node-red-opcua-otmr 3.0.2
OPCUA communication
npm install node-red-opcua-otmr
Node-RED OPCUA-OTMR Node
The @omidteimoori/node-red-opcua Node-RED node allows seamless communication with OPC UA servers. It enables you to read, write, and subscribe to values from specific Node IDs — ideal for industrial automation and IoT applications.
  • Connect to any OPC UA server via customizable endpoint URL and port
  • Read data from specific Node IDs
  • Write data to OPC UA tags
  • Subscribe to live changes
  • Suitable for use in SCADA, MES, and Industry 4.0 projects
Then restart Node-RED. The node will appear in the function category as opcua-otmr.
  1. Drag the opcua-otmr node into your Node-RED workspace
  2. Configure:
    • Endpoint (e.g., opc.tcp://192.168.0.10:4840)
    • Node ID (e.g., ns=2;s=Temperature)
    • Operation: Read, Write, or Subscribe
  3. Deploy the flow and monitor/debug results
Example Use Cases
  • Real-time temperature monitoring from a PLC
  • Writing setpoints to industrial devices
  • Live dashboards for machine data
Author
Developed by Omid Teimoori
GitHub: omidteimoori
GitHub Repository
GitHub: node-red-opcua-otmr
NPM Package
https://www.npmjs.com/package/node-red-opcua-otmr
Version: 3.0.2
Updated 1 year, 5 months ago
9 in the last week
  • opcua-otmr
  • opcua
  • node-red-contrib
  • opc ua
  • iiot
  • industrial
  • automation
