node-red-node-tdengine 1.0.3
The official plugin developed by TDengine for Node-RED.
npm install node-red-node-tdengine
TDengine Integration with Node-RED
Overview
Node-RED is an open-source visual programming tool developed by IBM based on Node.js. It enables users to assemble and connect various nodes via a graphical interface to create connections for IoT devices, APIs, and online services. Supporting multi-protocol and cross-platform capabilities, it has an active community and is ideal for event-driven application development in smart home, industrial automation, and other scenarios, with its main strengths being low-code and visual programming.
The deep integration between TDengine and Node-RED provides a comprehensive solution for industrial IoT scenarios. Through Node-RED's MQTT/OPC UA/Modbus protocol nodes, data from PLCs, sensors and other devices can be collected at millisecond-level speed. Real-time queries of TDengine can trigger physical control actions like relay operations and valve switching for immediate command execution.
node-red-node-tdengine is the official plugin developed by TDengine for Node-RED. Composed of two nodes:
  • tdengine-operator: Provides SQL execution capabilities for data writing/querying and metadata management.
  • tdengine-consumer: Offers data subscription and consumption capabilities from specified subscription servers and topics.
tdengine-operator
  • Supports TDengine local deployment or cloud service data sources.
  • Full coverage of all TDengine SQL operations (SELECT/INSERT/CREATE/ALTER/SHOW, etc.).
  • Unified interface for handling both read and write operations using msg.topic to pass SQL statements.
tdengine-consumer
  • Support TDengine local deployment or cloud service data sources.
  • Flexible configuration of subscription properties.
  • Support subscribing to multiple topics simultaneously.
  • Automatically submit and save consumption progress.
  • Automatically reconnect after server disconnection.
Prerequisites
Prepare the following environment:
  • TDengine >= 3.3.2.0 (Enterprise/Community/Cloud Edition are available).
  • taosAdapter is running, refer to taosAdapter.
  • Node-RED >= 3.0.0, Node-RED installation.
  • Node.js Connector for TDengine >= 3.1.8, get from npmjs.com.
Configure Data Source
TDengine WebSocket connection string format:
  • tdengine-operator: ws://user:password@host:port
  • tdengine-consumer: ws://host:port
See detail here.
Run the following command in your Node-RED user directory - typically ~/.node-red .
  npm i node-red-node-tdengine
Node Status
  • Grey: Connecting.
  • Green: Operational.
  • Red: Malfunction.
Input Format
tdengine-operator
Pass SQL statement via topic:
msg = { topic: "SQL statement" }
Special characters and escape sequences in SQL must follow JSON string specifications.
tdengine-consumer
Input node (no input).
Output Format
tdengine-operator
  • Write Operations
    The payload contains write results, and the topic passes through the SQL statement:
    msg = {
    topic: "insert into ...",
    isQuery: false, // true for query operations
    payload: {
    affectRows: 2,  // affect rows
    totalTime: 3,   // Total write time (ms)
    timing: 1683311 // Server-side execution time (ns)
  • Query Operations
    payload contains query results, topic passes through SQL:
    topic: "select * from ...",
    isQuery: true, // true for query operations
    payload: [
    { ts: 1749609744000, current: 20, voltage: 200, phase: 5 },
    { ts: 1749609200001, current: 31, voltage: 210, phase: 4 },
Query results are row data objects where properties correspond to column names. For data type mappings: TDengine NodeJS Connector Type Mapping.
tdengine-consumer
payload outputs array of objects where properties correspond to column names: TDengine NodeJS Connector Type Mapping.
  topic: Subscription topic,
  database: Database name,
  vgroup_id: Data partition,
  precision: Database precision
  payload: [{
    column_name1: value1,
    column_name2: value2,
Quick Start
Input
// Example: Inserting data
msg.topic = "insert into test.d0 values ('2025-06-10 10:00:02.001', 23.5, 220, 3)";
// Example: Querying data
msg.topic = "select * from test.d0";
Output
  • Insert Result
    "topic":  "insert into test.d0 values ('2025-06-10 10:00:02.001', 23.5, 220, 3)",
    "_msgid": "8f50fe84338387d7",
    "isQuery": false,
    "payload":{
        "affectRows": 1,
        "totalTime":  2,
        "timing":     "961982"
  • Query Result
    "topic":  "select * from test.d0",
    "_msgid": "0d19e9b82ae3841a",
    "isQuery":  true,
    "payload": [
      { "ts": 1749609744000, "current": 10, "voltage": 219, "phase": 0.32 },
      { "ts": 1749609200001, "current": 31, "voltage": 210, "phase": 4 }
  • Subscribe Result
    "topic": "topic_overload",
    "payload": [
        "tbname":   "d1",
        "ts":       "1750140456777",
        "current":  31,
        "voltage":  217,
        "phase":    2,
        "groupid":  4,
        "location": "California.MountainView"
    "database":  "test",
    "vgroup_id": 4,
    "precision": 0
Documents
Resources
Version: 1.0.3
Updated 1 year ago
11 in the last week
  • TDengineServer
  • tdengine-operator
  • tdengine-consumer
  • tdengine
  • tdengine-operator
  • tdengine-consumer
  • taos
  • subscribe
  • consumer
  • time series
  • tdengine plugin
  • node-red-contrib-tdengine
