node-red-node-ui-webcam 0.5.0
A Node-RED ui node to capture images from a webcam.
npm install node-red-node-ui-webcam
A Node-RED UI widget node that allows images to be captured from the dashboard.
Either use the Editor - Menu - Manage Palette - Install option, or run the following command in your Node-RED user directory (typically ~/.node-red) after installing node-red-dashboard:
    npm i node-red-node-ui-webcam
The node provides UI widget that will display a live image from the web camera on the device running the dashboard.
The user can click a button to capture an image which is then sent by the node as a Buffer object contain the image in png or jpeg format.
If a message is passed to the ui_webcam node with the capture property set, and if the webcam has been activated on the dashboard, it will capture an image without the user having to click on the button.
The user can select the default camera to use in the on-screen widget dropdown. This will be used for future sessions with that browser until changed.
Browser Support
This node will work in all modern browsers, but not IE.
If you are accessing the dashboard remotely (not via localhost), then you must use HTTPS otherwise the browser will block access to the webcam.
Privacy
Before the webcam can be activated, the browser will ask the user's permission for the page to access the device. The node cannot capture images until the user has given their permission.
Version: 0.5.0
Updated 2 years ago
Rating: 4.2 5
71 in the last week
  • ui_webcam
  • node-red-dashboard
  • webcam
