node-red-node-telegrambot 2.1.2
Telegram userbot nodes for Node-RED
npm install node-red-node-telegrambot
Telegram client nodes for Node-RED
Platform License Downloads Total Downloads NPM Known Vulnerabilities Telegram Package Quality Build Open Issues Closed Issues ...
This package contains a node which act as a Telegram Client. It is based on teleproto which implements the mtproto mobile protocol. (see https://core.telegram.org/mtproto). Unlike node-red-contrib-telegrambot it does not support the telegram bot api. The package can be used to create so-called userbots or selfbots which to automate things under your own user-name. However you should be aware of the fact, that if you cause flooding and other havoc telegram will quickly ban your account either for 24h or even forever. It is recommended to use a test account while developing.
Thanks for your donation
If you want to support this free project. Any help is welcome. You can donate by clicking one of the following links:
Buy Me A Coffee
Credits
NPM
You can install the nodes using node-red's "Manage palette" in the side bar.
Or run the following command in the root directory of your Node-RED installation
npm install node-red-node-telegrambot --save
Note that the minimum node-red version 1.3.7 and minimum nodejs version is 20.x.
Dependencies
The nodes are tested with Node.js v18.12.1 and Node-RED v3.0.2.
Up to version 0.2.1 this package used GramJS, which was archived in 2026. teleproto is a maintained fork of it. Your stored session keeps working — see ADR 0013.
Upgrading
Coming from an earlier version? MIGRATION.md has the upgrade path, including the two manual steps anyone on 0.1.x needs.
Changelog
Changes can be followed here.
Basics
Authentication
The Telegram client receiver node receives messages from like a telegram client. You need to login with a phone-number and an API ID and API Hash in order to be able to receive message under your own user name. In addition to that you can also login using a bot token retrieved from @botfather.
You can create an API ID and Hash when you login to your telegram account here https://my.telegram.org/auth Then go to 'API Development Tools' and create your API ID and API Hash. Both are required when configuring your nodes.
The nodes log in only once, to produce a so-called session string, which is then used instead of an interactive login. Create it in the config node — either with a phone code or with a QR code, see below.
Do not use one of the websites that offer to generate a session string for you — this page used to link to one, and that was bad advice. A session string authenticates your whole Telegram account, so producing one on someone else's site means handing that site your phone number, your login code and, with them, your account. Both routes in the config node keep it on your own machine.
Login with a phone code
Press Login. The panel asks for one thing at a time:
  1. Telegram sends a code. Type it into Phone-Code and click outside the field — leaving the field is what submits it.
  2. The Password field appears next. It is only needed if your account has two-step verification; if it has none, the login finishes on its own and the panel closes.
If a password is already stored for this config node, it travels with the login and step 2 is skipped — the tip under the button says so. You do not need to clear the field first.
Login with a QR code
Instead of waiting for a phone code, click Login with QR and scan the code with a Telegram app that is already signed in — in the app: Settings, Devices, Link Desktop Device.
The code is replaced every half minute until you scan it. If your account has two-step verification, enter the password in the same field the phone-code login uses. On a machine where Telegram is installed you can click the link under the code instead of scanning.
Both routes produce the same session string, so it makes no difference afterwards which one you used.
Receiver Node
The Telegram client receiver node receives message which are sent to your account or bot. Just add a debug node to the output and investigate the objects in msg.payload.
Message shape
Every event arrives in the same shape, so a flow can switch on one field:
msg.payload.type; // 'NewMessage' | 'EditedMessage' | 'DeletedMessage' | 'Album' | 'CallbackQuery' | 'Raw'
msg.payload.event; // the event itself, whatever the type
What each type adds next to those two:
type Also in msg.payload
NewMessage message, sender, chat, originalUpdate
EditedMessage message, sender, chat
DeletedMessage deletedIds
Album messages, originalUpdates
CallbackQuery query
Raw nothing — the update is msg.payload.event
sender and chat are resolved for you, which costs a lookup per message; that is why the filters below are worth setting on a busy account. Raw events also set msg.type = 'Raw' at the top level.
⚠ Changed in 2.0.0. Raw events used to put the update directly in msg.payload, with no msg.payload.type. See MIGRATION.md — it is one path segment.
Filters
Tick the event types you want, and optionally narrow them down. Filtering is done by Telegram's event builders, so traffic you are not interested in never reaches the flow at all — which matters on a busy account, because every message that does arrive costs a sender and chat lookup.
Field Effect
Chats Comma separated usernames or ids. Empty means every chat.
Exclude Turns the chat list into an exclude list.
Direction incoming only or outgoing only. Mutually exclusive in Telegram, hence one choice.
From users Comma separated senders, independent of the chat.
Pattern A regular expression the message text must match.
Not every filter applies to every event type, because Telegram's builders differ:
  • New messages and Edited messages support all of them.
  • Callback query supports Chats, Exclude and Pattern.
  • Deleted messages and Albums support Chats and Exclude only.
  • Raw events support none — raw updates arrive before Telegram resolves entities, so there is nothing to match a chat against.
Leaving every field empty reproduces the behaviour of earlier versions: no filtering.
Node status
Every node that talks to Telegram shows what the connection is doing:
Status Meaning
green ring connected the client is up
red ring disconnected the connection dropped; it recovers on its own
red dot broken: login again or redeploy the session is unusable or a reconnect gave up
red dot with a reason the connect never succeeded — see below
yellow ring flood wait Ns Telegram is throttling; it clears itself
blue dot working: uploading, downloading, reading
When a connect fails, the red dot names the cause rather than just saying disconnected: no session: login first if the config node was never logged in, session invalid: login again if the session died, api id or hash is wrong, and otherwise Telegram's own error code — which is worth searching for or quoting in an issue. It turns green as soon as a connection works, and the reason is dropped then.
Download Node
The Telegram client download node fetches the media on a received message — a photo, video, voice note or document. Wire it straight to a receiver output; it accepts what the receiver emits, so nothing has to be unwrapped.
[client receiver] --> [client download] --> [file out]
Output:
Property Contents
msg.payload the file as a Buffer
msg.filename the document's own name, or a generated one
msg.mimetype the mime type (photos are always image/jpeg)
msg.telegram the original message, so the sender and chat stay reachable
That is the shape file out and http response already expect, so they can follow directly.
Two settings matter:
  • Thumbnail — leave empty for the media itself, or give an index to fetch a thumbnail instead (0 is the smallest). Useful when you want a preview rather than a 40 MB original.
  • Max size — in megabytes. A larger download is refused with an error instead of being read into memory. 0 disables the check. The size is not known in advance for every kind of media, and the check is skipped when it cannot be determined — a safeguard, not a guarantee.
The node shows downloading 42% while it works, and a redeploy stops a download in flight rather than letting it stream into a node that no longer exists.
download media flow
Upload Node
The Telegram client upload node sends a file to a chat — the mirror of the download node.
[file in] --> [client upload]
Inputs:
Property Contents
msg.payload the file: a Buffer or a path as a string
msg.filename required for a Buffer — a Buffer carries no name of its own
msg.peer overrides the configured Send to
msg.caption overrides the configured Caption
msg.payload becomes the message Telegram created, so a following node can reply to it, edit it or pin it. The Buffer is not carried through.
Why msg.filename is required: teleproto names an unnamed Buffer literally unnamed, so the file would arrive in the chat called that. The node reports an error instead of sending it wrongly. A path needs no filename — Telegram uses the file's basename.
For large files pass a path rather than a Buffer: the whole file otherwise has to fit in memory before it can be sent.
Albums
An array in msg.payload is sent as one album, which is how Telegram groups several photos or videos into a single post. Every Buffer in it still needs its own name, so msg.filename is an array aligned by index; a path in the array needs no entry.
msg.payload = [bufferOne, '/tmp/second.jpg', bufferThree];
msg.filename = ['first.jpg', undefined, 'third.jpg'];
If any item is wrong the whole album is refused, naming the position — msg.filename[2] is required when msg.payload[2] is a Buffer. An album is a unit, and half of one arriving is worse than none.
The output is an array of the messages Telegram created, one per item.
Other options
Property Effect
msg.silent overrides Silent — deliver without a notification sound.
msg.replyTo a message id to reply to. Left out of the request entirely when unset.
msg.caption overrides Caption. An array is accepted for an album.
The node shows uploading 42% while the file goes up, so a large one does not look like a hang. A redeploy cancels an upload in flight rather than letting it finish into a node that no longer exists.
There is no thumbnail option. Telegram ignores thumb unless the file is a JPEG under roughly 20 kB and 320×320 and the underlying media's dimensions are supplied through the raw TL attributes, which this node does not expose — a field that mostly does nothing is worse than no field.
upload file flow   upload album flow
List Node
The Telegram client list node reads existing data: a chat's message history, your dialogs (the chat list), or the participants of a group or channel.
None of these work through the sender node, because Telegram returns them as async iterators — putting one into msg.payload gives a flow an object it cannot use. This node iterates and decides how the items become messages.
Output modes
one message per item (the default) emits each item separately with msg.parts set, so a standard join node in automatic mode reassembles the array:
[inject] --> [client list] --> [join] --> [debug]
Use this for history: a large one never has to fit in memory at once. msg.parts.count comes from Telegram's own total for the query, capped at the limit.
one message with an array emits a single message whose msg.payload is the whole array, with msg.total alongside. Simpler for small reads — a chat list, the members of a group — but everything is held in memory first.
The limit is not a formality
Limit Meaning
blank 100 items
a number that many items
0 no limit
Telegram's own default here is unbounded. Iterating a busy channel back to its first message takes a long time and can earn a FLOOD_WAIT; on a user account, repeatedly, that risks the account. 0 is available, but it has to be asked for — the same convention as Max size on the download node.
Inputs
Every setting the dialog offers can also arrive with the message, so one configured node can serve a flow that reads different things. Send msg.payload as an object:
msg.payload = {
    what: 'messages', // Read:      messages | dialogs | participants
    peer: 'me', // Read from: a username, a chat id, or "me" for Saved Messages
    limit: 50, // Limit:     0 means everything
    mode: 'stream', // Output:    stream | array
    search: 'invoice', // only messages and participants can be searched
Leave a field out to keep what the node has configured. The ReadHistory example ships a Function node that does exactly this.
The flat properties came first and still work:
Property Effect
msg.peer overrides Read from. Ignored for dialogs.
msg.limit overrides Limit.
msg.search overrides Search. Ignored for dialogs, which Telegram cannot search here.
msg.payload wins where both are given. A payload that is not an object — a timestamp from an inject, a string — contributes nothing and simply triggers the read, so existing flows are unaffected. An unknown what or mode is reported as an error rather than guessed at.
Any message triggers a read, and its other properties are carried through to every emitted message.
The node shows read n while it works, so a long read does not look like a hang. A redeploy stops it at the next item rather than continuing to pull from Telegram.
read history flow
Sender Node
The Telegram client sender node is able to call nearly all functions provided by teleproto. For a full list of client methods see the TelegramClient reference; for the raw MTProto requests see core.telegram.org/methods.
Two calling conventions
Leaving api out calls a method on the teleproto client directly, with args spread as its arguments — so args must be an array:
msg.payload = { func: 'sendMessage', args: ['someone', { message: 'Hello' }] };
Setting api builds a raw MTProto request, which takes a single options object:
msg.payload = { api: 'messages', func: 'SendMessage', args: { peer: 'someone' } };
Formatting message text
By default text is sent exactly as given. To get bold, links or code blocks, Telegram has to be told to interpret the text — either per message, which is usually what you want:
msg.payload = {
    args: ['someone', { message: '*bold* and _italic_', parseMode: 'md' }],
or for every message this client sends, via Parse mode on the config node (Markdown, MarkdownV2 or HTML).
Escaping: with a parse mode active, any text your flow did not write itself — a user's name, a value from an API, an error message — must be escaped first. A stray *, _ or < will render wrongly or make Telegram reject the message outright. If only some of your messages are formatted, leave the config-node setting off and pass parseMode per message.
Catching up after a restart
Messages that arrive while Node-RED is stopped or redeploying are normally lost — the receiver subscribes to the live stream and has no idea what it missed.
Catch up on the config node changes that. The position in the update stream is remembered in <user directory>/telegram-updates/<node id>.json, and on the next start everything since is fetched and emitted through the receiver. Replayed messages travel the same path as live ones, so a flow needs no changes and cannot tell the difference.
Off by default, on purpose: after a long outage on a busy account this arrives as a flood the moment you deploy.
Two limits worth knowing:
  • Telegram decides how far back it will replay. Past that it refuses, those messages are gone, and the log says getDifference: too long.
  • A message may be delivered twice around the boundary. Most duplicates are filtered out, but a flow that must not act twice should be idempotent.
Remembering peers across a restart
Telegram will not let a client address a user by numeric id alone — it needs an access hash, which the client only holds for peers it has already seen. That list normally lives in memory, so it is empty after every restart: a flow that addresses peers by id works while you build it and then fails with Could not find the input entity after a redeploy.
Remember peers on the config node keeps the list on disk, in <user directory>/telegram-sessions/<node id>, so numeric ids keep working.
It is off by default, deliberately. That directory also holds this account's session key — the same secret as the session string, which otherwise lives only in Node-RED's encrypted credentials file. Anyone who can read the directory can act as your account. Turn it on only if you address peers by numeric id, and treat the directory like the credentials file.
Usernames and invite links never needed it: they are resolved on demand.
Addressing a chat or user
You do not need to resolve peers yourself — both calling conventions accept a username and let teleproto look it up. How you address a peer decides whether it keeps working, though:
You pass Works
'username' Always. Costs one lookup, which Telegram then caches for the session.
An invite link Always.
A numeric id Only while that peer is in the session's cache.
A phone number Only if that person is in your account's contacts.
The catch is the numeric id. Telegram will not let you address an arbitrary user by id alone — it needs an access_hash, which the client only holds for peers it has already seen in this session. That cache lives in memory and is lost on every restart, so a flow that works while you are building it can fail after a redeploy with:
Could not find the input entity for ...
Two more messages mean a peer problem without saying so. The node adds an explanation to the log for both:
Error What it means
Cannot cast undefined to any kind of undefined No peer was passed at all — peer is undefined.
Cannot cast User to any kind of peer The peer is an object that lost its class, e.g. one that went through JSON.
The first is the one a flow built on a received message hits: msg.payload.chat comes from getChat(), which returns nothing when the session has no access hash for that chat. msg.payload.message.peerId is on every message and is the fallback to use — the shipped EchoMessage example does exactly that.
Address peers by username and none of this happens. If you only have an id, resolve it once in the same flow with getEntity and pass the result on:
msg.payload = { func: 'getEntity', args: ['username'] };
// then send to msg.payload from the next node
Buttons
Pass a plain-JSON buttons description in the options object and the node turns it into the objects Telegram needs — an array of rows, each row an array of buttons:
msg.payload = {
    args: [
        'someone',
            message: 'Pick one',
            buttons: [
                [{ type: 'url', text: 'Open the docs', url: 'https://docs.teleproto.dev' }],
                    { type: 'callback', text: 'Yes', data: 'yes' },
                    { type: 'callback', text: 'No', data: 'no' },
type Needs Effect
url url opens a link
callback data sends data back — bot mode only, see below
switchInline — starts an inline query, optional query, samePeer
text — a plain keyboard button; the text is sent as a message
requestLocation — asks the user to share their location
requestPhone — asks the user to share their phone number
An invalid button is reported with its position, for example buttons[1][0]: a 'url' button needs a 'url'.
Callback buttons only work in bot mode. Telegram sends the button press to the bot that created the button — the API documentation is explicit that the update is "sent to the bot". A user account has no bot, so it will never receive the press, and the receiver's Callback query event will stay silent. Use url buttons for userbot flows, or set the config node's login mode to bot.
Useful client methods
Anything on the client is reachable by name. The ones worth knowing:
Area Methods
Sending sendMessage, sendFile, forwardMessages, editMessage, deleteMessages
Chats pinMessage, unpinMessage, markAsRead, kickParticipant
Reading getMessages, getDialogs, getParticipants
Media downloadMedia, downloadFile, downloadProfilePhoto, uploadFile
Entities getEntity, getInputEntity, getPeerId
Account getMe, isBot, isUserAuthorized, checkAuthorization
The iter* variants (iterMessages, iterDialogs, iterParticipants) return async iterators, which do not survive being placed in msg.payload. Use the non-iterating methods until dedicated support exists.
Careful: the client is shared by every node using the same config node. Connection and authentication methods — connect, disconnect, destroy, start, signIn…, addEventHandler — are reachable too, and calling them from a flow will disrupt the other nodes.
Examples
Api.messages.SendMessage
To call the SendMessage function, you must do the following: Create a function node and enter 'messages' for the api property and 'SendMessage' for the func property. The arguments described in the api must be added to args. SendMessage contains a field randomId which must be set by the user to a random number to prevent message looping in the telegram server. Peer must be set to the name of the user you want to send the message to.
let randomId = BigInt(Math.floor(Math.random() * 1e15));
let username = msg.payload;
msg.payload = {
    api: 'messages',
    args: {
        peer: 'to username',
        message: 'Test1',
        randomId: randomId,
        noWebpage: true,
        noforwards: true,
        scheduleDate: 0,
        // sendAs: "from username",
send message flow
Api.account.CheckUsername
To call the CheckUsername function, you must do the following: Create a function node and enter 'account' for the api property and 'CheckUsername' for the func property. The arguments described in the api must be added to args. In this case it is only the username property.
msg.payload = {
    api: 'account',
    func: 'CheckUsername',
    args: {
        username: 'usernameToCheckHere',
check username flow
Version: 2.1.2
Updated 3 months, 3 weeks ago
Rating: 5.0 3
187 in the last week
  • telegram client config
  • telegram client receiver
  • telegram client sender
  • telegram client download
  • telegram client upload
  • telegram client list
  • telegram
  • bot
  • userbot
  • selfbot
  • mtproto
  • teleproto
