "receiverNumber": "+4955512345678",
    "content": "Hello MAG",
    "attachments": [
        "example/image.png",
        "example/music.mp3"
Note: On Windows systems, a double backslash must be used in strings when noting a path (e.g. "example\image.png")
4 Simple echo
A simple flow: the received message is returned to the sender. This flow represents the basis for a command flow and can be expanded accordingly.
It must be ensured that the sender number is assigned to the recipient number so that the message can be returned to the sender. Content of the function node:
msg.payload.receiverNumber = msg.payload.senderNumber;
delete msg.payload.senderNumber;
Example: 04_simple-echo
5 Expire timeout
So that the timeout for disappearing messages set by the client does not change, you can save it to a global variable and transfer it with the next send.
Example: 05_expire_timeout
GPLv3
nodered-contrib-signal-client is a free software project licensed under the GNU General Public License v3.0 (GPLv3) by Martin Gaus.
Version: 2.4.2
License: GPL-3.0
Rating: 1.8 5
56 in the last week
  • account
  • request-sms
  • request-voice
  • register
  • send
  • receive
  • signal
  • communicator
  • client
