node-red-syslog 2.1.7
Redis stream consumer with conditional acknowledgments and resource management
npm install node-red-syslog
redis-syslog-consumer
⚙️ Prerequisites
  • Node.js v14 or higher
  • Redis v5.0 or higher (Streams support required)
  • A reachable Redis server from your environment
A reusable library for consuming Redis streams reliably using consumer groups, with back‑pressure, retry, and dynamic concurrency control based on system load. Can be used as a standalone library or as a Node-RED node.
📦 Installation
Add the package to your project:
npm install redis-syslog-consumer
If using Node-RED, restart your Node-RED instance to load the new nodes.
🚀 Usage
Standalone Usage
const { StreamProcessor, GlobalResource } = require("redis-syslog-consumer");
// Create a map to store processor instances
const processors = new Map();
// Create a resource manager
const resourceManager = new GlobalResource(processors, {
  maxConcurrency: 10,
  minConcurrency: 1,
// Start the resource manager
resourceManager.start();
// Message handler function
const handleMessage = (message) => {
  console.log("Received message:", message.payload);
  console.log("Redis ID:", message._redisId);
  // Process the message...
  // After processing, acknowledge the message
  streamProcessor.acknowledgeAndDelete(message._redisId);
// Create a stream processor
const streamProcessor = new StreamProcessor(
  "redis://localhost:6379",
  "syslog",
  resourceManager.concurrency,
  handleMessage
// Register with resource manager
processors.set("syslog", streamProcessor);
// Initialize the stream processor
streamProcessor.initialize();
// Cleanup on shutdown
process.on("SIGINT", () => {
  processors.delete("syslog");
  resourceManager.stop();
  process.exit(0);
Node-RED Usage
Once installed, you'll have two new nodes in the palette under Syslog and config:
  1. Redis Syslog Consumer (redis-syslog-consumer)
  2. Resource Manager (redis-syslog-resource-manager)
Redis Syslog Consumer Node
  • Inputs: 1
  • Outputs: 2 (output, logs)
Node Properties
Property Type Description
Name String Optional label
Redis URL String Connection URI (redis://host:port)
Stream Key String Redis stream name (e.g. syslog)
Resource Manager Config Select your redis-syslog-resource-manager node
Behavior
  1. On deploy, it creates a StreamProcessor with:
    • A Redis client connection
    • A consumer‐group named grp:<stream>
    • A random consumer name name:<id>
  2. Initialization:
    • Creates or reuses the Redis consumer group
    • Drains existing backlog (XREADGROUP from 0)
    • Claims stale pending entries (older than 5 minutes)
    • Starts a continuous poll (BLOCK 30s) for new messages
  3. Message flow:
    • Each entry becomes a Node-RED message payload (msg.payload) with metadata (msg._redisId).
    • The developer must re-inject an object { _redisId, _redisAck: true } into the node to ACK/DEL from the stream.
  4. Logging: any lifecycle events, errors, or debug can be emitted to the second output.
Resource Manager Config Node
Global config node that monitors CPU and RAM and adjusts all active Redis Syslog Consumer nodes' concurrency based on hysteresis thresholds.
Config Properties
Property Default Description
Max Concurrency 10 Upper bound for message‐parallelism
Min Concurrency 1 Lower bound for parallelism
Sampling Size 10 Number of samples in sliding window
Sampling Interval (ms) 5000 Time between CPU/RAM checks
Upper CPU Threshold (%) 80 CPU% above which concurrency is halved
Lower CPU Threshold (%) 30 CPU% below which concurrency is doubled
Upper RAM Threshold (%) 80 RAM% above which concurrency is halved
Lower RAM Threshold (%) 30 RAM% below which concurrency is doubled
Behavior
  • Uses pidusage to sample process CPU and memory.
  • Maintains sliding‐window averages with weighted samples.
  • Applies hysteresis:
    • Decrease concurrency if CPU ≥ upper CPU threshold or RAM ≥ upper RAM threshold.
    • Increase concurrency if both CPU < lower CPU threshold and RAM < lower RAM threshold.
  • Doubles or halves the global concurrency, clamped between min/max.
📖 API Reference
StreamProcessor
const { StreamProcessor } = require("redis-syslog-consumer");
Constructor
  url: string,
  stream: string,
  concurrency: number,
  onMessageCallback: (msg: { payload: string; _redisId: string }) => void,
  options?: {
    logger?: (message: string, context?: string) => void,
    status?: (fill: string, shape: string, text: string) => void,
    consumerName?: string,
    consumerGroupPrefix?: string
  • url: Redis connection URI
  • stream: Redis stream key
  • concurrency: max parallel messages
  • onMessageCallback: invoked with each parsed message
  • options: Optional configuration
Methods
  • initialize(): Promise<void> – start consuming (create group, drain backlog, poll).
  • acknowledgeAndDelete(messageId: string): Promise<void> – XACK + XDEL for a given message.
  • setConcurrency(newConcurrency: number) – dynamically adjust concurrency.
GlobalResource
const { GlobalResource } = require("redis-syslog-consumer");
Constructor
new GlobalResource(
  processors: Map<string, { setConcurrency: (number) => void }>,
  config?: {
    maxConcurrency?: number,
    minConcurrency?: number,
    samplingCount?: number,
    samplingIntervalMs?: number,
    upperCpuThresholdPercent?: number,
    lowerCpuThresholdPercent?: number,
    upperMemThresholdPercent?: number,
    lowerMemThresholdPercent?: number
Methods
  • start() - Start monitoring CPU and RAM usage
  • stop() - Stop monitoring
  • registerProcessor(streamKey: string, processor: object) - Add a processor
  • unregisterProcessor(streamKey: string) - Remove a processor
  • get concurrency() - Get current concurrency value
🛠 Example Node-RED Flow
    "id": "1",
    "type": "redis-syslog-resource-manager",
    "name": "ResourceManager",
    "concurrencyMax": 20,
    "concurrencyMin": 1,
    "samplingCount": 15,
    "samplingInterval": 3000,
    "thresholdUpper": 75,
    "thresholdLower": 25,
    "thresholdUpperMem": 75,
    "thresholdLowerMem": 25
    "id": "2",
    "type": "redis-syslog-consumer",
    "stream": "syslog",
    "url": "redis://127.0.0.1:6379",
    "resource": "1",
    "wires": [["3"], ["4"]]
Inject back to acknowledge:
{ "payload": { "redis": { "id": "1680000000000-0", "ack": true } } }
Contributing
Contributions are welcome! Please fork the repository, create a feature branch, and submit a pull request with a detailed explanation of changes.
Versioning
We use SemVer for versioning. For the versions available, see the tags on this repository.
Authors
  • Paolo Fabris - Initial work - ibs.srl
See also the list of contributors who participated in this project.
⚖️ License
This project is licensed under the MIT License. See the LICENSE file for details.
Version: 2.1.7
Updated 1 year, 5 months ago
226 in the last week
  • redis-syslog-resource-manager
  • redis-syslog-consumer
  • redis
  • stream
  • ack
  • syslog
