node-red-zoracledb 0.0.7
Node-RED oracle database nodes
npm install node-red-zoracledb
node-red-zoracledb
node-red-zoracledb
msg.oracleConfig = {
    user: "myuser",
    password: "mypass",
    host: "192.168.1.100",
    port: "1521",
    db: "orcl"
    // 也可以包含 tnsname、instantclientpath
Robust, modern, and easy-to-use Node-RED nodes for interacting with Oracle Database.
This module provides a stable connection to Oracle, supporting queries, DML, stored procedures, and advanced data binding, all handled through a resilient connection pool.
Prerequisites
Before using this node, you must have the Oracle Instant Client libraries installed on the same machine that is running Node-RED.
  1. Download: Get the Instant Client "Basic" or "Basic Light" package for your operating system from the Oracle Instant Client Downloads Page.
  2. Install: Unzip the package to a permanent location on your system (e.g., /opt/oracle/instantclient_21_13 on Linux, C:\oracle\instantclient_21_13 on Windows).
  3. Configure Environment: Node.js needs to know where to find these libraries.
  • Linux: Add the path to the LD_LIBRARY_PATH environment variable.
  • Windows: Add the path to the PATH system environment variable.
  • macOS: Add the path to the DYLD_LIBRARY_PATH environment variable.
  1. In the node's configuration, you must provide the path to this directory in the Instant Client Path field. This directly addresses GitHub issue #52.
Install via the Node-RED Palette Manager or run the following command in your Node-RED user directory (typically ~/.node-red):
npm  install  node-red-contrib-oracledb-mod
  • Resilient Connection Pooling: Automatically manages a pool of connections to handle idle timeouts, network disconnects, and database restarts, ensuring your flows are always ready.
  • Execute SQL and PL/SQL: Run SELECT, INSERT, UPDATE, DELETE, and anonymous PL/SQL blocks.
  • Stored Procedures & Functions: Full support for calling stored procedures and functions with IN, OUT, and INOUT parameters using msg.bindVars.
  • Flexible Result Handling: Choose whether to get all rows at once, stream large result sets, or get metadata like the number of rows affected by a DML statement.
  • Configurable Connections: Connect using Classic (host:port/db) or TNS Name, with configurable connection pool settings.
  • Built-in Examples: Comes with an importable example flow for calling stored procedures.
Node Usage
1. oracle-server (Configuration Node)
This node configures the connection to your database. Using the Connection Pool is highly recommended for all use cases.
  • Connection Type: Choose "Classic" for host/port/db or "TNS Name" for using a tnsnames.ora entry.
  • Instant Client Path: The local filesystem path to your Oracle Instant Client installation.
  • Connection Pool:
  • Min/Max Connections: Control the size of the connection pool.
  • Idle Timeout (s): How long an idle connection can live in the pool before being terminated. This is key to preventing errors from firewalls closing idle connections.
2. oracledb (Query Node)
This node executes the query and sends the results.
Common Use Cases
Use Case 1: Simple SELECT Query
  • Set msg.query to SELECT * FROM employees WHERE department_id = :1.
  • Set msg.payload to [50].
  • Set the Action to send single query result message.
  • Output: msg.payload will be an array of employee objects.
Use Case 2: INSERT or UPDATE and Get Rows Affected
  • Set msg.query to UPDATE employees SET salary = salary * 1.1 WHERE department_id = :1.
  • Set the Action to send single message with metadata.
  • Output: msg.payload will be an object like { rowsAffected: 10, ... }. This addresses GitHub issues #3, #53, and #35.
Use Case 3: Calling a Stored Procedure with an OUT Parameter
  • Set msg.query to BEGIN get_employee_name(:emp_id, :emp_name); END;.
  • Set msg.bindVars as shown below.
  • Output: msg.payload.outBinds.emp_name will contain the returned name. This addresses GitHub issue #6 and #34.
// Example for msg.bindVars
msg.bindVars = {
emp_id: { dir:  "BIND_IN", val:  101, type:  "NUMBER" },
emp_name: { dir:  "BIND_OUT", type:  "STRING" }
For a full list of bind parameter types and directions, see the official node-oracledb documentation.
Executing Multiple Statements (Scripts)
The Oracle driver executes one SQL statement or one PL/SQL block at a time. You cannot send a script with multiple statements separated by semicolons (;) in a single query. This will result in an ORA-00933 error.
There are two recommended ways to run multiple commands:
1. For Transactional Scripts (INSERT, UPDATE, DELETE)
The best practice is to wrap your statements in a single PL/SQL BEGIN...END; block. This ensures all commands are executed together as a single, atomic transaction.
Example:
BEGIN
UPDATE inventory SET quantity = quantity - 1  WHERE product_id = :p_id;
INSERT INTO order_log (product_id, log_date) VALUES (:p_id, SYSDATE);
END;
2. For Sequential Queries
If you need to run multiple independent queries, especially SELECT statements, the standard Node-RED approach is to chain multiple oracledb nodes in your flow.
Example Flow:
Inject → [ oracledb (SELECT from table A) ] → [ oracledb (SELECT from table B) ] → ...
What's New
Version 0.7.5
  • Fixed: Corrected a critical startup crash (NJS-007 error) that occurred when importing flows with a configured connection pool. Flows are now fully portable. (Fixes #90).
Version 0.7.4
  • Feature: Added Smart Named Binding to automatically handle msg.payload objects and prevent ORA-01036 errors.
  • Feature: Implemented more intelligent and persistent node status feedback for running queries and errors.
  • Fixed: Resolved an upgrade issue where existing oracle-server nodes would be marked as invalid.
  • Fixed: Corrected a type_already_registered startup error by overhauling the build process.
Version 0.7.3
This is a major stability and modernization release.
  • Resilient Connections: The node now uses a robust Connection Pool, which resolves numerous issues related to idle timeouts, network disconnects, and stale connections.
  • Added Metadata Result Option: The "single-meta" action has been re-introduced to get the number of rowsAffected from DML statements or outBinds from procedures.
  • Improved Error Handling: The entire backend has been refactored to use modern async/await, providing clearer error messages and preventing Node-RED crashes.
  • UI and Documentation Overhaul: The configuration UI and help text have been significantly improved for clarity and ease of use.
  • Modernized Tooling: The development toolchain has been upgraded to modern standards.
  • Added Examples: A built-in example flow for stored procedures is now included.
View more commits and changelog
Version: 0.0.7
Updated 1 year, 1 month ago
2 in the last week
  • zoracleserver
  • zoracledb
  • oracle
  • sql
  • oracledb
