node-red-node-toon 1.0.0
A Node-RED node to encode and decode objects to TOON format strings
npm install node-red-node-toon
node-red-node-toon
A Node-RED node to encode and decode objects to TOON format strings.
npm i node-red-node-toon
A function that converts the msg.payload object to and from TOON format.
If the input is an object it converts it to a TOON encoded string.
If the input is a TOON encoded string it tries to convert it back to an object.
Version: 1.0.0
Updated 1 year ago
  • toon
  • toon
