node-threshold-control 0.2.3
Threshold control
npm install node-threshold-control
Platform NPM Known Vulnerabilities Downloads Total Downloads Package Quality Open Issues Closed Issues
Threshold control
With the threshold control you can enable or disable a delayed output when the input passes the on or off threshold.
Threshold control
There are a few values that need configuration before the node can be used:
  • On payload - The msg.payload to send when the on threshold get passed (and the counter reaches zero).
  • Off payload - The msg.payload to send when the off threshold get passed (and the counter reaches zero).
  • On threshold - As soon as this threshold gets passed by msg.payload, the onDelay counter counts down to zero. If that has passed, a "on" msg.payload gets send to the first output.
  • Off threshold - As soon as this threshold gets passed by msg.payload, the offDelay counter counts down to zero. If that has passed, a "off" msg.payload gets send to the first output.
  • On delay - the delay in seconds that is waited before the output gets send after the input passes the on threshold.
  • Off delay - the delay in seconds that is waited before the output gets send after the input passes the off threshold.
The on threshold should be higher than the off threshold.
Note that the delay is in whole seconds. It rounds it to the nearest integer when input is not in whole seconds.
Input
By default the node listens to msg.payload as input.
It also listens to different messages, which can change the configured values:
  • msg.onThreshold - The on threshold
  • msg.offThreshold - The off threshold
  • msg.onDelay - The on delay in seconds
  • msg.offDelay - The off delay in seconds
Outputs
There are three outputs. The first one just gives "on" or "off" (after the delay has passed).
The second output gives the state of the counter for the on delay.
The third output gives the state of the counter for the off delay.
Both second and third outputs also publish a msg.blink that is 0 or 1 when the counter is even or odd.
Status
The status node tries to show the current state. It can turn red on wrong input and on the "off" state, green on the "on" state and yellow when the on or off counter is running.
The node starts in the "unknown" state (blue dot). The first payload that is above the on threshold or below the off threshold starts the normal countdown, after which the "on" or "off" payload is sent. A payload within the hysteresis region (between the two thresholds) leaves the state "unknown".
Version: 0.2.3
Updated 3 weeks, 4 days ago
46 in the last week
  • threshold-control
  • victron
  • threshold control
