node-red-node-sentiment 0.1.6
A Node-RED node that uses the AFINN-165 wordlists for sentiment analysis of words.
npm install node-red-node-sentiment
A Node-RED node that scores incoming words using the AFINN-165 wordlist and attaches a sentiment.score property to the msg.
NOTE: There is also a multi-language version available - node-red-node-multilang-sentiment.
This is a node that should be installed by default by Node-RED so you should not have to install it manually. If you do then run the following command in your Node-RED user directory - typically ~/.node-red
Uses the AFINN-165 wordlist to attempt to assign scores to words in text.
Attaches msg.sentiment to the msg and within that msg.sentiment.score holds the score.
A score greater than zero is positive and less than zero is negative. The score typically ranges from -5 to +5, but can go higher and lower.
See the Sentiment docs here.
Version: 0.1.6
Updated 7 years, 5 months ago
Rating: 1.0 1
552 in the last week
  • sentiment
  • sentiment
  • anaylsis
  • AFINN
