node-red-node-smaz 0.0.2
A Node-RED node to pack and unpack strings to smaz format
npm install node-red-node-smaz
node-red-node-smaz
A Node-RED node to pack and unpack strings to smaz format buffers.
Either use the Manage Palette option in the Node-RED Editor menu, or run the following command in your Node-RED user directory - typically ~/.node-red
Uses a smaz library to pack and unpack short strings to small buffers.
Note: this node ONLY accepts strings - anything else will just be dropped.
If the input is a string it converts it into a smaz buffer.
If the input is a smaz buffer it converts it back to the original string.
Version: 0.0.2
Updated 6 years, 3 months ago
2 in the last week
  • smaz
  • smaz
