node-red-otplc-linux-sys-class-leds 0.0.906
Is for reading / writing sys class leds on linux from Node-RED
npm install node-red-otplc-linux-sys-class-leds
Ufff what a name !
ot-plc to use linux sys / class / leds kernel layer to flash your leds!
You need to have permissions to write to /sys/class/leds/*/[brightness|trigger] then this is working for setting. Without it is only able to read status now.
install it
For now installation is by entering node-red home directory then installing localy for Node-RED
npm i node-red-otplc-linux-leds
then restart Node-RED and start your led instance!
in result we have
iot keyboard led
using it
You can send it topic {string}:
dirList - to get payload with posible options to set as led
getStatus - to get payload current brightness
getStatusLong - extended {json} in payload info about set led
set - with payload will write to brightness
trigger - with payload write trigger
On start look on status of node or what is returning
example flow set
To check it out .json to import to Node-RED link...
status
working
screenshots
Video showing how to set it up and use it wrapt in node-red node as node-red-otplc-linux-sys-class-leds ...
node-red-otplc-linux-sys-class-leds oiyshTerminal at npm - on youtube from setting it up to blinking led...
If you see that this make sens
Version: 0.0.906
  • otplcLinuxSysClassLeds
  • otplc
  • light
  • linux
  • sysfs
  • leds
  • oiyshTerminal
  • oit
  • plc
