node-red-supemail-node 1.0.5
A Node-RED node for sending the latest file as an email attachment
npm install node-red-supemail-node
Node-RED Latest File Email Node
A Node-RED node that monitors a directory and sends the latest file as an email attachment.
  • Monitors a specified directory for files
  • Sends the latest file as an email attachment
  • Configurable email server settings
  • Configurable sender and multiple recipients
  • Configurable email subject and body
  • Detailed error handling and logging
  • Secure password storage
Via Node-RED Palette Manager
  1. Open Node-RED
  2. Click Menu → Manage Palette
  3. Switch to "Install" tab
  4. Search for "node-red-email-node"
  5. Click Install
Manual Installation
npm install node-red-email-node
Email Server Settings
  1. Double click the node to open configuration
  2. Click the pencil icon next to "Email Config"
  3. Configure the following:
    • Name: A name for this configuration
    • Host: SMTP server hostname (e.g., smtp.gmail.com)
    • Port: SMTP server port (default: 587)
    • Secure: Use SSL/TLS (check for port 465)
    • User: SMTP username
    • Password: SMTP password
    • To: Recipient email addresses (multiple addresses can be separated by commas)
    • Subject: Email subject
    • Text: Email body text
    • Watch Directory: Directory to monitor for files
Node Settings
  • Name: Optional name for the node
  1. Deploy the node
  2. The node will trigger when it receives any input message
  3. It will find the latest file in the configured directory
  4. The file will be sent as an attachment to all configured email addresses
Input
Any message will trigger the node to send the latest file.
Output
The node outputs a message with the following properties:
    "payload": {
        "success": true,
        "messageId": "message-id",
        "file": "filename.ext",
        "recipients": ["[email protected]", "[email protected]"]
Example Flow
        "id": "trigger-node",
        "type": "inject",
        "name": "Trigger",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
                "email-node"
        "id": "email-node",
        "type": "email-node",
        "name": "Send Latest File",
        "emailConfig": "email-config-node",
                "debug-node"
Development
Prerequisites
  • Node.js 14 or later
  • npm 6 or later
Setup
# Clone the repository
git clone https://github.com/yourusername/node-red-email-node.git
# Install dependencies
cd node-red-email-node
npm install
# Run tests
npm test
Testing
The node includes comprehensive tests:
  • File system operations
  • Email transport configuration
  • Email sending functionality
  • Error handling
Run tests with:
npm test
Troubleshooting
Common Issues
  1. No files found
    • Check if the watch directory exists
    • Verify directory permissions
  2. Email not sending
    • Verify SMTP server settings
    • Check credentials
    • Ensure network connectivity
  3. Authentication failed
    • Double-check username and password
    • For Gmail, you may need an App Password
  4. Multiple recipients not working
    • Ensure email addresses are separated by commas
    • Check for any spaces before or after email addresses
    • Verify all email addresses are valid
Debug Mode
Enable debug mode in Node-RED to see detailed logs:
  1. Open Node-RED settings
  2. Enable debug mode
  3. Deploy and check debug messages
MIT
Contributing
  1. Fork the repository
  2. Create your feature branch
  3. Commit your changes
  4. Push to the branch
  5. Create a Pull Request
Version: 1.0.5
Updated 1 year, 8 months ago
13 in the last week
  • email-node
  • email-config
  • email
  • file
  • attachment
