node-red-semantic-flow-language 0.4.2
Node-RED Semantic Flow Language - AI-powered tooltips and natural language flow builder plugins
npm install node-red-semantic-flow-language
Node-RED Semantic Flow Language (SFL)
The first implementation of the Semantic Flow Language, bringing bidirectional semantic synchronization and natural-language flow creation to Node-RED.
SFL Node-RED Demo
Overview
This plugin extends Node-RED with Semantic Flow Language (SFL) features β€” enabling AI-assisted flow creation, semantic sync between intent and logic, and inline editable tooltips for clarity and transparency.
For the full concept, specification, and philosophy, visit the main project: Semantic Flow Language Repository
  • Natural-Language Flow Builder Describe complete flows in plain English. For example: "Create an app that pulls today's Zendesk tickets at 7 AM and emails a report." AI translates your intent into valid Node-RED JSON automatically.
  • Auto-Verify with AI Self-Correction When the AI generates or updates a flow, the plugin validates it (schema, node types, required props, wire integrity, config-node refs) and β€” when explicitly enabled β€” deploys it to a non-production runtime to watch for errors. Any validation failure or runtime error is fed back to the AI as a correction diff for the next attempt. The loop stops on success, on the configured attempt ceiling, or when the same error signature recurs. See Auto-Verify for configuration.
  • Inline Node Tooltips
    • Hover to view node descriptions
    • Click to edit inline (content-editable)
    • Save or cancel with overlay buttons
    • Respects Node-RED themes and CSS
  • Semantic Sync Engine
    • Keeps node info (intent) and logic aligned
    • Blue-dot indicators for updated nodes
    • 429 rate-limit handling with exponential backoff
  • Native Integration
    • Uses Node-RED event system (node:added, node:changed, deploy)
    • No server patching required
    • Works with Node-RED approved nodes
Visual Indicators
Color Meaning
🟑 Yellow Sync in progress
πŸ”΄ Red Rate-limited / retry pending
πŸ”΅ Blue Synced and verified
Development
pnpm add node-red-semantic-flow-language
cd node_modules/node-red-semantic-flow-language
pnpm install
Production
Disclaimer
The Semantic Flow Language (SFL) framework is designed to be model-agnostic and compatible with a variety of AI and automation systems.
However, as of this release, Google AI, OpenAI, and Anthropic (Claude) integrations have not been formally tested or validated.
Any use of SFL with these systems should be considered experimental and may require additional configuration or compatibility testing.
AI Connection Setup
  1. Copy environment template:
cp node_modules/node-red-semantic-flow-language/.env.example ~/.node-red/.env
  1. Edit ~/.node-red/.env with your AI provider credentials:
# Select connector: azure-openai, openai, anthropic, google
AI_CONNECTOR=""
# Shared AI API key (required for all connectors)
AI_API_KEY=""
# Shared AI model (per provider)
AI_MODEL=""
# Token limits and context (optional)
AI_MAX_COMPLETION_TOKENS=1024
AI_MAX_TOKENS=1024
AI_MAX_FLOW_CONTEXT_CHARS=18000
# OpenAI (only when AI_CONNECTOR=openai)
AI_ORGANIZATION=""
# Azure OpenAI (only when AI_CONNECTOR=azure-openai)
AI_ENDPOINT="https://your-endpoint.openai.azure.com/"
AI_API_VERSION="2024-12-01-preview"
AI_DEPLOYMENT_NAME="your-deployment-name"
# Optional: Azure AI Search for RAG (Node-RED documentation)
AI_SEARCH_ENDPOINT="https://your-search.search.windows.net/"
AI_SEARCH_API_KEY="your-search-key"
AI_SEARCH_INDEX="your-index-name"
AI_EMBEDDING_DEPLOYMENT="your-embedding-deployment"
# Auto-Verify (AI tab switch defaults and correction-loop bounds)
SFL_AUTO_VERIFY_DEFAULT="true"
SFL_AUTO_VERIFY_MAX_ATTEMPTS="3"
SFL_AUTO_VERIFY_MAX_RESTARTS="3"
SFL_AUTO_VERIFY_TIMEOUT_MS="30000"
  1. Restart Node-RED:
node-red-restart
No changes to settings.js are required - the plugin is auto-discovered via package.json.
Advanced configuration in settings.js (optional)
The plugin is designed so that configuration can live in either .env or settings.js. Prompt overrides are read from settings.js when present. The plugin will work out of the box with only .env configured.
Recommendation: keep secrets (for example API keys) in .env rather than in settings.js. You can override settings in settings.js for per-instance tuning, but storing sensitive credentials there is not recommended.
If you want to tune behavior for a specific Node-RED instance, add a small configuration block to your settings.js.
module.exports = {
  aiPrompts: {
    SYSTEM_PROMPT: "Your custom system prompt here",
    SYSTEM_PROMPT_FLOW: "Your custom system prompt for flow here",
    SYSTEM_PROMPT_NODE: "Your custom system prompt for node here",
    USER_PROMPT_TEMPLATE: "Your custom user prompt template here",
    USER_PROMPT_WITH_CONTEXT: "Your custom user prompt with context here",
    NODE_SEMANTIC_UPDATE_PROMPT: "Your custom node semantic update prompt here",
    DESCRIPTION_GENERATION_PROMPT: "Your custom node description generation prompt here",
  AI_CONNECTOR: "openai",           // Optional override
  AI_MODEL: "gpt-4",                // Optional override
  AI_API_KEY: "",                   // Optional override (not recommended)
  AI_MAX_COMPLETION_TOKENS: 2048,   // Optional override
  AI_MAX_TOKENS: 2048,              // Optional override
  AI_MAX_FLOW_CONTEXT_CHARS: 20000, // Optional override
  AI_ORGANIZATION: "",              // Optional override for OpenAI
  AI_ENDPOINT: "",                  // Optional override for Azure OpenAI
  AI_API_VERSION: "",               // Optional override for Azure OpenAI
  AI_DEPLOYMENT_NAME: "",           // Optional override for Azure OpenAI
  AI_SEARCH_ENDPOINT: "",           // Optional override for Azure AI Search
  AI_SEARCH_API_KEY: "",            // Optional override for Azure AI Search
  AI_SEARCH_INDEX: "",              // Optional override for Azure AI Search
  AI_EMBEDDING_DEPLOYMENT: "",      // Optional override for Azure AI Search
  // Auto-Verify (see the Auto-Verify section below for behavior)
  SFL_AUTO_VERIFY_DEFAULT: true,    // Default state of the AI tab auto-verify switch
  SFL_AUTO_VERIFY_MAX_ATTEMPTS: 3,  // Correction attempts before regenerating from scratch
  SFL_AUTO_VERIFY_MAX_RESTARTS: 3,  // Fresh regenerations to try after inner attempts fail
  SFL_AUTO_VERIFY_TIMEOUT_MS: 30000,// Per-attempt deploy/observation window and loop upper bound
  // Audit (see the Audit Trail section below). Default empty = silent.
  SFL_AUDIT_DESTINATION: "",        // "" | "red.log" | "http(s)://..." | filepath (JSONL)
  SFL_AUDIT_HEADERS: {}             // URL mode only: HTTP headers (key-value object)
Auto-Verify
When the AI builds or updates a flow, auto-verify can validate the result, optionally deploy it to a non-production runtime, watch for errors, and feed any failure back to the AI as a correction diff for the next attempt. The correction log is rendered in the existing AI tab output panel; Node-RED's debug panel remains the canonical record of full error fidelity.
Toggle. A switch labeled auto-verify sits above the response panel in the AI Builder sidebar. Its default state comes from SFL_AUTO_VERIFY_DEFAULT.
Settings (configurable in .env or under the plugin block in settings.js):
Key Type Default Notes
SFL_AUTO_VERIFY_DEFAULT boolean true Default state of the AI tab switch.
SFL_AUTO_VERIFY_MAX_ATTEMPTS integer 3 Inner correction attempts within one restart.
SFL_AUTO_VERIFY_MAX_RESTARTS integer 3 After exhausting attempts, regenerate the flow from scratch (sends the original prompt with no context) and run auto-verify again. Worst-case AI calls = MAX_ATTEMPTS * MAX_RESTARTS.
SFL_AUTO_VERIFY_TIMEOUT_MS integer 30000 Per-attempt deploy/observe window and loop upper bound.
Auto-deploy gate. Turning on the auto-verify switch is the user's explicit consent to deploy, so the only remaining guard is the environment:
  • process.env.NODE_ENV must be set and not "production". Blank or undefined fails closed β€” an unknown environment must not deploy.
If the environment check fails, auto-verify runs validation-only (schema, node-type existence, required props, wire integrity, config-node refs) and a clean validation counts as a successful attempt.
Two-phase self-correction loop. Each attempt runs two phases in order:
  1. Syntax phase β€” uses Node-RED's own per-node validator (the same one that puts the red error triangle on invalid nodes in the editor). Covers required fields, typedInput types, JSONata expression syntax, wire integrity, unknown node types, and unresolved config-node references. If syntax errors are found, the attempt ends here and the next attempt starts again with a syntax check on the AI's correction.
  2. Runtime phase β€” only entered when the syntax phase is clean. Deploys the flow (if the auto-deploy gate allows) and observes the Node-RED debug stream for the timeout window. Any runtime errors observed end the attempt.
On either phase failure the plugin:
  • captures the error signature (namespaced syntax: or runtime:),
  • computes the correction diff between the previous and current attempt,
  • sends the diff + error + phase to the AI for the next attempt.
Restarts. If the inner attempts loop hits SFL_AUTO_VERIFY_MAX_ATTEMPTS without success (or stops on signature repeat), the plugin regenerates the flow from scratch by re-sending the original prompt to the AI with no context. It then runs the inner loop again on the fresh flow. This repeats up to SFL_AUTO_VERIFY_MAX_RESTARTS times.
The whole loop stops on: clean syntax + clean runtime, the SFL_AUTO_VERIFY_MAX_RESTARTS Γ— SFL_AUTO_VERIFY_MAX_ATTEMPTS ceiling, or repetition of the same error signature within a restart (early convergence stop for that restart). Both phases combined count as one attempt against SFL_AUTO_VERIFY_MAX_ATTEMPTS. On stop, the flow is left in its current state in the editor β€” there is no rollback or stash.
On terminal failure (all restarts exhausted), the AI tab output panel shows:
Couldn't resolve β€” try rephrasing prompt and running again. If that also fails, escalate to dev.
Audit Trail
Plugin activity (prompt receipt, each auto-verify attempt, and the final auto-verify outcome) can be emitted as structured JSON events to a single configurable destination. Default behavior is silent β€” nothing is emitted unless SFL_AUDIT_DESTINATION is set. Emission is fire-and-forget; it never blocks the user-facing operation.
Destination is resolved from SFL_AUDIT_DESTINATION in this order:
Value Behavior
empty / unset silent (default)
"red.log" emit via RED.log.info() with the event as a JSON string
starts with http:// or https:// POST JSON payload to that URL
anything else treated as a file path; append as JSONL (one event per line). Relative paths resolve against the Node-RED user directory.
For URL mode, set SFL_AUDIT_HEADERS (object) in settings.js to attach auth headers to every POST. TLS is verified by default. Transient failures (timeout, 5xx) are retried once with backoff; pending requests are capped at 100 to prevent backpressure, and excess events are dropped with a RED.log.warn.
File mode is append-only, no rotation in v1 β€” manage with logrotate or equivalent.
Common envelope on every event: timestamp (ISO 8601 with timezone), event_type, user (best-available: email β†’ username/UPN β†’ id β†’ null), user_source (email / username / id / none), prompt_id (UUID generated when the prompt is received, referenced by all subsequent events). The server stamps user/user_source fresh on each event write.
Event types:
  • prompt_received β€” emitted when an AI endpoint accepts a prompt. Extra fields: prompt_text, ai_mode (flow_generation / node_update / description_generation).
  • auto_verify_attempt β€” emitted once per attempt outcome. Extra fields: attempt_number, mode (syntax / runtime), error_signature (normalized β€” node ids/UUIDs/timestamps/numbers stripped so equivalent errors hash identically), error_message (raw), correction_summary, outcome (resolved / unresolved / same_signature_repeated).
  • auto_verify_complete β€” emitted once when the loop terminates. Extra fields: outcome (resolved / ceiling_hit / signature_repeated / unresolved_after_resample), total_attempts, resample_triggered (boolean), final_flow_id (target tab id), duration_ms.
Correction log format. The AI tab output panel shows the attempt count prominently at the top (for example: Resolved in 2 attempts or Stopped after 3 attempts β€” unresolved). Each attempt is rendered as a discrete entry labeled Attempt N Β· Syntax or Attempt N Β· Runtime to indicate which phase determined the outcome. The entry contains the attempt number + phase, a one-line error summary, what the AI changed in response, and the phase outcome.
Development time Flow Builder Sidebar
  1. Click the πŸͺ„Magic Wand icon.
  2. Describe your flow or logic in natural language.
  3. AI generates and inserts the corresponding flow JSON.
Tooltip Editing
  1. Hover over a node to view its description.
  2. Click to edit inline.
  3. Click the overlay "Save” button or outside the tooltip to commit.
  4. The node automatically re-syncs.
About Semantic Flow Language (SFL)
SFL is a Semantic Execution Model that represents logic as a bidirectionally synchronized meaning graph β€” permitting human intent, AI generation, and executable code to remain aligned.
Node-RED serves as the first working implementation of this model.
Learn more in the Semantic Flow Language repository.
Related Documentation
Contact
This project is licensed under the ISC License β€” see the LICENSE file for more details.
Copyright (c) 2025 William Shostak
Version: 0.4.2
Updated 2 months, 3 weeks ago
46 in the last week
  • plugin
  • editor
  • semantic
  • ai
  • tooltips
  • flow-builder
  • natural-language
  • Will Shostak
