node-red-trexmes-service 1.8.7
service Nodes for trexMes systems
npm install node-red-trexmes-service
A Node-RED package for trexMes Edge panel software โ€” real-time event handling, form design, and control management over a NodeRED connector plugin.
npm version License: GPL v3 Node-RED
๐Ÿ“– Full documentation: asafyurdakul.github.io/node-red-trexmes-service
What does it do?
node-red-trexmes-service collects real-time event triggers from 150โ€“200 trexMes panels on the production floor into a single Node-RED server. It lets you:
  • Capture panel events (business, system, communication, display, form)
  • Design real-time WinForms with XML
  • Bind data to form controls
  • Invoke panel methods and read state contexts
  • Trigger processes and run scripts on the panel side
  • Generate Node-RED flows from natural language using an LLM
Prerequisite: The trexMes Edge panel software must have the NodeRED connector plugin enabled.
Run the following command in your Node-RED install directory:
Or install directly from the Node-RED palette manager by searching for node-red-trexmes-service.
Nodes (23 total)
๐ŸŸข Core Nodes (2)
Required in every trexMes project.
Node I/O Description
trex Subscriber 0 โ†’ 1 Registers all project events on the panel side. One per project, mandatory.
Responser 1 โ†’ 0 Returns the HTTP response to the panel. Must be the last node in every event flow.
๐Ÿ”” Event Nodes (8)
Triggered by the trexMes panel. Each captures a specific event type.
Node Description
Business Events Business workflow events
System Events System-level events
Communication Events Communication layer events
Display Events UI display events
Form Events User interactions on custom forms
Display Methods Main form method triggers
Method Returns Asynchronous method invocation responses
Handle Setter Dynamically sets IsHandled=true to stop further panel processing
๐Ÿงฉ Form Nodes (5)
Custom form design, data binding and property management.
Node Description
Custom Form Creates a form from XML design at runtime
Form Bind Controls Binds data to form input fields
Control Properties Sets properties of controls on the panel form
Button Configurator Configures buttons on custom forms
Main Form Action Triggers actions on the main panel form
โš™๏ธ Action Nodes (4)
Method invocation, process triggering, and script execution.
Node Description
Method Invoker Calls a panel method with parameters (async โ€” response via Method Returns)
Context Getter Queries a station's StateContext data (async โ€” response via Method Returns)
Execute Process Triggers a defined process on the panel
Execute Script Runs a script on the active form
๐Ÿค– AI (1)
Node Description
LLM Flow Builder Generates a Node-RED flow from a natural language prompt using an LLM
Typical Flow Structure
trex Subscriber runs independently โ€” it does not trigger other nodes. Event flows start directly from Event nodes.
[trex Subscriber]  โ† standalone, registers events on panel
โ”€โ”€ Flow 1: open form โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€
[Business Events] โ†’ [Custom Form] โ†’ [Responser]
โ”€โ”€ Flow 2: bind data when form loads (Form Events / Load) โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€
[Form Events control="_" Load] โ†’ [Form Bind Controls] โ†’ [Control Properties] โ†’ [Responser]
โ”€โ”€ Flow 3: handle button click โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€
[Form Events / btnSave / Click] โ†’ [...] โ†’ [Responser]
โ”€โ”€ Async method call โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€
[Display Methods] โ†’ [Method Invoker] โ†’ [Responser]
                          โ†“ (async)
                    [Method Returns] โ†’ [...process result...] โ†’ [Responser]
Every project needs exactly one trex Subscriber. Every event flow must end with a Responser.
Custom Form is always followed directly by Responser. Data binding and control property changes go in the Form Events Load flow.
Requirements
Component Minimum Version
Node.js 18.16+
Node-RED 3.0+
trexMes Edge NodeRED connector plugin enabled
Documentation
Full reference documentation is available at:
https://asafyurdakul.github.io/node-red-trexmes-service/
Includes:
  • Installation & quick start guide
  • Architecture overview
  • Per-node property tables, payload examples, and flow diagrams
  • Flow examples (custom form, button configuration, method invocation)
  • FAQ & troubleshooting
License & Author
Licensed under GPL-3.0-or-later.
Author: Asaf Yurdakul ยท trex Digital Manufacturing
Version: 1.8.7
Updated 3 weeks, 5 days ago
License: GPL-3.0-or-later
Rating: 5.0 2
156 in the last week
  • trex Subscriber
  • llm-flow-builder-config
  • llm-flow-builder
  • Business Events
  • System Events
  • Communication Events
  • Display Events
  • Form Events
  • Display Methods
  • Method Returns
  • Responser
  • Custom Form
  • Form Design
  • Form Bind Controls
  • Control Properties
  • Button Configurator
  • Main Form Action
  • Method Invoker
  • Context Getter
  • Context Setter
  • Execute Process
  • Execute Script
  • Handle Setter
  • trex-mes
